AgentFruit Posted January 9, 2016 Report Share Posted January 9, 2016 I've been increasingly unhappy with the range of visibility that dipped beam gives me - I too feel that it's unsafe, even/especially at 20-30mpm through my pitch dark village. The brightness is ok....it just cuts off way to close to give enough range. I took it to another dealership this week to get it checked. I spoke to the master tech who actually seemed competent and helpful (a first for VW), but after he'd had a thorough inspection of all the bits and pieces (including DLA), the reply came back that he can't raise the level of the dipped beam any higher. The reason given is that, as they're Xenons, they're much brighter than normal lamps and therefore the MOT rules state that they have to be set lower. He said that if he raised the level the car would fail an MOT (and it'd blind other drivers). I have to admit that, whilst the beam level is low for driving, because the suspension is firm, when going over undulations in the road I do notice the level of the dipped beams also following the undulations of the road, momentarily rising to windscreen heights on other cars. If the lights were set any higher they would become a nuisance to others....just the kind of badly adjusted Xenons that we all curse in other cars. Quote Link to comment Share on other sites More sharing options...
DaveGrohl Posted January 9, 2016 Report Share Posted January 9, 2016 I've had mine raised slightly and I've not had much in the way of oncoming flashers, so to speak. My gf's Ranger tho has the dip set waaay too high as new and she's constantly getting flashed. Quote Link to comment Share on other sites More sharing options...
kev2632 Posted January 9, 2016 Report Share Posted January 9, 2016 Does the golf R come with headlight washers as standard?? As I've just ordered my 1st golf R cheers Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 9, 2016 Report Share Posted January 9, 2016 Does the golf R come with headlight washers as standard?? As I've just ordered my 1st golf R cheersCongratulation on ordering your new R. Yes, headlight washers are standard - xenon lights have to have headlight washers. Tbh they are a PITA if you like a clean car. They activate on the 1st downward press of the windscreen wiper stalk, after ignition on and thereafter on every 5th or 6th press of wiper stalk and often spray windscreen wash all over clean bonnet and wings, windows etc. I believe you can alter the number with vcds. I loath them. kev2632 1 Quote Link to comment Share on other sites More sharing options...
thanksabunch Posted January 10, 2016 Report Share Posted January 10, 2016 Congratulation on ordering your new R. Yes, headlight washers are standard - xenon lights have to have headlight washers. Tbh they are a PITA if you like a clean car. They activate on the 1st downward press of the windscreen wiper stalk, after ignition on and thereafter on every 5th or 6th press of wiper stalk and often spray windscreen wash all over clean bonnet and wings, windows etc. I believe you can alter the number with vcds. I loath them. If you ensure lights are in full off position not Auto before spraying washers it shouldn't activate the headlight washers just the windscreen ones ;-) Mainframe 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 10, 2016 Report Share Posted January 10, 2016 If you ensure lights are in full off position not Auto before spraying washers it shouldn't activate the headlight washers just the windscreen ones ;-) I know, but my lights are always set to auto by default, and I still get caught out on ocassion, lol. Before I set off I usually flip the switch to 0 then clear the windscreen if needed, then back to auto. On deserted B roads I have been known to momentarily flip the switch to 0 to clear winscreen and then lights back on! thanksabunch 1 Quote Link to comment Share on other sites More sharing options...
JonnyG Posted January 10, 2016 Report Share Posted January 10, 2016 Sidelight position is fine too (as well as off) ... keeps your rear lights on then as well Its become a habit with me now Mainframe and Booth11 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 10, 2016 Report Share Posted January 10, 2016 Sidelight position is fine too (as well as off) ... keeps your rear lights on then as well Its become a habit with me now Good tip Sidelights it will be from hereon. Quote Link to comment Share on other sites More sharing options...
kev2632 Posted January 10, 2016 Report Share Posted January 10, 2016 Cheers for the warm welcome , Yeah it's just when I was building my Golf R, it was the winter pack that offers the headlight washers? So I just wanted to make I still get the headlight washers with my car as I've not ordered the winter pack?? Quote Link to comment Share on other sites More sharing options...
andy35554 Posted January 10, 2016 Report Share Posted January 10, 2016 possibly an earth fault on the headlights if they are all dim including the drl's - best to get this checked at the stealers.. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 10, 2016 Report Share Posted January 10, 2016 Cheers for the warm welcome , Yeah it's just when I was building my Golf R, it was the winter pack that offers the headlight washers? So I just wanted to make I still get the headlight washers with my car as I've not ordered the winter pack?? I don't know why they include headlight washers in the info on the winter pack option, as they are definitely a standard on performance Golfs in conjunction with the bi-xenon headlights which are also standard. It's probably because lesser models without bi-xenons can have them as as part of the optional winter pack. But yes, (assuming you are in the UK) even without winter pack, your R will have headlight washers. kev2632 1 Quote Link to comment Share on other sites More sharing options...
thanksabunch Posted January 10, 2016 Report Share Posted January 10, 2016 I don't know why they include headlight washers in the info on the winter pack option, as they are definitely a standard on performance Golfs in conjunction with the bi-xenon headlights which are also standard. It's probably because lesser models without bi-xenons can have them as as part of the optional winter pack. But yes, (assuming you are in the UK) even without winter pack, your R will have headlight washers. So what do uk spec cars actually get in the winter pack?Heated seats! :-0 Quote Link to comment Share on other sites More sharing options...
kev2632 Posted January 10, 2016 Report Share Posted January 10, 2016 I don't know why they include headlight washers in the info on the winter pack option, as they are definitely a standard on performance Golfs in conjunction with the bi-xenon headlights which are also standard. It's probably because lesser models without bi-xenons can have them as as part of the optional winter pack. But yes, (assuming you are in the UK) even without winter pack, your R will have headlight washers. Yeah that's magic I'm based in Scotland so that's good then, can't wait to get my car... Hopefully in March lol Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 10, 2016 Report Share Posted January 10, 2016 So what do uk spec cars actually get in the winter pack? Heated seats! :-0 Well if you have cloth then winter pack gives you heated seats and heated windscreen washer jets. Though it states it includes headlight washers and low washer fluid warning as well, those things are included as standard on all cars whether cloth or leather. If you have leather, then all you are getting with the winter pack is the heated washer jets for ......£250 Rip off! Washer jets freeze over anyway so total waste of money. Who (with leather) in their right mind would spec it??? Mark V 1 Quote Link to comment Share on other sites More sharing options...
sve170 Posted January 13, 2016 Report Share Posted January 13, 2016 Well if you have cloth then winter pack gives you heated seats and heated windscreen washer jets. Though it states it includes headlight washers and low washer fluid warning as well, those things are included as standard on all cars whether cloth or leather. If you have leather, then all you are getting with the winter pack is the heated washer jets for ......£250 Rip off! Washer jets freeze over anyway so total waste of money. Who (with leather) in their right mind would spec it??? The jets do not freeze, I am in Scotland on my 2nd Golf R and it's an option I could not do without. Nosredna7r 1 Quote Link to comment Share on other sites More sharing options...
