DriveR Posted June 10, 2016 Report Share Posted June 10, 2016 If one disables the stop/start feature with VCDS, can the stop/start button next to the gear shift lever still be used to turn it back on temporarily? I have acquired the habit of hitting the button to turn stop/start off after starting the car, but occasionally like to turn it back on by tapping the button if I know I'm going to be stationary for a few minutes or more (I like the fact one can then dab the throttle to start things up - it would be perfect if that also then re-disabled the stop start feature...). Basically I'd like the car's stop/start behaviour to be inverted (off by default, on if I choose it)! My concern is that if I get VCDS and disable the feature, I won't be able to use it on the odd occasion I want to. Quote Link to comment Share on other sites More sharing options...
A l 3 x Posted June 10, 2016 Report Share Posted June 10, 2016 I think it just completely removes the feature, hence why I've not done it myself. Quote Link to comment Share on other sites More sharing options...
DriveR Posted June 10, 2016 Author Report Share Posted June 10, 2016 I think it just completely removes the feature, hence why I've not done it myself. Ah, OK; thanks. If anyone who has disabled it can confirm it would be much appreciated. Quote Link to comment Share on other sites More sharing options...
marshy Posted June 10, 2016 Report Share Posted June 10, 2016 I disabled mine via vcds by altering the battery voltage setting. When the car would use stop start you get the usual icon meaning it's not possible to function. The button makes no difference. Exactly how I'd want it, gets rid of the useless invention which in my opinion causes more damage than good. DriveR 1 Quote Link to comment Share on other sites More sharing options...
DriveR Posted June 10, 2016 Author Report Share Posted June 10, 2016 I disabled mine via vcds by altering the battery voltage setting. When the car would use stop start you get the usual icon meaning it's not possible to function. The button makes no difference. Exactly how I'd want it, gets rid of the useless invention which in my opinion causes more damage than good. OK, thanks. I agree stop start is probably bad for the car; I expect it's an "emissions requirement", hence not something a (normal) end-user can permanently disable. Quote Link to comment Share on other sites More sharing options...
Rich_D Posted June 10, 2016 Report Share Posted June 10, 2016 Disabled means exactly that, once you turn it off with VCDS the button does nothing and only VCDS can turn it back on. marshy, DriveR and goRt 3 Quote Link to comment Share on other sites More sharing options...
Mcahill Posted June 10, 2016 Report Share Posted June 10, 2016 I've had the Autowatch ghost immobiliser installed to protect the car and it can be programmed to automatically disable start stop every time the ignition is turned on but you can enable it by pushing the button. Rob2k68 and DriveR 1 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted June 10, 2016 Report Share Posted June 10, 2016 Or, you can make Start Stop automatically turn-off every time you turn-on the ignition switch (and turn it on again later- if you want) with a simple SS kill switch! I've designed and built a few of these and I have had them working for about 2 years now on my mk7 - works every time! Parts can be easily sourced and all you need is basic soldering skills - it's real easy Instructions in the link below Don http://www.vwwatercooled.com.au/forums/f197/golf-mk7-auto-start-stop-disable-switch-who-wants-help-108932.html#post1154903 DriveR 1 Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted September 26, 2016 Report Share Posted September 26, 2016 I've had the Autowatch ghost immobiliser installed to protect the car and it can be programmed to automatically disable start stop every time the ignition is turned on but you can enable it by pushing the button. sorry to hijack this thread a little how are you getting on with the autowatch ghost as looking at this myself Taz23-R 1 Quote Link to comment Share on other sites More sharing options...
Mcahill Posted September 26, 2016 Report Share Posted September 26, 2016 I love it, it makes me never worry about the car now as I know it will always be parked exactly where I left it. Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted September 27, 2016 Report Share Posted September 27, 2016 I love it, it makes me never worry about the car now as I know it will always be parked exactly where I left it. think i am also going to go down this route clever bit of tech when you think about it Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted October 10, 2016 Report Share Posted October 10, 2016 I love it, it makes me never worry about the car now as I know it will always be parked exactly where I left it. got it booked in for next sat for it to be fitted so looking forward to that also just re read you post it can auto disable the SS thats a bonus as well has used OBD Eleven but it dont always work and sometimes i find it stops Quote Link to comment Share on other sites More sharing options...
GeoffT Posted October 10, 2016 Report Share Posted October 10, 2016 think i am also going to go down this route clever bit of tech when you think about itI'm also thinking about this. Apparently the latest versions can also work by detecting the presence of a phone by Bluetooth so you don't even need to enter a PIN. It only works on iPhones at the moment but an Android version should be available soon. As soon as that is available I think will go for it. I've got my stop start permanently disabled via VCDS at the moment, but very occasionally it might have been useful to have in long queues etc so to have this unit automatically turn it off at start up, but still have it available on request is even better. It's a shame it's not available for DIY fit though. Quote Link to comment Share on other sites More sharing options...
Mcahill Posted October 10, 2016 Report Share Posted October 10, 2016 got it booked in for next sat for it to be fitted so looking forward to that also just re read you post it can auto disable the SS thats a bonus as well has used OBD Eleven but it dont always work and sometimes i find it stops Who is installing it for you and what price was you quoted Quote Link to comment Share on other sites More sharing options...
Mcahill Posted October 10, 2016 Report Share Posted October 10, 2016 I'm also thinking about this. Apparently the latest versions can also work by detecting the presence of a phone by Bluetooth so you don't even need to enter a PIN. It only works on iPhones at the moment but an Android version should be available soon. As soon as that is available I think will go for it. I've got my stop start permanently disabled via VCDS at the moment, but very occasionally it might have been useful to have in long queues etc so to have this unit automatically turn it off at start up, but still have it available on request is even better. It's a shame it's not available for DIY fit though. I've got the iPhone Bluetooth system installed in mine. Quote Link to comment Share on other sites More sharing options...
