Stobsie Posted January 4, 2019 Report Share Posted January 4, 2019 3 hours ago, MMCW said: That is my worry too I might find it really annoying to put in the pin in every single time. I also saw that even if you open the door and close it you will need to put in the code again? Is this true? After a day or two it becomes second nature and really isn't a issue entering the pin code. However if you do find it challenging you can also get the AWG App so you don't have to do anything more than have your phone on you. Quote Link to comment Share on other sites More sharing options...
Mark@sasmobile Posted January 4, 2019 Report Share Posted January 4, 2019 Hi Guys,There’s a link here to the demonstration video which shows how simple it is to use. https://www.facebook.com/safesoundvehiclesystems/videos/1642217795794407/I often say to customers if we install one and you don’t like it then I’ll remove it for you but I’m yet to be taken up on the offer. In relation to putting a code in each time the door is opened, that’s the hi-jack feature which as I mentioned before Christmas isn’t supported on VAG cars without a Shadow installed. It’s only supported on the MK3 Focus. All other vehicles such as BMW, Merc etc its a trial to see at the point of installation but no guarantees can be given but it will it work on VAG. For the programming codes and other things the ghost can do - I simply can not give a feature table. You guys could end up in all sorts of trouble as the codes that are applicable for one MQB VAG car aren’t forced to be the same on a G100 car so where one may fold wing mirrors it put the windows DOWN in another car. Those features are programmable by the installer only. It’s not worth you guys trying. There is the start stop override which some of you may have but again this isn’t officially supported or endorsed by myself or Autowatch. If anyone needs to turn it off please speak to your supplying dealer or if it was me and we did it by accident then just give me a call in office hours and I’ll talk you through it while you sit in your cars 01133979597Hope this helps. Sent from my iPhone using Tapatalk MMCW and Rob2k68 1 1 Quote Link to comment Share on other sites More sharing options...
ellixtt Posted January 4, 2019 Report Share Posted January 4, 2019 3 hours ago, MMCW said: That is my worry too I might find it really annoying to put in the pin in every single time. I also saw that even if you open the door and close it you will need to put in the code again? Is this true? Im used to it now after just a few weeks of it and it’s totally normal, like I said the code can be inputted fast so it’s not a bother. The code after opening doors is the ‘Anti Hijack’ feature which does not work on VAG vehicles. MMCW and SpursMadDave 1 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted January 5, 2019 Report Share Posted January 5, 2019 I was on the fence for a few months and did loads of research but I had it done 3 weeks back and it’s very, very good. For me I didn’t know how responsive it would be which would have been a pain in petrol stations and places like that if it had to type the pin in slowly but its really not like that. I turn the ignition on and type the code in as fast as I want and it will register and I can start the engine. For me it’s total peace of mind (except the possibility of it being towed away ) I watched the guy fitting it and you wouldn’t find it.But now you know where it is... do that fit it in the same place all the time?Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Nitto Posted January 6, 2019 Report Share Posted January 6, 2019 I have been looking at AWG as well for a while, it looks to be becoming more popular. Most installers seem to located in the northern area. Can any one recommend an installer that covers Berkshire area or a nationwide installer. I had seen Advanced In-Car Technologies. Quote Link to comment Share on other sites More sharing options...
ellixtt Posted January 6, 2019 Report Share Posted January 6, 2019 On 05/01/2019 at 12:06, SpursMadDave said: But now you know where it is... do that fit it in the same place all the time? Sent from my SM-G935F using Tapatalk No it can be fitted in loads of different spots all over the car, roof lining, behind dash, foot wells, side pillars etc. The guy who installed it said it’s their most popular installs and they always fit them in different locations but like they said to me, it’s only as good as the installers so if you get a sloppy visable install then it’s pointless! SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted January 6, 2019 Report Share Posted January 6, 2019 No it can be fitted in loads of different spots all over the car, roof lining, behind dash, foot wells, side pillars etc. The guy who installed it said it’s their most popular installs and they always fit them in different locations but like they said to me, it’s only as good as the installers so if you get a sloppy visable install then it’s pointless!Yeah guessed as much otherwise like keeping your front door key under the plant by the doormat.... better move mine now!Sent from my SM-G935F using Tapatalk ellixtt 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted January 6, 2019 Report Share Posted January 6, 2019 Yeah guessed as much otherwise like keeping your front door key under the plant by the doormat.... better move mine now!Sent from my SM-G935F using TapatalkA little like the Disklok steering wheel locks. Most people have the key with the car key or house keys. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted January 6, 2019 Report Share Posted January 6, 2019 A little like the Disklok steering wheel locks. Most people have the key with the car key or house keys. Sent from my iPhone using TapatalkYeah Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
