Booth11 Posted September 16, 2022 Report Share Posted September 16, 2022 With some valuable help from @dv52 (thank you Don) I’ve coded to enable the chirp on unlock and lock. I did this on my mk7R and wanted it on the mk8 too. Note: This did not require SFD unlock on mine. Here’s the step by step guide: - Pop the bonnet (otherwise it will not write any changes) - Plug in OBDeleven dongle and connect - Go into 09 Central Electrics - Adaptations - Put ZV in search box - Select ZV Quittierungen For chirp on unlock Scroll to Quittierungston_bei_entriegeln (translates as Acknowledgment_beep_on_unlock) Change from Not Active to Active Slide to write change For chirp on lock Scroll to Quittungs_ton_bei_verriegeln (translates as Acknowledgment_tone_when_locking) Change from Not active to Active Slide to write the change To enable the audible confirmation option in the car’s Vehicle Central Locking menu Scroll to Quittungston_hmi_einstellbar (translates as Acknowledgment tone_hmi_adjustable) Change from Not Active to Active Slide to write changes To check it’s in the menu, on the infotainment screen, go to Vehicle - Exterior - Central locking and you’ll see ‘Audible confirmation’ as a new menu item. Tap to make it active. Close up bonnet. And that’s it! Here it is although the sound gets a bit let amongst the mic picking up passing traffic and the folding wing mirror mechanism. Actually sounds louder (in a good way) in the flesh than in video. Excuse the very dirty car. Consequence of hosepipe ban. Now rocking mud brown Estorils. 😢😁 JonnyG, ToRnado_R, Scudgie and 1 other 2 1 1 Quote Link to comment Share on other sites More sharing options...
AHG Posted September 16, 2022 Report Share Posted September 16, 2022 Terrific ! Tomorrow I’m doing it too (maybe today if I get impatient) it’s a terrific option I’ll try to do the chirp as well if I feel it’s enough for my needs I’ll refrain from the ASBO honk 😉 So to summarize: 4 item to tick for chirp (lock, unlock, global, hmi) 2 more for horn (activate, and length) Right ? Edit: I saw your post (that then disappeared) and it seems you didn’t tick the GLOBAL is it unnecessary for the chirp ? Booth11 1 Quote Link to comment Share on other sites More sharing options...
AHG Posted September 16, 2022 Report Share Posted September 16, 2022 Amazing. Thx. You didn’t need to turn on Quittierton Global as well ? so just 3 parameters to be changes to active ? For activation via horn (fit those with no alarm, or that need extra oomph) I’m guessing these two will need to be set as well: I will try to check tomorrow and will update. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Author Report Share Posted September 16, 2022 4 hours ago, AHG said: Terrific ! Tomorrow I’m doing it too (maybe today if I get impatient) it’s a terrific option I’ll try to do the chirp as well if I feel it’s enough for my needs I’ll refrain from the ASBO honk 😉 So to summarize: 4 item to tick for chirp (lock, unlock, global, hmi) 2 more for horn (activate, and length) Right ? Haha, I got impatient too. 😄 Like @8YARWY and for same reasons, I only want a subtle audible sound so the chirp is perfect for me. Does a double chirp on unlock and single chirp on lock. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Author Report Share Posted September 16, 2022 27 minutes ago, AHG said: Amazing. Thx. You didn’t need to turn on Quittierton Global as well ? so just 3 parameters to be changes to active ? For activation via horn (fit those with no alarm, or that need extra oomph) I’m guessing these two will need to be set as well: I will try to check tomorrow and will update. No no need for Quittierton Global to be changed for the chirp. I decided to start out simply, just trying what I thought were the key ones and see if it worked. It did, so yes, just the 3 parameters for the chirp. I’d anticipate for the horn it might need those too but only one way to find out! Good luck with yours. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted September 16, 2022 Report Share Posted September 16, 2022 3 hours ago, Booth11 said: Haha, I got impatient too. Like [mention=18156]8YARWY[/mention] and for same reasons, I only want a subtle audible sound so the chirp is perfect for me. Does a double chirp on unlock and single chirp on lock. It’s subtle isn’t it but I think it’s enough, yours is exactly the same noise as mine Becs. Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Author Report Share Posted September 16, 2022 8 minutes ago, 8YARWY said: It’s subtle isn’t it but I think it’s enough, yours is exactly the same noise as mine Becs. Sent from my iPhone using Tapatalk It’s just right Sean, and just enough to have that audible assurance. Thanks for your help. 😊 Quote Link to comment Share on other sites More sharing options...
AHG Posted September 16, 2022 Report Share Posted September 16, 2022 I managed to activate the chirp Problem: it only chirps on the second time I press to lock Is it the same for you @Booth11 ? Is there a way to make it chirp on the first lock ? Also, the chirp is a bit quiet for me (see video). And it won’t help me find the car in underground parking. So I turned on: - Quittierton_global - Quittungston_ueber_hupe (acknowledgement over horn) But it still chirps happily as a bird and no obnoxious horn is heard P.S. apparently I don’t have: Akustische Quittierungsdauer Einfachhorn (to change the length of the horn/chirp) Booth11 1 Quote Link to comment Share on other sites More sharing options...
AHG Posted September 16, 2022 Report Share Posted September 16, 2022 Does it only chirp on the second time you lock ? For some reason that’s what happens to me Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Author Report Share Posted September 16, 2022 I tested it with key fob and then using keyless entry for both unlock and lock and pretty sure it works just the one press (using key) and the one palm wave for keyless. I’m away from my car for a little while but will check again when I’m next with it. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted September 16, 2022 Report Share Posted September 16, 2022 I tested it with key fob and then using keyless entry for both unlock and lock and pretty sure it works just the one press (using key) and the one palm wave for keyless. I’m away from my car for a little while but will check again when I’m next with it. Same here. One press only and/or touch of the handles (RS3 tho)Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted September 16, 2022 Report Share Posted September 16, 2022 Does it only chirp on the second time you lock ? For some reason that’s what happens to meNope chirp on first lock / unlock / via fob/handle touch. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
AHG Posted September 16, 2022 Report Share Posted September 16, 2022 Maybe it has something to do with: Quittierton beim zweiten ZV ZU Befehl Mine came with it on ACTIVE is yours active as well ? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Author Report Share Posted September 16, 2022 @AHG Back with car now and tried it a number of times. Definitely chirps with a single press with the key fob, and single touch only with keyless entry. This is for lock and unlock. Also works with the ‘unlock on approach’. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Author Report Share Posted September 16, 2022 7 minutes ago, AHG said: Maybe it has something to do with: Quittierton beim zweiten ZV ZU Befehl Mine came with it on ACTIVE is yours active as well ? I’ll check when I’m home near WiFi. Quote Link to comment Share on other sites More sharing options...
