DarkArrow Posted December 14, 2020 Report Share Posted December 14, 2020 18 hours ago, starmagsi said: Out of interest, would the Macan 4-pot caliper be a suitable stage 1 level upgrade for somebody not really looking to track their R? With a half-decent disc/pad combo it feels like it should offer a real improvement in stopping ability at the c.£1k level. The factory brake system is more than enough for a stage 1 or 2 on a non-track application. The reason why Stage 1 or more on track starts to overwhelm the factory brake system is due to the extra heat the brakes generate from having to stop a faster car. This increases the chance of boiling the fluid, glazing the pads, etc. You shouldn't experience these issues on a public road without doing something stupid or illegal. The main reasons for a BBK on these cars are a larger disc acts as a better heatsink, the increased surface area of larger disc sheds heat faster, and a lighter 2-piece disc is less rotational mass. None of these benefits are really applicable to a road car. I don't have any first hand experience with the Macan calipers. I did research on them when people started swapping them over, but I currently don't see a benefit worth the cost. From my understanding the benefits are top loading pad swaps, using Mk6 R 345mm discs, and you get 4 piston calipers. The extra 5mm will very slightly increase the torque arm of the brakes allowing for slightly increased braking force and the 4 pistons will give you a more even clamping pressure and better modulation of the brakes. That being said, if you can consistently lock your wheels and activate ABS, that extra braking force isn't doing anything because your ABS is releasing brake pressure to unlock your wheels. Once the braking force overloads the tire's grip, you're not stopping any faster. A better tire will have a bigger impact on stopping distance, which is where I'd rather put the money towards instead of buying the Macan calipers. starmagsi 1 Quote Link to comment Share on other sites More sharing options...
starmagsi Posted December 14, 2020 Report Share Posted December 14, 2020 13 hours ago, DarkArrow said: The factory brake system is more than enough for a stage 1 or 2 on a non-track application. The reason why Stage 1 or more on track starts to overwhelm the factory brake system is due to the extra heat the brakes generate from having to stop a faster car. This increases the chance of boiling the fluid, glazing the pads, etc. You shouldn't experience these issues on a public road without doing something stupid or illegal. The main reasons for a BBK on these cars are a larger disc acts as a better heatsink, the increased surface area of larger disc sheds heat faster, and a lighter 2-piece disc is less rotational mass. None of these benefits are really applicable to a road car. I don't have any first hand experience with the Macan calipers. I did research on them when people started swapping them over, but I currently don't see a benefit worth the cost. From my understanding the benefits are top loading pad swaps, using Mk6 R 345mm discs, and you get 4 piston calipers. The extra 5mm will very slightly increase the torque arm of the brakes allowing for slightly increased braking force and the 4 pistons will give you a more even clamping pressure and better modulation of the brakes. That being said, if you can consistently lock your wheels and activate ABS, that extra braking force isn't doing anything because your ABS is releasing brake pressure to unlock your wheels. Once the braking force overloads the tire's grip, you're not stopping any faster. A better tire will have a bigger impact on stopping distance, which is where I'd rather put the money towards instead of buying the Macan calipers. Tip-top answer... Thanks for taking the time, much appreciated. I had half-an-eye on them as I will need to replace discs and pads all round soon and that isn't a couple of hundred-quid all in job on one of these. Man maths suggests that if something is already quite expensive you may aswell just crack on and go for it. I may need your advice again next time I think of blowing cash on unnecessary mods. 👍 Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted December 19, 2020 Report Share Posted December 19, 2020 On 13/12/2020 at 11:44, starmagsi said: Out of interest, would the Macan 4-pot caliper be a suitable stage 1 level upgrade for somebody not really looking to track their R? With a half-decent disc/pad combo it feels like it should offer a real improvement in stopping ability at the c.£1k level. I took time to decide between the Macan 4 pot Callipers and the similar Audi TTS 4 pot callipers. I ended up buying a used set of TTS callipers, alone with CS discs and I think there is a noticeable improvement. Despite being a 4 pot calliper and using a larger brake pad they are also considerably lighter than the OE R callipers. I'm just finishing up my 'how to' fitment thread and hope to post it before Christmas. Here's a little taster; starmagsi and camelsac2002 2 Quote Link to comment Share on other sites More sharing options...
starmagsi Posted December 19, 2020 Report Share Posted December 19, 2020 4 hours ago, TheBlondeFella said: I took time to decide between the Macan 4 pot Callipers and the similar Audi TTS 4 pot callipers. I ended up buying a used set of TTS callipers, alone with CS discs and I think there is a noticeable improvement. Despite being a 4 pot calliper and using a larger brake pad they are also considerably lighter than the OE R callipers. I'm just finishing up my 'how to' fitment thread and hope to post it before Christmas. Here's a little taster; Look lovely they do, roughly how much did you pay for the calipers if you don't mind me asking? Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted December 19, 2020 Report Share Posted December 19, 2020 1 hour ago, starmagsi said: Look lovely they do, roughly how much did you pay for the calipers if you don't mind me asking? I bought them 2nd hand and they cost me £380 delivered including used pads. I had them professionally repainted and bought new Tarox pads which obviously put the overall price up though. The TTS 4 Pot callipers like the Macan 4 Pot callipers are both a direct bolt on replacement which makes the swap really easy. Quote Link to comment Share on other sites More sharing options...
ChrisTurbo Posted December 21, 2020 Author Report Share Posted December 21, 2020 I have some Bilstien B16 PSS10s being fitted in the new year along with some front and rear White Line ARBs. I think I might need to adjust the camber outside of the current thresholds (think it’s 1-1.5 negative stock?) What do you recommend (tried and tested) and any links? Thanks. Quote Link to comment Share on other sites More sharing options...
Msportman Posted December 21, 2020 Report Share Posted December 21, 2020 If you’re seriously going to do track work you’ll definitely need a 2 piece set up (As Blondefella can vouch for when I took him out for a spin around Combe) Its all about heat dissipation on circuit and cooling the brakes. Hi performance brake pads generate heat and lots of it. The higher or more aggressive the pad for track use the more heat is generated. The primary function of the bell is to transfer heat away from the calliper and disc face. Always go grooved discs and not drilled items. Another aspect to consider is steel quality, preparation for heat cycling and carbon content for heat expansion and contraction for heat cycles . The Tarox kits use very quality grade “A” motorsport/ competition steel in their BBK’s. Have a read on their BBK literature. In the end you pays your money and get what you pay in any track of motorsport parts. camelsac2002 1 Quote Link to comment Share on other sites More sharing options...
TWPaul Posted January 2, 2021 Report Share Posted January 2, 2021 On 21/12/2020 at 23:38, Msportman said: If you’re seriously going to do track work you’ll definitely need a 2 piece set up (As Blondefella can vouch for when I took him out for a spin around Combe) Its all about heat dissipation on circuit and cooling the brakes. Hi performance brake pads generate heat and lots of it. The higher or more aggressive the pad for track use the more heat is generated. The primary function of the bell is to transfer heat away from the calliper and disc face. Always go grooved discs and not drilled items. Another aspect to consider is steel quality, preparation for heat cycling and carbon content for heat expansion and contraction for heat cycles . The Tarox kits use very quality grade “A” motorsport/ competition steel in their BBK’s. Have a read on their BBK literature. In the end you pays your money and get what you pay in any track of motorsport parts. Msportman.... OK, I plan to start tracking my stage 2 R this year. I’ve only recently acquired it, important bits are that it’s Stage 2, lowered 20mm (unsure which springs) and 15mm/10mm spacers rear/front. Michelins on 19” Prets. Having read up a little it seems a good idea to upgrade brakes before venturing on track, no point trashing discs/pads straight off, would rather keep them in good order to put back on later as and when I move on. I see you have the 8 pot Tarox set up, which (other than going full ceramic for very silly money) seems to be pretty much the ultimate (although I have seen 12 pot Tarox on Awesome GTI website?). Anyway, think I say that you’d got ‘a bite of a deal’ over the advertised price of about £3240 + fitting. Any suggestions where I can go to get a decent saving? I have seen a Racingline setup on EBay but some seem to... let’s say... trash that kit, any thoughts? https://www.ebay.co.uk/itm/383864502115?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F710-53481-19255-0%2F1%3Fff3%3D4%26pub%3D5575418208%26toolid%3D10001%26customid%3DEAIaIQobChMIsZS51e_97QIVE-3tCh1W4weYEAQYASABEgL8T_D_BwE%26campid%3D5338627314%26mpre%3Dhttp%3A%2F%2Fwww.ebay.co.uk%2Fitm%2F383864502115%26customid%3DEAIaIQobChMIsZS51e_97QIVE-3tCh1W4weYEAQYASABEgL8T_D_BwE%26gclid%3DEAIaIQobChMIsZS51e_97QIVE-3tCh1W4weYEAQYASABEgL8T_D_BwE%26srcrot%3D710-53481-19255-0%26rvr_id%3D2752441505866%26rvr_ts%3Dc458d2721760a9cca1909f31ffc9df5a&ul_noapp=true Also, your rear brake set up, are you as happy with that as the fronts or is there a more ideal set up you'd go for given the chance? I do plan on getting catch can sooner rather than later plus ARB’s then bit longer term looking to coilovers etc. Lastly, where do you tend to track? Brands Hatch is my local but I did my ARDS test (many years ago, never used in earnest) at Thruxton, is that your usual haunt? It would be good to meet up with someone that’s ‘been there and done that’...... If anyone else with decent track-based experience has any recommendations to make please don’t hesitate to shout! Cheers. Cheers! Quote Link to comment Share on other sites More sharing options...
Msportman Posted January 2, 2021 Report Share Posted January 2, 2021 15 hours ago, TWPaul said: Msportman.... OK, I plan to start tracking my stage 2 R this year. I’ve only recently acquired it, important bits are that it’s Stage 2, lowered 20mm (unsure which springs) and 15mm/10mm spacers rear/front. Michelins on 19” Prets. Having read up a little it seems a good idea to upgrade brakes before venturing on track, no point trashing discs/pads straight off, would rather keep them in good order to put back on later as and when I move on. I see you have the 8 pot Tarox set up, which (other than going full ceramic for very silly money) seems to be pretty much the ultimate (although I have seen 12 pot Tarox on Awesome GTI website?). Anyway, think I say that you’d got ‘a bite of a deal’ over the advertised price of about £3240 + fitting. Any suggestions where I can go to get a decent saving? I have seen a Racingline setup on EBay but some seem to... let’s say... trash that kit, any thoughts? https://www.ebay.co.uk/itm/383864502115?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F710-53481-19255-0%2F1%3Fff3%3D4%26pub%3D5575418208%26toolid%3D10001%26customid%3DEAIaIQobChMIsZS51e_97QIVE-3tCh1W4weYEAQYASABEgL8T_D_BwE%26campid%3D5338627314%26mpre%3Dhttp%3A%2F%2Fwww.ebay.co.uk%2Fitm%2F383864502115%26customid%3DEAIaIQobChMIsZS51e_97QIVE-3tCh1W4weYEAQYASABEgL8T_D_BwE%26gclid%3DEAIaIQobChMIsZS51e_97QIVE-3tCh1W4weYEAQYASABEgL8T_D_BwE%26srcrot%3D710-53481-19255-0%26rvr_id%3D2752441505866%26rvr_ts%3Dc458d2721760a9cca1909f31ffc9df5a&ul_noapp=true Also, your rear brake set up, are you as happy with that as the fronts or is there a more ideal set up you'd go for given the chance? I do plan on getting catch can sooner rather than later plus ARB’s then bit longer term looking to coilovers etc. Lastly, where do you tend to track? Brands Hatch is my local but I did my ARDS test (many years ago, never used in earnest) at Thruxton, is that your usual haunt? It would be good to meet up with someone that’s ‘been there and done that’...... If anyone else with decent track-based experience has any recommendations to make please don’t hesitate to shout! Cheers. Cheers! Yeap you need to fit the Tarox 8 pot kit with their latest fast road pads...they are not race pads but a step up and in between the Corsa pad and the full blown race pad range. I got my kit via Tom Walker at Retro Resus who fitted the kit. You’ll also need upgraded Motul brake fluid. If you contact me via pm I’ll give you contact at Tarox if seriously interested who “may” be able to help Re any discount and supply. On the rears I run Tarox F2000 discs with Strada pads as they create less heat.....they are more than adequate. Only change the rear ARB...I use 034 Motorsport which has two settings. Changing the front gives you a flatter front but will introduce understeer. The front will wash wide once you get heat cycles into the tyres overwhelming the tyres. Youll great back up with Tarox.....they supply F1 and know brakes! High quality set up and you’ll get a free refurb of Rotors when need. I’ve had experience with AP in the past which are also very good. I normally go to Donnington, Castle Combe, Mallory Pk. I’ve done most tracks years ago on a regular basis so when COVID lifts I’ll be looking to do another day. I’m hopefully going to The Ring with a few others on here end of April. BTW Ive just changed the front rotors so now on my second set. They are being refurbed by Tarox. Expect them to last 3-5yrs depending on usage. Quote Link to comment Share on other sites More sharing options...
