Neilo Posted January 13, 2016 Report Share Posted January 13, 2016 Hi all, Is it possible to have the stop start system default to off when I start the car? I don't want to disable it altogether in case I get stuck in bad traffic then I can just turn it back on. Thanks Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted January 13, 2016 Report Share Posted January 13, 2016 Its one press of one button. Like, for real. 1 press. ColC1981 and Stobsie 2 Quote Link to comment Share on other sites More sharing options...
adam. Posted January 13, 2016 Report Share Posted January 13, 2016 Nope. It's either the button or code it out perm. Quote Link to comment Share on other sites More sharing options...
neg Posted January 14, 2016 Report Share Posted January 14, 2016 There is a bit of kit from Germany which remembers the last settings. I found it easier to code it out Quote Link to comment Share on other sites More sharing options...
Jeff R Posted January 14, 2016 Report Share Posted January 14, 2016 Disable Start/Stop Select STG 19 STG adjustment -> function 10 Start Stop Limit voltage Value=12 bitmadmax 1 Quote Link to comment Share on other sites More sharing options...
Neilo Posted January 14, 2016 Author Report Share Posted January 14, 2016 Thanks everyone Quote Link to comment Share on other sites More sharing options...
chris_blue Posted January 14, 2016 Report Share Posted January 14, 2016 Hi all, Is it possible to have the stop start system default to off when I start the car? I don't want to disable it altogether in case I get stuck in bad traffic then I can just turn it back on. Thanks No Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 19, 2016 Report Share Posted February 19, 2016 Hi all, Is it possible to have the stop start system default to off when I start the car? I don't want to disable it altogether in case I get stuck in bad traffic then I can just turn it back on. Thanks Neilo Hello. This is my first post, so I hope that I get it right!! The answer to your question is a resounding YES! But it's done with a simple electronic device that I designed and that anyone with a modicum of soldering skills can make and fit You can find the instruction on the VWWatercooled site below. I and a few of my forum colleauges have been using this device for some months now and it has operated without fail. When the ignition is turned-on, a wait period of 5 seconds occurs after which the device automatically disables SS. The centre console button can be pressed any time after this to re-enable SS if needed (I have never re-enabled SS) Don http://www.vwwatercooled.com.au/forums/f197/golf-mk7-auto-start-stop-disable-switch-who-wants-help-108932.html#post1154903 Neilo 1 Quote Link to comment Share on other sites More sharing options...
Neilo Posted February 19, 2016 Author Report Share Posted February 19, 2016 Neilo Hello. This is my first post, so I hope that I get it right!! The answer to your question is a resounding YES! But it's done with a simple electronic device that I designed and that anyone with a modicum of soldering skills can make and fit You can find the instruction on the VWWatercooled site below. I and a few of my forum colleauges have been using this device for some months now and it has operated without fail. When the ignition is turned-on, a wait period of 5 seconds occurs after which the device automatically disables SS. The centre console button can be pressed any time after this to re-enable SS if needed (I have never re-enabled SS) Don http://www.vwwatercooled.com.au/forums/f197/golf-mk7-auto-start-stop-disable-switch-who-wants-help-108932.html#post1154903 Excellent, thanks for the reply and link Quote Link to comment Share on other sites More sharing options...
Stobsie Posted February 19, 2016 Report Share Posted February 19, 2016 Neilo Hello. This is my first post, so I hope that I get it right!! The answer to your question is a resounding YES! But it's done with a simple electronic device that I designed and that anyone with a modicum of soldering skills can make and fit You can find the instruction on the VWWatercooled site below. I and a few of my forum colleauges have been using this device for some months now and it has operated without fail. When the ignition is turned-on, a wait period of 5 seconds occurs after which the device automatically disables SS. The centre console button can be pressed any time after this to re-enable SS if needed (I have never re-enabled SS) Don http://www.vwwatercooled.com.au/forums/f197/golf-mk7-auto-start-stop-disable-switch-who-wants-help-108932.html#post1154903 Firstly a good post, but an awful lot of hassle when after all it's just 1 press of a button to deactivate S/S, you also need to consider the warranty implications this mod may cause for me and many others I would imagine it's not worth the bother. Rich_D 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 19, 2016 Report Share Posted February 19, 2016 Firstly a good post, but an awful lot of hassle when after all it's just 1 press of a button to deactivate S/S, you also need to consider the warranty implications this mod may cause for me and many others I would imagine it's not worth the bother. Stobsie: Hello Yes, I've had a couple of replies like yours to my VWW post (thanks for the response). When something different is proposed, there are always different views regarding its value - that's OK, that's the reason why forums like this are so interesting. Clearly though, my view was that the design/build was worth the effort. I now no longer have to remember to press that button every time that I start the car. It's automatically off and it still allows me to re-energise SS - not that I will turn it on! I'm not saying that my view is better than yours, it's just a different view - both our opposite views are equally valid albeit they are predicated on a different value-set. As for the warranty implications, the device that I designed does nothing more than mimic the button that you press on the centre console. If you look at the design, you will see that the relay mimic's the single-pole, single-throw switch on the centre console. Of course there may be dealers who want to argue the warranty issue, but any first year engineering student could easily and successfully render claims as being fatuous! Nevertheless, considerations of a warranty breach are valid- I just don't beleive that they could be justified with this device. indeed - any use of a VCDS cable on any car under warranty could equally be liable to warranty issues But thanks again for the reply - I guess we can agree to disagree Don I'm not saying that my view is better than yours- its just a different view. Hung_Tran, GeoffT and Stobsie 3 Quote Link to comment Share on other sites More sharing options...
