Bend Lighting (AFS) Error
lonions
So on the way home from work tonight I had the (AFS) Error come up on my R. I noticed as well once this come up the cornering lights did not work anymore on either side when turning left or right.
Has anyone had this issue before and is it a relatively/cheap easy fix?
On 15/02/2018 at 22:25, banana_man said:
This has happened to mine tonight and I've just ordered the Philips 12972XV+S2.
I'm assuming it's easy to change these bulbs (not done 'em before)?
Watch me accidentally change the wrong ones!
Really easy fitting job:
Pop the bonnet open, lean over and remove the round black quick release cover cap by hand.  To release cap, turn it 1/8th turn clockwise, (if looking front of bonnet towards windcreen) at the back of the headlights, reach your fingers in and press down on the existing light unit and gently pull until the bulb and connector till they are free, then remove (pull) the standard bulb from the connector, push the replacement bulb into the connector, making sure the little double pronged tab (on the circular metal part of the bulb) is at the top, then seat the light back into its housing, and fit the black cover cap back on (turn 1/8th turn anti-clockwise, again if looking towards windscreen). It's a bit tight on the driver's side due to the windscreen washer bottle but still quite easy to access.
  • 9 months later...
