Puddle lights
Vinniecoup
8 hours ago, NRW said:
Now considering emigrating to USA.
Stop it. You have the Settle-Carlisle line where you live. You can watch a black 5 over the Ribblehead or a Duchess roar up towards Aisgill Summit (46233 should be back in steam next year, I think!). Nothing in the USA could beat that.
If you live in the east (I apologize, I don’t know the exact definition of “Northumbria” in this millennium 🤣 ), and support Newcastle, then yes, I would definitely consider emigrating to the US, haha 😜
I am, of course, totally joking!!
Me too I meant to be near to DAP/ Paul and Humble mechanic to look after my R.
Attempted humour gets lost in translation tho.  Northumbria is meaningless too, so vague…
  • 1 month later...
On 14/08/2024 at 23:46, AHG said:
I ordered a pair from shopDAP.com
price was 73$/pair inc. local shipping
(LHD as US/EU, not sure if the same for  AU/UK)
Left (Drivers):
https://www.shopdap.com/5h1945301a-vw-audi.html
Right (Passenger):
https://www.shopdap.com/5h1945302a-vw-audi.html
I replaced the puddle light today.
Not the easiest job, but more because of me being afraid to break something than the job itself.
Took out the glass mirror and disconnected the heating wires.
I followed the Humble Mechanic video, who mentioned it is a struggle the first time around. It was a struggle indeed, took patience and subtlety.
He actually broke the glass and then explained how not to break it 🙂
Then removing the cover (two tabs released with prying tool) and the Side Assist disconnected, and removed from the cover.
The connector has a button you need to press, so it comes out.
Removing the Side Assist requires pressing a tab and then jiggling it out, a bit of force is required. I recommend a soft paper between the cover and the light unit, so it doesn’t mar.
Then it taking out two Torx 10 screws on bottom left and right of the front frame.
After removing the front frame, and moving a couple of tabs (where the screws were) I had to jiggle the bottom frame down and twist it, so I can approach the puddle light without further tear down.
Another Torx 10 screws held it in place, and then a bit of a jiggle to get it out (there’s a tooth holding it down across from the screw).
Then putting it all back again.
Just make sure the tooth holding it down it pressed against it (took some trying).
On 15/08/2024 at 21:44, AHG said:
genuine VW Satin Black mirror covers cost €220 each side (before shipping)
I think I’ll try the 30€ eBay version first, to see if I like it visually.
If I do but not happy with the quality, I may order genuine ones 🙂
PS2 - here are the PN for the puddle lights and the black caps
Puddle lights (5H1945301A, 5H1945302A - 1 is left, 2 is right)
Black Mirror Covers (5H1857508AP9B9, 5H1857507AP9B9)
Used the opportunity to swap mirror covers to black ones.
The 30$ eBay set was not perfect, but pretty good for the price
In the left one the recess for the Side Assist wasn’t perfect so its top side protrudes out by 1/2 mm (other one is flush).
Noticeable only by touch or camera at a specific angle.
The right one had a paint imperfection, also very minor.
I’ll stay with it for a while, then decide it to switch back, get an expensive OEM set, or stay with those.
  • 2 months later...
Just get a new pair and replace them
ShopDAP carries them at $73 per pair (in the US)
I assume you can find similar offers in UK
DO IT SLOWLY
As it is attached in a very specific way (you need to twist it in/out, so it ‘feels’ pressure from the small cantilever that’s supposed to keep it in place.
Talking about puddle lights, does anyone else think that the ones on later models seem a bit more robust?
My 21 plate white mk8 ones were fragile and needed replacement under warranty after 18 months  or so but the ones on my 23 plate R20 years are faring much better after 17 months with no signe of any fracturing.
I guess only time will tell for the 8.5s
  • 2 months later...
On 25/12/2024 at 22:07, AHG said:
I can tell you I replaced my right side one after 2+ years (MY22, June ‘22 build) and my left one is still looking good (I bought a pair, so when it goes, I’m ready 🙂
So happy I did it myself, it was confidence building (and money saving).
I concur with that, its so nice achieving what we sometimes feel, i cant do that. The best part we take more care in treating our cars than the Grease monkeys. All beit its just a car to them. Dare i say it, have the issues with the puddle lights been fixed as no one has mentioned them for a while.?
  • 5 months later...
I’ve just taken my R in to the garage as the bottom of the front badge has fallen off and the puddle lights just looked like smashed glass on the floor…
Only to be told that the badge doesn’t come under warranty (£279 to fix!!).
And that my vehicle spec (2023 R with performance pack) doesn’t come with ‘R’ puddle lights… I thought they all came with R puddle lights..? £70 to fix, surely whatever the stock puddle light is should be under warranty anyway…
I asked for a call back… after an hour of not getting one, I called to find that my contact was going to be on lunch for another 35mins…
On a side note… can anyone recommend a VW garage in South London/Surrey?? I’ve found Lookers Battersea and now Wimbledon to be woeful…
It will definitely have R puddle lights. The dealer is talking rubbish.
The quality of both the R badges and the puddles lights is crap. My mk8 front R badge fell off and I had to glue it back on a couple times.  Puddle lights went the way they all do.
Thanks Becs, that’s what I thought! My 24 definitely had the R puddle lights.
The bottom of the badge fell off that one too, and Battersea only replaced on warranty after I kicked up a fuss. I might find the part number and order myself, I’m not paying £270 for something so minor.
Have a look here for the part number @Shiverme
 https://www.vwroc.com/forums/topic/42046-front-grille-badge-snapped-off/?do=findComment&comment=630315
