thanksabunch Posted May 20, 2017 Report Share Posted May 20, 2017 Morning all I have a couple hundred albums on an SD card in my R They all play just fine but whenever I turn engine off soon as I restart the head unit has returned to the first Album in my library! If I remember to select radio before switching engine off I can then resume playing the album where I left off later on by pressing the media button very annoying is this normal or am I doing something wrong? Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted May 20, 2017 Report Share Posted May 20, 2017 polo does the same with discover nav P.I.T.A. ! thanksabunch 1 Quote Link to comment Share on other sites More sharing options...
thanksabunch Posted May 20, 2017 Author Report Share Posted May 20, 2017 Not just me being stupid then it seems thanks Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted May 20, 2017 Report Share Posted May 20, 2017 I just leave mine on random and advance a track each time I start up....at least the randomiser is quite random ! Quote Link to comment Share on other sites More sharing options...
DUB Posted May 20, 2017 Report Share Posted May 20, 2017 Mine will play one day and the follow day tell me it cannot read the SD card!! I take it out and delete/copy again on the laptop, it works for few days then the same thing happens. Given up with it now. Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted May 20, 2017 Report Share Posted May 20, 2017 I use a 32gb SD card in mine with MP3's and the only time it "forgets" is if the SD card gets removed from it's slot. Otherwise, it always starts exactly where it was when it was switched off. I don't have the nav pro, just the normal unit with Dynaudio. Have you tried a different SD card and/or checked that you have it formatted correctly etc etc? There is a page or 2 about SD cards and compatibility in the media manual iirc. Quote Link to comment Share on other sites More sharing options...
hazbot Posted May 20, 2017 Report Share Posted May 20, 2017 6 minutes ago, P-P-P-PirateGolf_ARRR! said: I use a 32gb SD card in mine with MP3's and the only time it "forgets" is if the SD card gets removed from it's slot. Otherwise, it always starts exactly where it was when it was switched off. I don't have the nav pro, just the normal unit with Dynaudio. I have the same setup and mine works just the same as this. OP the behaviour of your unit sounds abnormal ... (and annoying!) Quote Link to comment Share on other sites More sharing options...
thanksabunch Posted May 20, 2017 Author Report Share Posted May 20, 2017 Interesting wonder what can be wrong with mine then! im using a 32gb sandisk card and definitely formatted it before use etc Also the problem seems a little sporadic as sometimes it does carry on playing where it left off but more often than not it will go back to beginning all album artwork is there correctly too! Quote Link to comment Share on other sites More sharing options...
DUB Posted May 20, 2017 Report Share Posted May 20, 2017 26 minutes ago, P-P-P-PirateGolf_ARRR! said: I use a 32gb SD card in mine with MP3's and the only time it "forgets" is if the SD card gets removed from it's slot. Otherwise, it always starts exactly where it was when it was switched off. I don't have the nav pro, just the normal unit with Dynaudio. Have you tried a different SD card and/or checked that you have it formatted correctly etc etc? There is a page or 2 about SD cards and compatibility in the media manual iirc. Thanks will see what size the SD card is. I will order a 32GB one as I suspect mine is larger. What brand is yours? Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted May 20, 2017 Report Share Posted May 20, 2017 there are a few strange things on the unit the could be improved ,the one that winds me up is when you make or receive a phone call ( use phone a lot work) it always stays on the phone screen never returns to where you was on the main screen and the centre display ,i find i am constantly plying with the steering wheel controls to put back speed or oil temp after every call made or back to nav on man screen ,seems a really simple issue .my last car (ford )was back to before the call but not this unit . Quote Link to comment Share on other sites More sharing options...
TechieAli Posted May 20, 2017 Report Share Posted May 20, 2017 Try ejecting the sd card safely using the menus then do the factory reset on the media part of the system. The re-insert the memory card. Use the safely remove options in the menus otherwise the media cataloguing gets confused. DUB and LouCyffer 2 Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted May 20, 2017 Report Share Posted May 20, 2017 I was going to post up a thread on this. My Discover Pro will happily play any music on my 32Gb SanDisk SD card, but once I turn off the car, the unit forgets the card. It shows no card is available, until I eject & reinsert it, upon which it starts up with the first track on the first album. I'll take this up with my dealer next week & see what I can find out. In the meantime, any ideas/fixes gratefully received. I'll definitely try your idea, Ali thanks Quote Link to comment Share on other sites More sharing options...
PhilC22 Posted May 20, 2017 Report Share Posted May 20, 2017 2 hours ago, Matthewsimone said: Interesting wonder what can be wrong with mine then! im using a 32gb sandisk card and definitely formatted it before use etc Also the problem seems a little sporadic as sometimes it does carry on playing where it left off but more often than not it will go back to beginning all album artwork is there correctly too! I have the same card in a 2013 golf with discover nav and it has always worked fine (resumes where it left off). Maybe a hard reset will do the trick as others have suggested. Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted May 20, 2017 Report Share Posted May 20, 2017 3 hours ago, DUB said: Thanks will see what size the SD card is. I will order a 32GB one as I suspect mine is larger. What brand is yours? The unit will support the following SD card types and capacities: SD up to 2GB SDHC up to 32GB SDXC up to 256GB The unit will support FAT16, FAT32, ExFAT and NTFS formats. Personally, I use Sandisk as they have (so far) always been reliable and fast, but, I should imagine most reputable brands will be perfectly suited. Quote Link to comment Share on other sites More sharing options...
DUB Posted May 20, 2017 Report Share Posted May 20, 2017 21 minutes ago, P-P-P-PirateGolf_ARRR! said: The unit will support the following SD card types and capacities: SD up to 2GB SDHC up to 32GB SDXC up to 256GB The unit will support FAT16, FAT32, ExFAT and NTFS formats. Personally, I use Sandisk as they have (so far) always been reliable and fast, but, I should imagine most reputable brands will be perfectly suited. Yeah thanks but obviously not all are suited as mine doesn't work!! It must be formatted correctly as it works for a few days and then decides it cannot read it anymore. Possibly a failing on my unit rather than the SD card to be fair. Sandisk SDXC 64GB. I'm using an ipod now balls to the SD card!! 😄 Quote Link to comment Share on other sites More sharing options...
