dazie00 Posted July 26, 2018 Report Share Posted July 26, 2018 Hi guys, anybody know how to get my pano roof fully opening from the remote , with VCDS, have seen guys doing this with OBD and know it's in coding somewhere , all windows are opening and roof is going on tilt at the moment so convenience opening is working ??? thanks Daz Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 26, 2018 Report Share Posted July 26, 2018 Better luck than me, I have turned on all the settings via OBDEleven and have the option in the menu to open all but nothing happens... Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
dazie00 Posted July 26, 2018 Author Report Share Posted July 26, 2018 5 minutes ago, SpursMadDave said: Better luck than me, I have turned on all the settings via OBDEleven and have the option in the menu to open all but nothing happens... Sent from my SM-G935F using Tapatalk Have you ticked the box in car set up , opening/closing, all windows?? Does seem to be a bit hit and miss . Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 26, 2018 Report Share Posted July 26, 2018 Have you ticked the box in car set up , opening/closing, all windows?? Does seem to be a bit hit and miss .Yep it is ticked... Went in again to check settings and all seem correct but still nothing... That's what I checked below maybe it is out of date?Everything checks out as below so very strange Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Count Drunkula Posted July 26, 2018 Report Share Posted July 26, 2018 With mine once it reaches the tilt position and stops releasing the button on the fob and holding it again opens the roof fully Quote Link to comment Share on other sites More sharing options...
dazie00 Posted July 26, 2018 Author Report Share Posted July 26, 2018 1 minute ago, Count Drunkula said: With mine once it reaches the tilt position and stops releasing the button on the fob and holding it again opens the roof fully That i will now try , thanks Didn't work for me , may not be doing it quite right Have found this but not sure what channel to find it, not in central electrics, long coding ???? Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 27, 2018 Report Share Posted July 27, 2018 Hmmm maybe just doesn't work with my car, I had credits so I used an app and still doesn't work... other stuff I long coded works fine like fan lights in auto etc so I'm not doing anything wrong just no opening and closing via the remote for me Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
mortys Posted July 27, 2018 Report Share Posted July 27, 2018 9 hours ago, dazie00 said: That i will now try , thanks Didn't work for me , may not be doing it quite right Have found this but not sure what channel to find it, not in central electrics, long coding ???? Seem like you need to tick off "Bit 0" - Comfort opening for sliding roof active Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 27, 2018 Report Share Posted July 27, 2018 Windows and buttons all working fine but when I did a scan I found this, tried googling the code and got nothing but maybe the reason this isn't working? Will get it checked out when the car goes in for a service next monthSent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
dazie00 Posted July 27, 2018 Author Report Share Posted July 27, 2018 1 hour ago, mortys said: Seem like you need to tick off "Bit 0" - Comfort opening for sliding roof active Thats what i think but cant find how to get to this coding page , !!!!!!!!! @dv52 Don , can you help me out here , do i need to go security access and will that give me more options possibly ? Thanks Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 27, 2018 Report Share Posted July 27, 2018 9 minutes ago, dazie00 said: Thats what i think but cant find how to get to this coding page , !!!!!!!!! @dv52 Don , can you help me out here , do i need to go security access and will that give me more options possibly ? Thanks 9 Central Electrics Security Code is 31347 You can either go into Adaptions and change the options below or go to Long Coding and it should show the bytes as in your photos. When you get Long Coding open you have to click on the 4th box from the left to see the sunroof boxes. 9- Central electronics 10- Adaptations 2-Access control 2- comfort opening > active 3- access control 3- comfort closing > active 7- access control 2- funk komfort oeffnen > active 6- access control 2- funk komfort schilessen > active 27 access control 2- Menuesteuerung komfortbedienung einstellbar >adjustable Comfort closing sunroof 9 Central Electronics Security code 31347 10 Adaptations ( Channel (10) - Zugangskontrolle 2 - SAD Richtung Komfortöffnen auswählen) or (Access control select comfort opening direction). Select SAD direction convenience opening - channel (10) - Access control 2 Put value on open. (and tilting). If you have keyless you might need to do the following - you may have already done this when activating the comfort access in the first place Kessy 20- access control 2-Kessy komfort schilessen > active markR 1 Quote Link to comment Share on other sites More sharing options...
dazie00 Posted July 27, 2018 Author Report Share Posted July 27, 2018 1 minute ago, ashleyman said: 9 Central Electrics Security Code is 31347 You can either go into Adaptions and change the options below or go to Long Coding and it should show the bytes as in your photos. When you get Long Coding open you have to click on the 4th box from the left to see the sunroof boxes. 9- Central electronics 10- Adaptations 2-Access control 2- comfort opening > active 3- access control 3- comfort closing > active 7- access control 2- funk komfort oeffnen > active 6- access control 2- funk komfort schilessen > active 27 access control 2- Menuesteuerung komfortbedienung einstellbar >adjustable Comfort closing sunroof 9 Central Electronics Security code 31347 10 Adaptations ( Channel (10) - Zugangskontrolle 2 - SAD Richtung Komfortöffnen auswählen) or (Access control select comfort opening direction). Select SAD direction convenience opening - channel (10) - Access control 2 Put value on open. (and tilting). If you have keyless you might need to do the following - you may have already done this when activating the comfort access in the first place Kessy 20- access control 2-Kessy komfort schilessen > active Thanks Ash , i'll give that a go 👍 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 27, 2018 Report Share Posted July 27, 2018 Just now, dazie00 said: Thanks Ash , i'll give that a go Let me know if it doesn't work and I'll try and find the threads I referenced when I coded it into my R. dazie00 1 Quote Link to comment Share on other sites More sharing options...
dazie00 Posted July 27, 2018 Author Report Share Posted July 27, 2018 55 minutes ago, ashleyman said: 9 Central Electrics Security Code is 31347 You can either go into Adaptions and change the options below or go to Long Coding and it should show the bytes as in your photos. When you get Long Coding open you have to click on the 4th box from the left to see the sunroof boxes. 9- Central electronics 10- Adaptations 2-Access control 2- comfort opening > active 3- access control 3- comfort closing > active 7- access control 2- funk komfort oeffnen > active 6- access control 2- funk komfort schilessen > active 27 access control 2- Menuesteuerung komfortbedienung einstellbar >adjustable Comfort closing sunroof 9 Central Electronics Security code 31347 10 Adaptations ( Channel (10) - Zugangskontrolle 2 - SAD Richtung Komfortöffnen auswählen) or (Access control select comfort opening direction). Select SAD direction convenience opening - channel (10) - Access control 2 Put value on open. (and tilting). If you have keyless you might need to do the following - you may have already done this when activating the comfort access in the first place Kessy 20- access control 2-Kessy komfort schilessen > active Got it working now , still couldn't find it in long coding Most settings were already correct apart from 3. comfort opening , now active and in comfort closing couldn't find Zugangskontrolle but tapped in SAD rictung and found that which enabled me to change tilt to open All good now it's raining lol !!!!! Thanks ashleyman and Microbe 2 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 27, 2018 Report Share Posted July 27, 2018 8 minutes ago, dazie00 said: Got it working now , still couldn't find it in long coding Most settings were already correct apart from 3. comfort opening , now active and in comfort closing couldn't find Zugangskontrolle but tapped in SAD rictung and found that which enabled me to change tilt to open All good now it's raining lol !!!!! Thanks If it didn't work I was going to suggest changing the tilt option for open. It doesn't help that recent VCDS releases all have English translations when all the guides have the German! Glad you got it working! dazie00 1 Quote Link to comment Share on other sites More sharing options...
