Servicing help, please
stonefish
My car is coming up to 4 years old and has 27647 miles on the clock.  The Inspection service and oil change service has popped up on the infotainment.  My local dealer has said it needs the 4 year/40 000 mile Major service.
Is the dealer right? The car is on a QI6 servicing regime.
Same age and near same mileage as mine. I had my 4th Service done end August and it was a Major Service.  Mine’s on Fixed (Time & Distance) Service regime.  MOT’d at same time.
Your car should be on a fixed regime service given your mileage. Flexible servicing is usually for cars covering 18k+ miles per year.
If you do significantly less (or more) mileage than average it can be better to ignore the minor/major service classification and look at what needs to be done based on actual time and mileage.
I have an official VW check list "Service Schedule - Passenger Vehicles" which shows what should be done and when.  I use this as a guide, but do some things sooner that it says (eg Replace Haldex fluid - every three years)
Some items need to be done on time eg Brake fluid, Pollen (cabin) filter, Haldex oil (don't forget to clean the filter as well)
Some items are mileage based eg Fuel filter, Air filter, Spark plugs, DSG oil
Other items are time or distance, whichever occurs first eg Engine oil & filter
I do a lot less distance than average, and back when I used to take my vehicles to a VW dealer they were always replacing distance related parts way too soon.  Their excuse was it was part of a "major service" but I was aware that it was only required once the car had done the miles specified for those parts.  That was one of the reasons I switched to a good Indy for servicing.
Thank you to everyone for their help.  I'll let VW do their major service. As I only do 3500-4000 miles a year I'll make sure my car is put on the fixed servicing schedule.
Might well be worth getting the Haldex serviced and cleaned if you haven't had it done before, 4 years of gunk could start to cause you issues...
