gpf1xxx Posted February 5, 2019 Report Share Posted February 5, 2019 My R is with the dealer tomorrow for the warranty DSG shifter replacement. An all day job. The past few days has seen the 'error' message come on every time I start the car. I will report back on the result of the new parts. Quote Link to comment Share on other sites More sharing options...
vagnum Posted February 6, 2019 Report Share Posted February 6, 2019 This is a common error with the parking switch that’s built inside the selector lever so the whole selector has to be replaced and it’s a very involved job to do. Centre console out to get to the interior bolts holding it to the floor, exhaust and centre tunnel heat shield off to remove the selector from under the car and depending on what selector you have already the superseded part may require the a new selector cable. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gpf1xxx Posted February 6, 2019 Report Share Posted February 6, 2019 On 05/02/2019 at 17:08, gpf1xxx said: My R is with the dealer tomorrow for the warranty DSG shifter replacement. An all day job. The past few days has seen the 'error' message come on every time I start the car. I will report back on the result of the new parts. All fixed...dropped car off at 8.15am and it was ready by 2pm. The reassembly of the DSG console has been done perfectly and the car is back to normal. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted February 6, 2019 Report Share Posted February 6, 2019 All fixed...dropped car off at 8.15am and it was ready by 2pm. The reassembly of the DSG console has been done perfectly and the car is back to normal.Great news!Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
BillTheButcher Posted March 22, 2019 Report Share Posted March 22, 2019 My 7R estate flashed up this error message last weekend. It cleared itself after a few seconds but then reappeared the next time I started it. Again, the message cleared itself a short while later. It only appeared if I tried to select M; if I left it in D or S it was completely fine. I took it in yesterday to have it looked at. Apparently it's the F319 switch that's faulty. They're replacing the whole selector assembly today. The courtesy car they've given me is an entry-level Up. It's like driving a shopping trolley. The front of the car is so short that I keep parking it about three feet away from the end of parking spaces. Quote Link to comment Share on other sites More sharing options...
Notstig Posted May 11, 2019 Report Share Posted May 11, 2019 Grr.. mines gone too, booked in on Friday, Inchscape Swindon seem to know about the fault, even though the car drives fine, get it sorted while VW are paying Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dunc Posted September 8, 2019 Report Share Posted September 8, 2019 I recently purchased a used MK 7 Golf 2.0 TDI with a DSG autobox, within a week I began to get the dreaded message, the fault did not show an the car status nor was it logged on VW Connect app. the Golf was returned to Inchcape who diagnosed the full shift assembly would need to be replaced under warranty, I hope to have the Golf back tomorrow. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 8, 2019 Report Share Posted September 8, 2019 58 minutes ago, Dunc said: I recently purchased a used MK 7 Golf 2.0 TDI with a DSG autobox, within a week I began to get the dreaded message, the fault did not show an the car status nor was it logged on VW Connect app. the Golf was returned to Inchcape who diagnosed the full shift assembly would need to be replaced under warranty, I hope to have the Golf back tomorrow. Unfortunately this is a common fault. At least the fix is straight forward and you should be back to happy motoring quickly. Quote Link to comment Share on other sites More sharing options...
Dunc Posted September 8, 2019 Report Share Posted September 8, 2019 Hopefully this will not be a reoccurring problem, I have previously had two Golfs and a Sirrocco all with DSG autobox’s and never any problems...fingers crossed🤞🤞 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 8, 2019 Report Share Posted September 8, 2019 Hopefully this will not be a reoccurring problem, I have previously had two Golfs and a Sirrocco all with DSG autobox’s and never any problems...fingers crossedI think it's just a one off issue usually with the mech unit so not the actual gearbox itself just the hardware/software that controls itSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 8, 2019 Report Share Posted September 8, 2019 4 hours ago, SpursMadDave said: I think it's just a one off issue usually with the mech unit so not the actual gearbox itself just the hardware/software that controls it AFAIK this error is usually caused by a faulty sensor in the gear lever assembly, so not in the DSG, nor in the mechatronic unit that controls the DSG. Obviously there was a batch of sensors that had a high failure rate, VW know about it so they are replacing them without any drama. Replacing the gear lever assembly seems to fix it for pretty well everyone (there is an instruction in the TSB to look at the wiring loom first, but replacing the gear lever is much more common). LouCyffer, SpursMadDave and Count Drunkula 1 2 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 8, 2019 Report Share Posted September 8, 2019 AFAIK this error is usually caused by a faulty sensor in the gear lever assembly, so not in the DSG, nor in the mechatronic unit that controls the DSG. Obviously there was a batch of sensors that had a high failure rate, VW know about it so they are replacing them without any drama. Replacing the gear lever assembly seems to fix it for pretty well everyone (there is an instruction in the TSB to look at the wiring loom first, but replacing the gear lever is much more common).I'm sure I've read of owners having to get their mechatronic unit replaced though may be a different error, luckily not seen it in either of my RsSounds logical as the car is saying put the gearbox in P when it already is so the sensor is fubarSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 9, 2019 Report Share Posted September 9, 2019 The reports I've read where the mechatronic had to be replaced mostly seemed to have problems with gears not being selected and/or clutches not engaging. Quote Link to comment Share on other sites More sharing options...
ftr1873 Posted September 10, 2019 Report Share Posted September 10, 2019 Just had mine fixed, only just out of warranty 🙄. My local dealer spoke to VW and got 100% parts and 50% labour paid. Obviously much appreciated contribution but considering it's not an old car and it's a common fault, still stings a bit. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 10, 2019 Report Share Posted September 10, 2019 Just had mine fixed, only just out of warranty . My local dealer spoke to VW and got 100% parts and 50% labour paid. Obviously much appreciated contribution but considering it's not an old car and it's a common fault, still stings a bit. How far out of warranty were you?Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
