slider09 Posted September 27, 2019 Report Share Posted September 27, 2019 Mine tends to sit around 95-98 degrees under normal driving, however when driving hard it's anywhere from 102 - 112 degrees but quickly comes back down again when driving normally.95-98 degrees is too low, needs to be above 100 degrees to burn off any water / condensation. Have you changed to a non spec oil / any additional oil cooling kits. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
VW17GLF Posted September 27, 2019 Report Share Posted September 27, 2019 5 minutes ago, slider09 said: 95-98 degrees is too low, needs to be above 100 degrees to burn off any water / condensation. Have you changed to a non spec oil / any additional oil cooling kits. Sent from my iPhone using Tapatalk Got MPM oil in, but will be doing an oil change next weekend to VWs own oil. No additional oil cooling kits added, plus I am running at Stage 3 also. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2019 Report Share Posted September 27, 2019 Got MPM oil in, but will be doing an oil change next weekend to VWs own oil. No additional oil cooling kits added, plus I am running at Stage 3 also.Seems stage 3 cars run a bit cooler as seen a few posts mentioning it, I'm sure it's not an issue as long as it gets over 100 degrees at times. I guess being stage 3 you dont driver everywhere in ECO mode and under 2k revs Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
VW17GLF Posted September 27, 2019 Report Share Posted September 27, 2019 57 minutes ago, SpursMadDave said: Seems stage 3 cars run a bit cooler as seen a few posts mentioning it, I'm sure it's not an issue as long as it gets over 100 degrees at times. I guess being stage 3 you dont driver everywhere in ECO mode and under 2k revs Sent from my SM-G950F using Tapatalk I suppose with it being a bigger turbo it isn't in use at full power when driving normally compared to stage 1/2 or even standard. Yeah it does get a thrashing sometimes which gets it over 100 degrees which is always good. Hmm, never in ECO, always in Race ready for the next send! Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 27, 2019 Report Share Posted September 27, 2019 4 hours ago, VW17GLF said: Got MPM oil in, but will be doing an oil change next weekend to VWs own oil. No additional oil cooling kits added, plus I am running at Stage 3 also. I had a vague idea that some ecu tunes had different cooling strategies to the std tune, so maybe they are running the engine oil cooler to avoid overheating the oil when running hard. I have no hard data on this, but I'm pretty sure I read it somewhere. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2019 Report Share Posted September 27, 2019 I suppose with it being a bigger turbo it isn't in use at full power when driving normally compared to stage 1/2 or even standard. Yeah it does get a thrashing sometimes which gets it over 100 degrees which is always good. Hmm, never in ECO, always in Race ready for the next send! Yeah sounds very plausible, I'm sure I've seen others with bigger turbos say the same and it makes perfect sense and nothing to worry about, glad to hear you don't use ECO Sent from my SM-G950F using Tapatalk VW17GLF 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2019 Report Share Posted September 27, 2019 I had a vague idea that some ecu tunes had different cooling strategies to the std tune, so maybe they are running the engine oil cooler to avoid overheating the oil when running hard. I have no hard data on this, but I'm pretty sure I read it somewhere.Yep same here and makes sense when you think about itSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
golf7.5r Posted September 27, 2019 Report Share Posted September 27, 2019 1 hour ago, gregozedobe said: I had a vague idea that some ecu tunes had different cooling strategies to the std tune, so maybe they are running the engine oil cooler to avoid overheating the oil when running hard. I have no hard data on this, but I'm pretty sure I read it somewhere. You can't control the oil cooler afaik. It's probably more about how much boost they run - APR maps run higher boost to get less power than a Unicorn map, and higher boost means higher EGTs which means higher temps, which in turn heats the oil up more. Off-topic but I changed a sensor on a previous car (B5 S4) to turn on a turbo after-run pump at a lower temp. It pumped water around the turbo jacket for around 10 mins after shut-off. Quote Link to comment Share on other sites More sharing options...
r@d00 Posted September 27, 2019 Report Share Posted September 27, 2019 A Stage 3 boost should be much higher than a stock one, so you would also expect higher oil temperatures. I also think you can control the cooling strategy via software to a certain extent... Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 28, 2019 Report Share Posted September 28, 2019 13 hours ago, golf7.5r said: You can't control the oil cooler afaik. I meant running the oil at a cooler temp, which could be done via controlling coolant movement and/or oil movement to the oil cooler (heat exchanger). AFAIK the Golf R has a very sophisticated mechanism for controlling coolant & oil temps (much of it focused on reducing air pollution by getting critical engine components up to optimum operating temps as quickly as possible). In any case I have no direct knowledge of the details of how lower oil temps are achieved. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 28, 2019 Report Share Posted September 28, 2019 I meant running the oil at a cooler temp, which could be done via controlling coolant movement and/or oil movement to the oil cooler (heat exchanger). AFAIK the Golf R has a very sophisticated mechanism for controlling coolant & oil temps (much of it focused on reducing air pollution by getting critical engine components up to optimum operating temps as quickly as possible). In any case I have no direct knowledge of the details of how lower oil temps are achieved.Sophisticated maybe but the coolant system has a couple of very weak links in the thermostat housing and water pumpSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 28, 2019 Report Share Posted September 28, 2019 4 hours ago, SpursMadDave said: Sophisticated maybe but the coolant system has a couple of very weak links in the thermostat housing and water pump Unfortunately very true 😭 Quote Link to comment Share on other sites More sharing options...
