Peth Posted March 9, 2018 Report Share Posted March 9, 2018 Three factors to consider are the cat dia, the cells per square inch and the cat position, all of which influence performance. We place the cat as far away from the turbo as possible which will not allow the lambda lead to reach the rear of the cat. To overcome this we insert a miniature 200 cell cat into the secondary lambda boss to fool the ecu. Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted March 12, 2018 Report Share Posted March 12, 2018 On 09/03/2018 at 11:32, nige bcs said: Catalytic Converter D Direct quote off their site ;-) APR’s engineers specified a high-quality and high-flow GESI metal 300-cell catalyst ideal for forced induction application. During dyno testing, the 100mm x 100mm design showed no measurable loss in power thanks to the catalyst’s design. Internally the catalytic converter feature a proprietary wash coat that helps to reduce emissions and smell common on cat-less setups. The low-profile catalyst features a fully captured substrate brick, which is furnace braised to the outer mantle and physically captured by the diffuser cones preventing rattling, rotation, and damage to the substrate. Subsequently, a byproduct of running the catalyst is a reduction in noise, making the system as a whole more pleasing to the ear. Isn't the quoted CELL value a figure per square inch so that overall size of the sport cat comes into play therefore a 300 Cell x 100mm length is less restrictive than a 200 Cell x 200mm length ? Also, the APR quote doesn't say what they were comparing it against - a catless DP ? I'm no APR fan boy just trying to understand this better. Jon R306 1 Quote Link to comment Share on other sites More sharing options...
nige bcs Posted March 12, 2018 Report Share Posted March 12, 2018 1 hour ago, Rob2k68 said: Isn't the quoted CELL value a figure per square inch so that overall size of the sport cat comes into play therefore a 300 Cell x 100mm length is less restrictive than a 200 Cell x 200mm length ? Also, the APR quote doesn't say what they were comparing it against - a catless DP ? I'm no APR fan boy just trying to understand this better. The APR cat is 100mm in dia and 100mm in length 300cpsi... We use a monolith that is 125mm dia by 125mm in length with a choice of 100 or 200 cpsi Cheers Nige Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted March 12, 2018 Report Share Posted March 12, 2018 The APR cat is 100mm in dia and 100mm in length 300cpsi... We use a monolith that is 125mm dia by 125mm in length with a choice of 100 or 200 cpsi Cheers NigePerfect ! - thanks Nige.Good to have the technical data behind these. 100cpsi is the clear winner for flow but probably not a lot in it between 300cpsi and 191 cubic inch volume and 200cpsi and 374 cubic inches.Sent from my iPhone using Tapatalk Pro Jon R306 and nige bcs 2 Quote Link to comment Share on other sites More sharing options...
Msportman Posted March 12, 2018 Report Share Posted March 12, 2018 Well the APR DP works well on my Stage 2 car and is well made. I like the look of the BCS system to Finnish it off though. Jon R306 and nige bcs 2 Quote Link to comment Share on other sites More sharing options...
golf7.5r Posted April 2, 2018 Report Share Posted April 2, 2018 On 3/2/2018 at 06:48, Rob2k68 said: Had the Milltek 200 cell on my stage 2 S3 which was the perfect amount of increased rasp for me - not any louder just a different tone. They've since improved it by adding a cast section to it for better air flow and I believe it's a bit cheaper. If I was doing this again I'd go Scorpion as the cat is located further down closer to the joint for the res rather than immediately out of the turbo. BCS also does this and looks quality but I'm not a fan of how the wrap looks. Did you get the full Milltek system as their website specifically states that you can't mate it to the OEM system (I'm only looking for a DP at this stage)? Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted April 2, 2018 Report Share Posted April 2, 2018 6 hours ago, golf7.5r said: Did you get the full Milltek system as their website specifically states that you can't mate it to the OEM system (I'm only looking for a DP at this stage)? No - just the DP (older non cast version) which came in two pieces the rear section tapered down to fit the original system. This was 18 months or so ago so things may have changed . golf7.5r 1 Quote Link to comment Share on other sites More sharing options...
vax Posted April 2, 2018 Report Share Posted April 2, 2018 Where to buy the 100cells bcs dp…? I can't see it in the website. Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted April 3, 2018 Report Share Posted April 3, 2018 20 hours ago, golf7.5r said: Did you get the full Milltek system as their website specifically states that you can't mate it to the OEM system (I'm only looking for a DP at this stage)? I've just checked their website and they have quite a few downpipes that mate to the OE exhaust, there's de-cat, sport cat, cast and EC-approved options (you'll pay more for the EC approval). Cast with sport cat to OE pipe is this one :- Large Bore Downpipe and Hi-Flow Sports Cat For Fitment with the OE Exhaust system only and requires a Stage 2 ECU remap System Number: SSXVW349 Consists of: Tailpipe Style: 1 x Cast Large Bore Downpipe 200cell HJS Catalyst {Replaces MSAU616} 1 x Milltek Downpipe-to-OE Cat-back Connecting Pipe {4WD-only} marshy and golf7.5r 1 1 Quote Link to comment Share on other sites More sharing options...
nige bcs Posted April 3, 2018 Report Share Posted April 3, 2018 15 hours ago, vax said: Where to buy the 100cells bcs dp…? I can't see it in the website. Hi valero - I have sent you the pricing ;-) best regards Nige Quote Link to comment Share on other sites More sharing options...
Wicked Posted March 12, 2019 Report Share Posted March 12, 2019 On 03/04/2018 at 14:44, nige bcs said: Hi valero - I have sent you the pricing 😉 best regards Nige HI Nige Can you pm me the price for ur, 200 cell downpipe, heat wrapped and with fitment onto a Milltek cat-back? Tyvm! Quote Link to comment Share on other sites More sharing options...
nige bcs Posted March 13, 2019 Report Share Posted March 13, 2019 17 hours ago, Wicked said: HI Nige Can you pm me the price for ur, 200 cell downpipe, heat wrapped and with fitment onto a Milltek cat-back? Tyvm! no problem - PM'd goodbadboy 1 Quote Link to comment Share on other sites More sharing options...
DaveDeller Posted November 21, 2021 Report Share Posted November 21, 2021 Resurrecting an old thread here, but just wondering if rick/nige could let me know what the power limitations are for stage 3 on the bcs 100 cel (assuming fuel pumps are upgraded too). Does the limitation still sit with the strength of the block or does the downpipe kick in first? I already have the bcs downpipe on the car with Rick's stage 2 and it's brilliant! Just looking at options for stage 3 as you do get used to the power quite quickly 😀 Quote Link to comment Share on other sites More sharing options...
DaveDeller Posted November 22, 2021 Report Share Posted November 22, 2021 @Rick@UnicornMotorDev @nige bcs just realised i would probably need to tag for you to see my previous post! Quote Link to comment Share on other sites More sharing options...
Tangodeltasierra3 Posted May 15, 2023 Report Share Posted May 15, 2023 What's difference from 100 and 200 cel then ? Quote Link to comment Share on other sites More sharing options...
