Electric boot
alexretro
Productive day today
Fitted electric boot on my Golf. Quite useful feature I would say. Shame Golf never came out with this option so had to get after kit.
Can be opened from remote or interior switch. Closing either with switch in the boot or interior.
Can be adjusted how high you want your boot open (not sure why tho)
And this is how it works:
1 minute ago, alexretro said:
Unfortunately it is aftermarket Chinese kit so I won’t be selling it mate as I don’t want to take responsibility for that. Same kit has been fitted in my mates car and works fine since a year now
Can fit if needed.
There you have link for the kit. £280ish (depends of exchange rate)
https://a.aliexpress.com/_BU0m1B
How much just to install the kit.?
13 minutes ago, Deltabox said:
I looked into this and found this
https://www.autoease.com/product/liftgate/
I’m sure I found the uk supplier and they would supply direct. I’ll look and see if I can find costs... I never went ahead with it.
It was around £1500 from what I remember. Too expensive but if the cheap Chinese version can be installed in 3 to 4 hours it would make more financial sense.
Guys. This kit costs £280. Took me half a day to figure out how it connects. Than another half a day to fit it. Comes with fitting manual as well. Now I would say fitting is doable within 4h for someone familiar with tools and trims. So I can’t see why they charge £1500 for that. Good profit tho
One cable goes to fuse box, one earth, 2 cables from steering lock to can gateway or interior door loom. Rest is on clips which you cannot miss as they only fit one place. Kit also comes with correct drill bits for buttons and struts wiring.
  • 4 weeks later...
  • 2 years later...
Help!
We've had a local mobility specialist fit the Autoease kit for my wife as she has a disability
The kit doesn't fit - the tailgate struts are in the wrong position and have dented the inside of the tailgate
Alex - was your kit from Autoease?  Can you help with pictures of the brackets too and bottom of the struts?
Many thanks........
Richard
5 hours ago, Madelvic said:
Help!
Many thanks........
Richard
It states the kit was was from aliexpress not autoease. The original link no longer works but if you look around the aliexpress web site you’ll probably find a seller. At least you should have a contact number to phone for an autoease supplied kit. Aliexpress you’ll be on your own.
