pridders Posted August 4, 2017 Report Share Posted August 4, 2017 Hey All, I have ordered my new 7.5 R and included the Dynaudio Excite Soundpack as an option but did not opt for the Nav Pro. Good Move? Bad Move? I don't really know, The Nav Pro seemed expensive for what it was and thought the Dynaudio Excite Soundpack would make the biggest difference in terms of Audio then opting for both I may be wrong but any thoughts on this from anyone? The main difference i could see was the larger screen and gesture control which for me was not worth over £1k! Was it a good move just opting for Dynaudio Excite Soundpack; is it worth the extra? Lancslad 1 Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted August 4, 2017 Report Share Posted August 4, 2017 Dynaudio is a no brainer, you'd be daft not to as an aftermarket kit of its quality would be 4 figures! I have nav pro and love it but am really pissed off I bought it for google earth and it has been dropped. The voice track / album selection is good and the screen is fabulous, it is not nearly as good value as dynaudio is.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Richard_Nottm Posted August 4, 2017 Report Share Posted August 4, 2017 3 minutes ago, pridders said: Hey All, I have ordered my new 7.5 R and included the Dynaudio Excite Soundpack as an option but did not opt for the Nav Pro. Good Move? Bad Move? I don't really know, The Nav Pro seemed expensive for what it was and thought the Dynaudio Excite Soundpack would make the biggest difference in terms of Audio then opting for both I may be wrong but any thoughts on this from anyone? The main difference i could see was the larger screen and gesture control which for me was not worth over £1k! Was it a good move just opting for Dynaudio Excite Soundpack; is it worth the extra? I have the same setup..standard nav and dynaudio and alls good. Its still a nice screen doing away with most buttons etc. I coudlnt justify the extra to myself either....was never quite sure what i was missing out on but didnt look into too much.knew it would be fine for me..does it have an internal HDD too...? There are two memory card slots on std nav...one for the nav card and the other for music i presume. I stream deezer via bluetooth 99% of the time. dynaudios nice but havent heard the std audio to compare. Privatedoc 1 Quote Link to comment Share on other sites More sharing options...
JaseW Posted August 4, 2017 Report Share Posted August 4, 2017 Standard nav and dynaudio for me. Perfect. Wasn't interested in having the pro nav and definitely don't regret not adding it. Costs Too much for something I wouldn't use anymore than what the standard nav offers. No brainer to spec dynaudio as the doc says it would be 4 figures if you bought aftermarket Sent from my iPhone using Tapatalk Privatedoc 1 Quote Link to comment Share on other sites More sharing options...
Harry8052 Posted August 5, 2017 Report Share Posted August 5, 2017 Same here, I have Dynaudio and standard Nav and I'm really happy with it. The standard Nav is really quick to operate and you get none of the lag you use to get from the RNS510 etc. Apple car play works really well and I have put all my music on a separate sd card, although I very rarely use it as Dezzer via car play works so well. I do get some distortion in the sound at about half volume so I'm not sure if that's a speaker issue or the quality of the music file....... Quote Link to comment Share on other sites More sharing options...
oryxgolfr Posted August 5, 2017 Report Share Posted August 5, 2017 This is good to hear as I am about to order and had the same question. ApplyPlay maps takes a bit of getting used to but is excellent. Quote Link to comment Share on other sites More sharing options...
gazza5 Posted August 7, 2017 Report Share Posted August 7, 2017 wish i had dynaudio, mate as it in his gti (mk5) - but as mines a lease the standard isn't bad now its broken in a bit - bit tinny for my ears, so turned the treble down a notch. Standard nav screen is very very good, I wouldn't bother with the improved one, although I use google maps as I hate the look of the vw sat nav, looks very old to me - don't like the colour scheme of it. Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted August 9, 2017 Report Share Posted August 9, 2017 I've just ordered the very same Dynaudio and standard nav. The dealer struggled to tell me what you get for the extra £1,350 I think it is so I asked a very knowledgeable friend who told me :- Larger screen 9.2" vs 8" 64Gb SSD hard drive Voice commands Gesture control DVD drive 3D mapping Maps on both nav screen and virtual cockpit screen Still didn't swing it - I added Prets instead LoL !! Quote Link to comment Share on other sites More sharing options...
bigp2 Posted August 9, 2017 Report Share Posted August 9, 2017 The standard nav seems good enough for me. Unless I don't know what I'm missing... Quote Link to comment Share on other sites More sharing options...
David Davies Posted August 9, 2017 Report Share Posted August 9, 2017 I Have Dynaudio, and Nav pro. Couldn't tell you the difference over standard it was on the car when I bought it. Voice command is pretty Good. Gesture control is rubbish. Sat Nav works perfectly for the odd time it's used, Pro screen is set up on the Radio Stations, and the Nav on in the Virtual Cockpit, Which is pretty cool. I probably wouldn't add it on the options. But if as I did, found a car with it on. It would be a no brainer. Dynaudio, is the first option, Every R owner should Get, Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
