Engine temperature!!
Penta
2 minutes ago, SpursMadDave said:
Around 100 is absolutely normal for the oil temp, water temp around 90, if you have sport dials both will be at around 12 o'clock emoji106.png
Thanks, for your reply very much appreciated. My focus didn't get up to temperature that quick!!. Can only be a good thing I suppose.
17 hours ago, Sequence said:
The engine in our R's is quite unique in that the exhaust manifold is internal within the engine block and is cooled by engine coolant thus allowing for the car to warm up nice a quickly and keeping us toasty on a cold winters morning :P
Yep. VAG found when developing from EA888 Gen2 to Gen3 (latter is what's in our Rs) that a lot of emissions were produced during engine warm-up. So they strove to speed that up as quickly as possible - hence the exhaust manifold being internal and a different coolant control system to get the engines warm ASAP.
Lots of cool changes between Gen2 and 3, but that was the biggest change in my view and the most noticeable (other than more power).
@Penta - don't look just at the gauge on the dash though. Also check your oil temperature in the driver's display or in the Performance screen in the main display before you drive hard. My rule is 80C+ is when I feel comfortable booting it.
The coolant gets to normal operating temp (90C) very quickly (1-3 minutes on mine), but the oil temp takes much longer (but you should wait for the oil to get to at least 80C before working the engine hard).
My oil doesn't take that much longer, I finished work at 6am, got in the car and started up about 5 past then on the drive home I never touched 60mph or over 2k revs so about 8 minutes to easily get to 80C+565efab3abcce4e4cce9b009d0ca3c71.jpg
Out of curiosity - what are people's average oil temps?
So mine usually sits at 106c, but yesterday in traffic and driving in S Manual mode it was 112c. Highest it hit was 115c !
Not sure why it was particularly higher. It's literally just had an oil service about 3 weeks ago. Should I be concerned that VW put the wrong oil in maybe?
So mine was probably within "normal" range I guess. Just surprised me because I wasn't driving hard, but I guess S Manual mode tends to result in higher rev gear changes and in slow moving traffic probably heats the engine up quite a bit.
As long as it came back down a bit once you got moving then I wouldnt be too worried
