Rusty discs
discolegend73
Some people have managed to get theirs painted by the dealer FOC, but probably better to sort yourself and save yourself the risk of the dealer causing other damage.  Mine started rusting after about a month but haven't got too much worse, but intend to paint them this year.
They are mild steel discs, there is salt on the road and moisture, rust is a perfectly normal reaction in those conditions, either live with it or paint them, plenty of other posts on here on the subject.
If you buy some of the after marked discs for an extra £15 a pair they are coated (still cheaper than the OEM discs) the first time you drive the coating is removed from the braking surface leaving the rest protected had a set on my old 25th anni for 8 years and 60k with out any signs of rust on a car that costs as much as an R it's a disgrace tat VW can't or won't do better
My cars 3 months old and the rust is starting to show, my previous BMW did the same. Get a drill and a spinning wire brush disc to remove the build up of rust then a coat of silver hammerite does the trick. Did this on my BMW, plan to do it on the GR7 once the weather improves.
