Rusty discs
discolegend73
Very common unfortunately
I did mine around 12 months ago, rubbed down a touch with scotchbrite pad then wiped over with thinners, masked the disc up with frog tape and paper then painted them with aerosol, high temperature silver BBQ paint, rated to 600c, still looking great today :-D
Don't whatever you do use hammerite/smoothrite, guy in work done his on a 2015 S3 and rust came straight back through within a matter of couple months
If you buy some of the after marked discs for an extra £15 a pair they are coated (still cheaper than the OEM discs) the first time you drive the coating is removed from the braking surface leaving the rest protected had a set on my old 25th anni for 8 years and 60k with out any signs of rust on a car that costs as much as an R it's a disgrace tat VW can't or won't do better
It's not just VAG, most cars suffer from rusty hubs after a while, some worse than others. I noticed a fairly new Merc C class in a car park the other day which were far worse than those on my R. A mate at work has a 65 plate 330d and the discs and calipers are in a terrible state.
Audi were also suffering from this and a few years ago they would replace them if you kicked off enough, i was just saying there is a cheap easy fix to be had but looks like VW and a number of others aren't bothered enough to make it happen
I always find rusty hubs and discs interesting. My car is 11 months old and my hubs and discs are doing fine compared to some other cars. I do plan to paint them to prevent future rusting.
They're filthy but this is what they currently look like. Not bad rust wise at all compared to others on here:
funny thing, i washed mine this morning and with this thread freshly in my mind i paid particular attention to the rusting brake discs. Rear ones are pretty much on par with those on here, front ones have virtually zero rust, you really have to look closely to see it. seems weird but there you go.
Mine looked like that after 2 weeks of ownership
Sent from my SM-T810 using Tapatalk
