Mk7.5 "Apps"
Managh
Hi,
Little question, with the standard head unit on a mk7.5, do you have any "apps" (spotify etc) which are built in?
I know with new bmw's for example the app is built in to the car so you dont need to plug your phone in. Is this the case with the 7.5 R or does it work through Android/Apple car play?
Hi,
CarPlay / Android for Apps on the new pro, not too many to choose from either.
You’ll need to plug in if you’ve an iPhone
With Android you can use mirror link.
16 minutes ago, JoeyJoeJo said:
Very underwhelming yes.
Gave up trying to get mirrorlink working.
I havent tried MirrorLink, but whats the advantage of it (over android auto) anyway? The discover media manual (Mirrorlink checklist) says that the mobile device must be connected to the infotainment system via usb, with no mention of bluetooth. I just use android auto (for spotify, mainly), which works ok, but I often pull way having forgotten to plug the damn phone in. Bit of a pain tbh.
I am struggling to see the point of it can't work out what it gives me that the car doesn't already do, and you lose the 2nd phone connection.
i think the tech in the BMW worked better, faster and was more seamless. The sat nav was certainly much better. The VW tech looks nice but a bit clunky,
8 hours ago, Golfr7.5 said:
Does this come standard on the 7.5?
I've got std unit, android auto, carplay, mirrorlink all available as std.
Also car-net which I don't fully understand yet and will be a subscription service after 3y,
All seems a bit incoherent, I can do phone and audio via bluetooth, phone, audio and apps via cable with mirrolink and android auto, but need to make a hotspot and connect via wifi for car-net features.
Probably 90% due to unfamiliarity having only had it a week!
I think you've got it right. It's not well thought out.
Car net does require you to set up a wireless hotspot connection, and you need to do this each time you turn the car on. At least from an iPhone you cannot set it to connect automatically, though I think this is an Apple issue. It's disappointing that car net does not work via the USB or be integrated with Car Play.
The most useful feature of car net is that it feeds live accurate traffic info to the VW sat nav. If you're using a phone based sat nav there's no benefit in using car net as far as I can see.
Thanks for the traffic tip. Glad its not just me on connection front i want to be able to get in the car and not faff about connecting to hotspots and searching through menus for the address. . I like the ability to send the address to the car worked well on BMW but it is far easier to just enter it in to the sat nav in VW system.  BMW made use of the installed sim card not sure how the VW communicates ( assume its the same) but it certainly seems limited in what it allows access to it.
Still early days for me and still getting used to the menus / how the features work, so I am sure it will improve as i became familiar with it
Yep I miss BMW's send to car function from iPad / mobile and the Conceirge service of just getting them to update the Sat Nav with directions.
On 12/09/2017 at 18:42, Gavras said:
It's a bit dire really.
if you are lucky you have IOS, if not welcome to Android.
with Apple you get a nice colour screen and Apple Music, with Android it's like 1950's East Berlin.
I plug my Android phone (Samsung S7) into the USB dock every time I get in the car and find android auto to be excellent and looks good, easy to navigate and straightforward to use. Plus Google assistant actually works  and is useful compared to Siri. With Waze now working on Android auto it's got even better.
It's also very easy with an Android phone to have your mobile hot-spot switch on or off for use in the car automatically or even manually, this then enables the carnet functions.
12 hours ago, veneeringman said:
I’ve used the Car-Net app to send a destination to the car several times now with no issues. emoji4.png
I agree with veneeringman that online route planning is fairly easy and can then be sent to the car via carnet, either with your car connected  to your home network, if where it is parked is within range or via a mobile hot-spot on the phone.
Personally I much prefer the Android option for in car navigation and music streaming. Although the VW voice controls for the infotainment is pretty good.
