ACC Error
bex
Is anyone getting lots of these errors, mine has started to do it on a daily basis. I took it to the dealers and they said that no error codes had been registered (???) and went on about keeping the sensor clean.  I laboured the point that Im verging on OCD when it comes to cleaning the car but as it didnt throw up the error in the 2 hours they had it they 'couldnt' do anythng with it.  Needless to say it was back on the next day.  In most instances it dissappears if you switch the car off and on again and they reassured me its safe to drive however its bl88dy annoying.  The cars due its second service in 2 months and ill be pressing for a replacement sensor then but wondered if anyone else had similar issues and manged to get it resolved?
I've been getting this quite a lot, and have it booked in for investigation, I'm slightly alarmed to read above that it could indicate an engine fault, the dealer didn't mention this when I first reported having problems.
  • 3 weeks later...
  • 1 month later...
I had this issue yesterday driving down from a bendy car car park.
I was assuming that driving round bends affects the sensor.
The error cleared itself after driving for about a mile .
I have the same thing. I normally get it at a very sharp corner in my town. I had another R owner ask me about it too - he also gets the error at the same spot! Guess it's a flaw, rather than an actual part failure.
m33porsche, on 11 Oct 2015 - 09:56 AM, said:
Mine says ACC Deactivated - had it working for a bit but now nothing.......Can't be arsed to take it to the dealers, might even be a case of RTFM for me
m33
This just means that it is turned off. Press the button on the steering wheel to turn it on again.
Not sure if this have any bearing on the issues in this topic but I have just had a new replacement front reg plate fitted by the supplying dealer. They said that the original one,  which had a rubber strip displaying their dealership name running along the bottom edge, has affected the front main sensor by being in its field of view.
I get "ACC Deactivated" when I pull up on my drive, switch off , open the garage and start engine - may be something to do with the fact that it sees a solid wall in front of it, or the wing mirrors folded in, or maybe because I don't have my seat belt on. ACC works absolutely fine whenever I use it, so in this case I don't think it's a fault.
  • 3 months later...
Please be gentle with me - this is my first post on here.
Read the comments about ACC issues with interest, I have an ACC story and want to advise, but also see if anyone else has had anything similar!
My ACC failed on my Golf Mk 7 about three months ago, while driving 50mph just threw up an error, I did the usual cleaned the sensor casing (as I've done previously, but this time it didn't fix it), then after loads of battling with VW CS in MK got it booked in for a warantee check to determine if the issue is caused by me/miss-use, or a component failure ... then today the following :-
- Dealer agrees that there is no sign of any impact (a) the bumper, spoiler and surround all intact, no sign of damage (B) the sensor cover is all clean/tidy, no impact or scratches © and additionally when the cover is removed, nothing inside shows any evidence of impact, no scratches, cracks and (d) no damage to the mounting brackets that hold the sensor into the car !
- But when the bezel cover is removed a small lens at the top of the unit (approx .5cm square) is "damaged/missing an apparent very small glass lens" - I'm told it is "bonded" (i.e. glued in) and not held in by anything else ... so, you would have thought simple ... the glue has failed and the dealer would agree, that this is a part failure and not down to miss-use or damage ! ... in addition the little square where the lens would have been located, shows clear evidence of a "mirror like foil partially there, and some sort of glue, that looks like a dab that hasn't been applied properly at the time of manufacturer.
- So now I enter the next chapter - awaiting to hear from VW CS in MK to see what they are going to do!
- Looks pretty apparent the "dab of glue" applied during the manufacturing process has failed during normal use of the vehicle, and also may not have been applied correctly anyway.  Resulting in the small glass lens just falling out !
- Given the extremes of temperature that this unit is exposed to, (the elements in general) snow, sleet, rain etc. - it's pretty apparent that the glue has failed !
Who knows as vehicles become older more parts may fail with this same issue !
  • 2 weeks later...
  • 2 months later...
I've 'bumped' the front of my R on a parking stop.... my ACC sensor is out of alignment. I have no dealer in my city, I'll be doing what I can myself. I've noticed this little mirror, and am thinking it would be perfect to bounce a laser off to align it.  Can anyone tell me if the sensor should be perfectly forward facing or is it tilted up or down any?
I had the same issue but think it was due to someone reversing into me whilst parked as I had a cracked numberplate. I replaced the numberplate and took it into the dealers; however, they refused to cover it under warranty as it had taken a knock. Had to fork out £396 in the end to get it calibrated!
  • 9 months later...
 Thought I would bump this as I've just picked up a 2yo R noticed I'm getting the acc deactivated when I start the car? It appears to be working fine but how do I get rid of the message(it disappears straight away).
I quoted the above as the front plate seems to have a strip along the bottom with the dealers name which is bigger than a standard plate?
Am I doing something stupid it didn't come up on my GTi.
i only get that message if the acc is switched off.........
