Delta Posted January 16, 2018 Report Share Posted January 16, 2018 HI all, I just need to conform I have a Milltek cat back at the moment, I have ordered a Milltek down pipe and high flow cat (200 cell) will this show up an engine check light at all? I have a JB4 as well. ย thanks all ๐ Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted January 17, 2018 Report Share Posted January 17, 2018 I think youโll get more answersย if you post this inย the Modifying sectionย ๐ Quote Link to comment Share on other sites More sharing options...
marshy Posted January 17, 2018 Report Share Posted January 17, 2018 Since Milltek has the cat up at the turbo like the original one you might be lucky.Think if it was me Iโd be fitting an o2 spacer at time of fitting which should reduce the risk of the light coming on even more. Quote Link to comment Share on other sites More sharing options...
Delta Posted January 17, 2018 Author Report Share Posted January 17, 2018 Ops sorry wrong section thanks LouCyffer. LouCyffer 1 Quote Link to comment Share on other sites More sharing options...
Delta Posted January 17, 2018 Author Report Share Posted January 17, 2018 Cool I will have a search for one Marshy thank you ๐ Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 19, 2018 Report Share Posted January 19, 2018 If I read correctly doesn't the JB4 have the ability to 'block' the light should it detectย this error ? Quote Link to comment Share on other sites More sharing options...
JohnRRR Posted January 19, 2018 Report Share Posted January 19, 2018 Somebody with VCDS should be able to code any error lights off the dash. Quote Link to comment Share on other sites More sharing options...
S3 Turbo Posted January 19, 2018 Report Share Posted January 19, 2018 On 1/16/2018 at 22:17, Delta said: HI all, I just need to conform I have a Milltek cat back at the moment, I have ordered a Milltek down pipe and high flow cat (200 cell) will this show up an engine check light at all? I have a JB4 as well. ย thanks all ย Can attest that it lights like a christmas tree. At least now during winter. ย With Jb4 you can set Future Use D = 90 to get auto clear which works brilliantly. ย Performance wise it is great, fuel trims increased quite a bit using custom map 6.ย ๐ ย Off topic, @Rob2k68, guess you have 'betrayed' Audi and gotten an R? ย ย Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
GrayMK7R Posted January 19, 2018 Report Share Posted January 19, 2018 10 hours ago, JohnRRR said: Somebody with VCDS should be able to code any error lights off the dash. ย The lambda sensor has to be coded out in the ECU map, unfortunately VCDS cannot do thisย Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 22, 2018 Report Share Posted January 22, 2018 On โ19โ/โ01โ/โ2018 at 20:14, S3 Turbo said: ย Off topic, @Rob2k68, guess you have 'betrayed' Audi and gotten an R? ย ย ย Hello mate, yes indeed only quite recently though last November hence the reduced postsย over at ASNย ๐ฌ ย Hope you're keeping well and car is good ? Quote Link to comment Share on other sites More sharing options...
S3 Turbo Posted January 22, 2018 Report Share Posted January 22, 2018 6 hours ago, Rob2k68 said: ย Hello mate, yes indeed only quite recently though last November hence the reduced postsย over at ASNย ย Hope you're keeping well and car is good ? ย Yes we both are fine thank you. ย Reading the modding section here regularly,ย more action than in the ASN S3 section... ย I get the impression from posts here that you didn't bring the mods over to the new car? (IC for sale? ๐) ย Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 22, 2018 Report Share Posted January 22, 2018 18 minutes ago, S3 Turbo said: ย Yes we both are fine thank you. ย Reading the modding section here regularly,ย more action than in the ASN S3 section... ย I get the impression from posts here that you didn't bring the mods over to the new car? (IC for sale? ) ย ย Yeah some good informative stuff on here - seems to be a larger modding scene than the four circles. ย No mate sorry, left the big stuff on so intercooler, brakes and suspension all went with the carย ๐ S3 Turbo 1 Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted January 22, 2018 Report Share Posted January 22, 2018 30 minutes ago, Rob2k68 said: ย Yeah some good informative stuff on here - seems to be a larger modding scene than the four circles. ย No mate sorry, left the big stuff on so intercooler, brakes and suspension all went with the carย ย Sounds familiar... I come over from the Macan owners club and theyโre idea of modding is the detailing section ๐ณ modding being a massive swear word with those guys ๐๐ ย Rob2k68 and S3 Turbo 2 Quote Link to comment Share on other sites More sharing options...
