Booth11 Posted April 28, 2025 Report Share Posted April 28, 2025 10 minutes ago, chillly said: I’m perplexed at this issue considering primarily the paddles are surely running the same software as the 7.5 for this feature? Sadly I’m beginning to think that amalgamating the EV software into Ice cars is never going to work. Such a shame as the car is awesome otherwise. I don’t recall ever hearing of this issue on the mk8R even. IF that is the case then it appears to be an issue that specific to the 8.5R. Quote Link to comment Share on other sites More sharing options...
chillly Posted April 28, 2025 Report Share Posted April 28, 2025 5 minutes ago, Booth11 said: I don’t recall ever hearing of this issue on the mk8R even. IF that is the case then it appears to be an issue that specific to the 8.5R. Regardless whether it’s 8 or 8.5 does it not share the same tech as the 7.5 on the DSG software. I assume it would be separate to the new infotainment anyways? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 28, 2025 Report Share Posted April 28, 2025 1 minute ago, chillly said: Regardless whether it’s 8 or 8.5 does it not share the same tech as the 7.5 on the DSG software. I assume it would be separate to the new infotainment anyways? No idea 🤷🏼♀️ Quote Link to comment Share on other sites More sharing options...
AHG Posted April 28, 2025 Report Share Posted April 28, 2025 43 minutes ago, chillly said: are surely running the same software as the 7.5 Why would you think that ? Quote Link to comment Share on other sites More sharing options...
chillly Posted April 28, 2025 Report Share Posted April 28, 2025 15 minutes ago, Booth11 said: No idea 🤷🏼♀️ Seems It’s never ending 🤷♂️ Quote Link to comment Share on other sites More sharing options...
chillly Posted April 28, 2025 Report Share Posted April 28, 2025 1 minute ago, AHG said: Why would you think that ? Is it not the case? Do me a favour can you copy all the post as to not lose some of the question👍 Quote Link to comment Share on other sites More sharing options...
AHG Posted April 28, 2025 Report Share Posted April 28, 2025 Personally I love manual mode but get to use it very scarcely So it would bother me when daily driving but I would want it fixes eventually I do think it is only a software malfunction as I believe (despite some claims) that no hardware has been changes in the steering wheel and its surroundings (including the manual shifting paddles). Quote Link to comment Share on other sites More sharing options...
AHG Posted April 28, 2025 Report Share Posted April 28, 2025 2 minutes ago, chillly said: Is it not the case? I see no resemblance between the 7.5 and the 8/8.5 platform, electrically or otherwise. But I have no proof it is not. Just trying to figure out if you have information to shed light on on the subject or is it just a guess Quote Link to comment Share on other sites More sharing options...
chillly Posted April 28, 2025 Report Share Posted April 28, 2025 2 minutes ago, AHG said: I see no resemblance between the 7.5 and the 8/8.5 platform electrically or otherwise But have no proof it is not Just trying to figure out if you have information to shed light on on the subject or is it just a guess I’m pretty sure I was not guessing but asking! Again I assume it runs the same as the 7.5 DSG did? Quote Link to comment Share on other sites More sharing options...
mahalo Posted April 28, 2025 Report Share Posted April 28, 2025 Hmm where has the connection to EV software being incorporated into the DSG software for the 8.5R. This is incorrect. Nearly every EV on the market does not have a gearbox - the only two that do are the Porsche Taycan and the Audi E-Tron GT that have a 2 speed gearbox. I don't recall being unable to use manual mode (paddles) being a gremlin on the 8R and I am not sure I recall it being mentioned as a gremlin on the R20. It therefore appears to be a problem confined to the 8.5R. VW has presumably done some changes for the 8.5R to the software and presumably to the steering wheel/paddles etc. It is therefore a case of working through the problem in a methodical and logical manner to determine the cause of the issue. Quote Link to comment Share on other sites More sharing options...
AHG Posted April 28, 2025 Report Share Posted April 28, 2025 1 hour ago, chillly said: I’m pretty sure I was not guessing but asking! Again I assume it runs the same as the 7.5 DSG did? I don’t have info but I don’t think the wheel interface is the same (and I assume that is where the problem lies) the gearbox I. itself is a 2nd gen DQ381 (the 7.5 and S38V had the first gen) Quote Link to comment Share on other sites More sharing options...
chillly Posted April 29, 2025 Report Share Posted April 29, 2025 8 hours ago, mahalo said: Hmm where has the connection to EV software being incorporated into the DSG software for the 8.5R. This is incorrect. Nearly every EV on the market does not have a gearbox - the only two that do are the Porsche Taycan and the Audi E-Tron GT that have a 2 speed gearbox. I don't recall being unable to use manual mode (paddles) being a gremlin on the 8R and I am not sure I recall it being mentioned as a gremlin on the R20. It therefore appears to be a problem confined to the 8.5R. VW has presumably done some changes for the 8.5R to the software and presumably to the steering wheel/paddles etc. It is therefore a case of working through the problem in a methodical and logical manner to determine the cause of the issue. Isn’t the the 8.5 infotainment system from the I’d 4 ? I was assuming the DSG box and paddles/tech are from previous gen’s? 7.5 etc. Unless they have changed it? I didn’t say they incorporated it into the DSG box! Mixing the old and new tech from EVs are not a mix seemingly. I’ve not come across any S3 posts with the similar issue? Quote Link to comment Share on other sites More sharing options...
AHG Posted April 29, 2025 Report Share Posted April 29, 2025 Not in the mk8 as well which is the closest sibling I think it’s the steering wheel interface software which has been claimed to change in the 8.5 Quote Link to comment Share on other sites More sharing options...
Rossdh91 Posted April 29, 2025 Report Share Posted April 29, 2025 Another issue encountered yesterday, noticed it a while ago but only figured out exactly what it was. The font driver side wiper is whacking the weather strip on the edge of the windscreen occasionally. Doesn’t do it all the time but it can easily be replicated. Not sure if this is an issue with the Bosch wipers or not. Anyone else had this? Quote Link to comment Share on other sites More sharing options...
Scudgie Posted April 29, 2025 Report Share Posted April 29, 2025 11 minutes ago, Rossdh91 said: Another issue encountered yesterday, noticed it a while ago but only figured out exactly what it was. The font driver side wiper is whacking the weather strip on the edge of the windscreen occasionally. Doesn’t do it all the time but it can easily be replicated. Not sure if this is an issue with the Bosch wipers or not. Anyone else had this? Yes, I noticed this too. Not whilst driving, but when I was cleaning the car, and pressed the Infotainment button to activate the wiper service mode, it moved the driver’s wiper to a position beyond its normal range. Happened only once and I've not noticed any impact on normal wiper function since. Quote Link to comment Share on other sites More sharing options...
