Privatedoc Posted June 26, 2017 Report Share Posted June 26, 2017 As you may know I have my R landing in 3 or so weeks and have bought obd11 in readiness....I've tried it out on my polo (dial sweep) and it works well even with the pish kindle fire 7 I hope to do the fan-lights on auto mod but wonder what else you peeps would recomend, also fancy a chirp on lock and unlock what elso would you suggest?? Thanks folks ps anyone near me feel free to try it out it if you want, I've loads of credits Quote Link to comment Share on other sites More sharing options...
thecrofter Posted June 26, 2017 Report Share Posted June 26, 2017 I'd go chirp on lock only. Reason being you know when you've heard it it's definitely locked. Not misheard if you've accidentally unlocked. You may also have a tendency to unlock from afar thereby giving advance notice of your car being unlocked etc. Me being paranoid perhaps but worth considering.Sent from my iPhone using Tapatalk Privatedoc 1 Quote Link to comment Share on other sites More sharing options...
mickR Posted June 26, 2017 Report Share Posted June 26, 2017 Extended brake lights, reverse lights increased to 100%, DRLs to 100% when lights on, turbo boost increase to 450BHP (joking). These mods may/may not apply to MK7.5? Privatedoc 1 Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted June 26, 2017 Author Report Share Posted June 26, 2017 sounds good, also the turn boost up ha ha ...if only it was that easy ! wonder if the 7.5 will mod the same way as the 7 or if I'll be back to the dealer saying I broke it ! :-) Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 26, 2017 Report Share Posted June 26, 2017 Take your pick really. Always try a few out and if non too keen, revert back to normal. I did the following and happy with all:Chirp on lock/unlock - long codedStop/start disable - long codedHeadlamp washers off - long coded Enable fan level display on auto - appReverse lights full brightness - long codedComing home lights long codedDRL 100% with headlights - long codedFull (5) brake lights - long code Refuel amount 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
MC71 Posted June 26, 2017 Report Share Posted June 26, 2017 I find the Coming home lights is a must have....great little tweek. Still NO idea why it's not enabled as standard as it used to be with my previous generation Golfs. Def Start/stop too, alarm chirp, DRLs and disable that Soundaktor. Full brake light is a must too. Quote Link to comment Share on other sites More sharing options...
mickR Posted June 26, 2017 Report Share Posted June 26, 2017 I'm confused, coming home lights standard on mine and duration can be adjusted as standard???😕 Obbzi 1 Quote Link to comment Share on other sites More sharing options...
Lee63 Posted June 26, 2017 Report Share Posted June 26, 2017 Was thinking the same mick, mine has coming home lights and i can adjust the time on in the car info system. Sent from my iPhone using Tapatalk Obbzi 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 26, 2017 Report Share Posted June 26, 2017 2 hours ago, mickR said: I'm confused, coming home lights standard on mine and duration can be adjusted as standard??? 32 minutes ago, Lee63 said: Was thinking the same mick, mine has coming home lights and i can adjust the time on in the car info system. Sent from my iPhone using Tapatalk Coming home lights are standard (as is the time option setting in the menus), but unless it's changed with the facelift, you have to use the indicator stalk to activate them each time. With the obdeleven adaptation you don't need to do this, they activate automatically on ignition off, exiting the car. mickR 1 Quote Link to comment Share on other sites More sharing options...
mickR Posted June 26, 2017 Report Share Posted June 26, 2017 Ah I see now (get it lol), thanks for shedding light on that Rebecca👍😀 Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 26, 2017 Report Share Posted June 26, 2017 4 minutes ago, mickR said: Ah I see now (get it lol), thanks for shedding light on that Rebecca You've seen the light Mick. 😂 Its one one of my favourite obdeleven mods, after disabling stop/start and headlight washers which I couldn't do quick enough, lol! Quote Link to comment Share on other sites More sharing options...
