Gudrun's Chronicles
Leo9
Today is the first day of summer in Kernow - yesterday was a good rehearsal and now here's the real thing. At last. This means that my summer wheels (Neuspeed RSe102's 19x8.5" ET45 in Matte Satin Bronze) have gone on with their summer tyres (Goodyear Eagle F1 Asymmetric 3's 235/35R19 91Y) and here are some photos showing the offsets without spacers plus a top view of the repainted (from silvery grey to Night Blue Metallic bodycolour) front VW badge bezel as per Bec's request Sorry about the road dirt, we were fresh back from the trip to the tyrefitters and an evaluations blast detaour on the way home during which we as normal picked up or drove through hefty helpings of field. Compared to 18" Cadiz with 225/40 Michelin CrossClimates the ride is certainly more "jiggly" and larger surface imperfections felt as both harder and louder but the difference is not enough to warrant a switch in DCC settings from Normal to Comfort. Some will be the result of the required higher tyre pressures in any case. Roadholding seems to have gone up a notch too: a road kink regularly taken comfortably at 60 is now just as easy at 65. Promising!
More upgrades to come shortly.  :)
I adore those wheels Leo. Always had a massive soft spot for a bronze wheel, and in satin finish they are just sublime.  Thanks for posting side-on pic of the body coloured bezel, looks perfect. You've really stamped your personality on the car in a very classy, understated way.  A triumph!
  • 2 weeks later...
On 2017-5-18 at 17:47, Leo9 said:
^ Well found!  It isn't the same as mine but I'm sure it will do the job just as well, if not better. You've been quite lucky to escape with dented/bent rad. fins - any one of them could so easily have been a hole instead. I've certainly lost a rad. that way before. I'm really surprised more (any?) manufacturers don't protect their customers' pricey investments better in this area.
Leo, just got the mesh for protection of my rads, how did you attach it to the car?
@ Microbe:
I didn't, the bodyshop did it while the front bumper assy. was off and in pieces for the respraying. I can't see much from the outside but it looks as though they shaped the pieces into an oversized fit, bent the surplus 90 degrees to form a lip all round. and stuck them on with a good black double-sided tape. I suspect a few small black self-tapping screws could have been used instead as I can't see any in "my" installation.
HTH
  • 2 weeks later...
After a busy few days now that the excess heat has gone I'm equipped with 3 more upgrades:
VWR Turbo Elbow - replaces TT inlet pipe which was so fat I felt it placed unacceptable pressure on the brake pipe below it. Even still using the standard hose the major bottleneck should have been removed so I'm happy with that. K&N panel filter previously fitted along with "snow" grate removal as well.
GFB DV+
JB1 tuning box - not as hard a job to fit as feared although reaching some of the release catches in the 1st place was tough.
Had a nice 8-mile run (already warmed-up) with some full-throttle run to get the JB1 working and WOW - acceleration in 3rd now as good as pre-fitting in 2nd, and likewise 4th almost as good as previous 3rd. Road unsuitable to test acceleration in higher gears. Looking forward to a much longer run next week. MPG for that little blast was just under 20 (instead of nearly 30) so it must've been good!  B)
  • 2 weeks later...
Newly returned from the lovely people at AVS Redruth (thanks to Bob for the personal recommendation) where they've installed the last 3 key upgrades in the "make a Golf R more like a Porsche 911" Odyssey.
Eibach Pro Springs - Added for extra "plantedness". They only reduce the already-lowered-by-factory R by an extra 5mm and 10mm F & R so the difference, and the resulting feeling, is in the "small but significant" rather than the "night and day" category but that's fine for me - I live amid miles of uneven country lanes that have growing green stuff in the middle so big lowering was highly undesirable anyway - and the ride is indistinguishable from OEM (just what was wanted) while the favourite long off-camber curve is now more secure and can be taken 10% faster in great security with no apparent "topple" of the outside front wheel. Result!
Forge Intercooler - No noticeable results or effect whatsoever, but it's been fitted for a modest 25% increase in capacity as a future-proofing move with possible long-distance hot-weather autobahn-storming in mind - not to mention enhanced ECU tuning one day - so that's fine. Easy-as-pie direct fit, reportedly.
BCS Powervalve Catted Downpipe with Titanium heatwrap - Fantastic! Troublesome-as-usual removal of badly-designed OEM pipe (one cumbersome piece with the Cat in the wrong place adding heat in the engine compartment) but the BCS 3-parter fitted a dream thanks to a bit of help from Nige (it was the 1st one AVS had done, though they tell me it won't be the last now they know how good it is). Lovely deep throaty growl on acceleration but no added noise when in cruise - ideal! Also markedly better engine breathing and pick-up/response
Best £733 I've spent on the car and one of the top 3upgrades - JB1 and DTUK Pedalbox being the others (at less cost but similar value for money). Recommended!
In conjunction with the JB1, Pedalbox, Intake, Filter and other assorted mods we're just about perfect. For now at least!  :)
  • 3 weeks later...
Thanks Bec. Hard choice as to favourite upgrade but on balance I think the one I could do without the least on the most frequent occasions is......
...the Pedalbox!
August's advanced developments must perforce remain a closely guarded secret but it's reasonable to expect them to occur in the general areas of performance and handling.
To be continued.  ;)
  • 2 weeks later...
Another trip yesterday to AVS Redruth for more upgrades:
034 Motorsport rear Antiroll Bar: Skilfully and rapidly installed by the experienced James with no bother on the chosen softer of the 2 available settings: 37% stiffer than OEM seemed enough to start with as there are no plans to upgrade the front bar - the aim is more pointability/less understeer - and it leaves the extra-stiffness setting to go to in future if needs must. Too much holiday traffic to properly assess the level of improvement as yet so a report will have to wait.
Revo Lower Torque (dogbone) Mount: Complete replacement of the OEM unit, as opposed to the gap-filling polymer or aluminium alternatives more widely publicised. Immediate improvement felt in driveline "shunt" with some but very little increase in NVH. Perceived (but maybe placebo) improvement in "feel" of what the front end's doing wrt interaction with road surfaces. Time and mileage will clarify that.
4-wheel laser/computer alignment: at Tyrefinder Truro on the way home as recommended by AVS a month after the Eibach Pro springs were fitted to allow for settlement. Whether as a result of their fitting, or the upgrade to 19" wheels, or the wheel-bump into a stone wall, or a bad factory setup, or a combination of some or all of these, the toe-in in particular was well out on one front wheel (not the banged one) and the opposite rear so there was a bit of "crabbing". Now solved and things noticeably more secure all round.
Good trip with pleasing results. Still more to come though!
James did a great job with my turbo muffler delete too - and as I have said elsewhere another guy refilled my washer fluid (I had the warning on the dash) FOC. I had said nothing about this. I like these guys more and more...explains why they are so mega-busy...
