Basic Track preparation - Mk7 Golf R
ChrisTurbo
Hi,
I collect my Dec 2016 registered Golf R. I want to use it for spirited Sunday blasts and a fair few track days next year. It will also do the odd commute when I am not working from home.
My day 1 list (as in I want to buy now) is:
Brakes
- DS2500 pads
- RBF600 fluid
- Hell Brake lines
- Discs are new and OEM (should last me until i BBK in the future)
Tyres
- Michelin Cup 2 (18/40/225)
Suspension
- Bilstien B16 PSS10s
- 034 Motorsport top mounts????? Are these the correct ones to get to add a bit more negative camber?
- Geo
The question is where are the best places to get some deals on the above?
I was thinking about getting it fitted at Midland VW?
I was also looking out for a stage 1 remap/gearbox flash (DSG)
Chris
Your discs will last for normal road use but as soon as you start lapping on a track, they’ll be toast. The standard set up isn’t brilliant for spirited driving let alone track days.
For the bits, you could try the usual places like Awesome GTi and VRS. For remaps, you could try VRS in Northampton for a stage 1 map or MRC in Banbury.
10 hours ago, ChrisTurbo said:
Thanks. So shall I get the uprated clubsport S discs or maybe the Vagbremtechnic 'J' Hooked 340mm Front Brake Discs (MQB) for starters?
Dont bother with those you’ll need a proper BBK to cope....been there done that with uprated discs and pads.
Been running a Tarox 8 Pot. 2 piece kit for two years.
Also you’ll need race fully synthetic brake fluid. I run Castrol SRF or Motul RB 600.
These engines run hot even on the road in the summer so get a decent inter cooler. I run all APR kit and it sorted heat soak on track and in summer.
Cooling is important and changing oil after track sessions. I run Ester based oil and also change that at every 5 k and DSG oil at 18k. Rear Haldex I change oil every year.
With high cornering and big stops on track one of the most important upgrades that often gets over looked and is essential to save your turbo from oil surge is a breather kit. I use the Racingline breather kit which definitely works keeping breather clean.
Id also recommend the Superpro Poly Caster bush set which gives you additional caster and camber. If you decide on  extra camber the fixed top mounts 034 motorsport are good but are non adjustable and you’ll knock inside edges of tyres out more rapidly.
If you’ve got the budget I’d go KW 3 way or their 2 way  Clubsport kits which are brilliant but pricey or B16 Clubsports. Ohlins make a great kit as well.
AST  or KW Individual Custom coils are  the pinnacle.
Keeping on top of maintenance is key and ensuring engine runs as cool as possible. I’d also consider Racingline oil cooler and DSG coolers now available and get that mapped.
My recommendation is Retro Resus
https://www.retroresus.com
VW Cup Race Car Prep
MK5 PGTI Championship builders
MK2 16 V Championship Race Prep
Thunder Saloons
They look after mine and a few others on here.
APR & Racingline and a whole host of other equipment
Tom Walker & Graham Scott both motorsport engineers and builders of rave cars
A couple highly recommended modifications for a track day to add to your list:
- RS3 brake ducts.  Inexpensive, fit like OEM, and are fairly effective.  Won't replace a true ducting system, but people have shown they do help cool the rotors a decent amount.
- Rear sway bar.  IMHO, one of the biggest bang for buck mods for the R.  Helps neutralize understeer.  I haven't had any issues of snap oversteer that some other cars struggle with when you put a big rear bar on.
On factory power, the factory brakes on an R are adequate.  You'll run into heat issues towards the end of a typical 25 minute session, but they hold up okay with DS2500s and good fluid.  Don't waste your money on "upgraded" discs/rotors.  The only ones that would probably help are Girodiscs and they're $800USD/pair.  Not worth it.  High carbon blanks work just fine, and you won't feel bad when you need to replace them often or swap to a BBK.  If you run a stage 1, you're pushing the capability of the factory brakes, and stage 2 will most likely run into heat issues very early and should be thinking of getting that BBK soon.  FWIW, my OEM rotors have lasted ~12 track days and they'll be needing replacement before the next event.
Not sure about pricing in Europe, but SuperPro makes almost identical camber plates for cheaper than 034.  If you want adjustable camber, I recommend Vorshlag or Ground Control.  AFAIK, they're the only adjustable camber plates that don't require cutting into the strut top or pulling the suspension to adjust.  Since the R doesn't have any adjustable front camber, outside of shifting the subframe, I bought adjustable to keep the camber even.  I'm running the Ground Controls with ~ -2* of camber and have very even wear.  I'm looking to add more negative camber next alignment.  If you zero out the front toe, you won't have any significant tire wear issues with modest camber.
This is a great post and is most helpful. Thanks for taking the time to write this up.
I need to research the BBK option as there is so much choice and all around £2k or more so need to be right for me. ~I.e. I like the standard Cadiz alloys but knowledge these would need to go if I BBK.
I might follow your advice for now ... 20 min sessions would be fine for me as this is what I’m used to.
PS..... funnily enough I had a set of RS3 ducts arriver today!
Thanks.
Will the Tarox kit fit under the Cadiz alloys with no spacers - I want to keep the stealthy stock look.
Yes they will
No spacers required. One of the only proper BBK’s on the market that do.
The black TD’s are 18’s btw but this kit is made to fit both stock VW wheels.
14 minutes ago, Msportman said:
Yes they will
That’s great news..... I found a set on eBay for £1800... I’m not sure on the colour (green on a lapis blue) and also the fitment of the brake lines as they are off a Octavia VRS.
Out of interest, would the Macan 4-pot caliper be a suitable stage 1 level upgrade for somebody not really looking to track their R? With a half-decent disc/pad combo it feels like it should offer a real improvement in stopping ability at the c.£1k level.
I believe so although I don’t know
who has fitted the kit on here.
Id ring Dean at Vagbremtechnic who is putting together some new stuff at Awesome
