SoggyBottomBoy Posted February 6, 2017 Report Share Posted February 6, 2017 Hi Soggy, this is what I'm looking at, the car was picked up a month ago. The engine sound options are eco, normal and sport, but this turns on the soundaktor too. Thanks for the speedy reply Exactly the same,settings I have in individual mode. Tell me this....when you cycle through the driving modes can you hear the exhaust note change? Mine noticeably changes in Race and Individual modes. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted February 6, 2017 Report Share Posted February 6, 2017 Launch control: Having reached 1000 miles I thought I'd give it a go Traction off Foot on the brake Then when I try and press the accelerator its as if its unwilling to rev. It goes up then stops, then if I let my foot off the accelerator a tiny bit, the revs go up a wee bit more. Probably 1k every time I do this. So it takes 4 attempts on the accelerator before the revs are at 4k. Anyone else experience this? Quote Link to comment Share on other sites More sharing options...
ashleyman Posted February 6, 2017 Report Share Posted February 6, 2017 Launch control: Having reached 1000 miles I thought I'd give it a go Traction off Foot on the brake Then when I try and press the accelerator its as if its unwilling to rev. It goes up then stops, then if I let my foot off the accelerator a tiny bit, the revs go up a wee bit more. Probably 1k every time I do this. So it takes 4 attempts on the accelerator before the revs are at 4k. Anyone else experience this? Are you in Race mode or at least have the gearbox in Sport? Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted February 6, 2017 Report Share Posted February 6, 2017 Yeah race mode and S. Its the first time I've tried it so wasn't sure what to expect. I vaguely recall another thread where this was also highlighted. I had only been out the house for less than 10 minutes so possibly not warmed up correctly? Quote Link to comment Share on other sites More sharing options...
Sundown Posted February 6, 2017 Report Share Posted February 6, 2017 Exactly the same,settings I have in individual mode. Tell me this....when you cycle through the driving modes can you hear the exhaust note change? Mine noticeably changes in Race and Individual modes. Sent from my iPhone using Tapatalk Just been out in it, at idle there's definitely a note change in race and individual from normal, although when I started up in I changed from individual to race so haven't checked to see if the car starts with 4 pipes open or i need to manually re-select individual to open the pipes. Jobs for tomorrow... SoggyBottomBoy 1 Quote Link to comment Share on other sites More sharing options...
SoggyBottomBoy Posted February 6, 2017 Report Share Posted February 6, 2017 Just been out in it, at idle there's definitely a note change in race and individual from normal, although when I started up in I changed from individual to race so haven't checked to see if the car starts with 4 pipes open or i need to manually re-select individual to open the pipes. Jobs for tomorrow... If you leave it in individual or race when you turn it off, when you restart the car it will revert to closed valves/flaps even though the mode selector will say Race/Individual. You need to cycle through the modes again after turning the engine off if you want the valves to open. Sent from my iPhone using Tapatalk Sundown 1 Quote Link to comment Share on other sites More sharing options...
Sundown Posted February 6, 2017 Report Share Posted February 6, 2017 If you leave it in individual or race when you turn it off, when you restart the car it will revert to closed valves/flaps even though the mode selector will say Race/Individual. You need to cycle through the modes again after turning the engine off if you want the valves to open. Sent from my iPhone using Tapatalk Ah perfect! That explains it then! I'm guessing that's a vcds tweak to fix and it'll all be honky dory. Thanks! Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted February 6, 2017 Report Share Posted February 6, 2017 Launch control: Having reached 1000 miles I thought I'd give it a go Traction off Foot on the brake Then when I try and press the accelerator its as if its unwilling to rev. It goes up then stops, then if I let my foot off the accelerator a tiny bit, the revs go up a wee bit more. Probably 1k every time I do this. So it takes 4 attempts on the accelerator before the revs are at 4k. Anyone else experience this? Wow you actually waited until a thousand miles !! I thought I had done well getting to 400 . I know someone who had 10 miles and did a few Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted February 6, 2017 Report Share Posted February 6, 2017 Wow you actually waited until a thousand miles !! I thought I had done well getting to 400 . I know someone who had 10 miles and did a few Sent from my iPad using Tapatalk I had forgot about it if truth be told ninja_geezer 1 Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted February 6, 2017 Report Share Posted February 6, 2017 Launch control: Having reached 1000 miles I thought I'd give it a go Traction off Foot on the brake Then when I try and press the accelerator its as if its unwilling to rev. It goes up then stops, then if I let my foot off the accelerator a tiny bit, the revs go up a wee bit more. Probably 1k every time I do this. So it takes 4 attempts on the accelerator before the revs are at 4k. Anyone else experience this? Ive used lc in 3 different golf R now, same in all 3 .hold traction control button for a few seconds until it bings,race mode selected ,mash brake firmly (important firmly or it does not work) foot on throttle mash to the floor revs should hover around 4k then just let foot of brake when ready :afro: Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted February 6, 2017 Report Share Posted February 6, 2017 I had forgot about it if truth be told Lol my bro got an R a week before me and every other day he was saying have you launched it yet :grin: Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted February 6, 2017 Report Share Posted February 6, 2017 Launch control: Having reached 1000 miles I thought I'd give it a go Traction off Foot on the brake Then when I try and press the accelerator its as if its unwilling to rev. It goes up then stops, then if I let my foot off the accelerator a tiny bit, the revs go up a wee bit more. Probably 1k every time I do this. So it takes 4 attempts on the accelerator before the revs are at 4k. Anyone else experience this? No, the only thing you may be doing wrong from what you are describing is not pressing the brake firmly enough. Make sure oil is up to temperature (>80°C to be safe, not exactly sure of the threshold, personally I don't launch until >/=95°C) press ESC once to turn to ESC sport (or hold to turn off, doesn't matter, both work, matter of choice for conditions) Gearbox in sport (DSG) Foot very firmly on brake Throttle pushed through the floor Let go of brake when revs rise and hover around the 4k mark for a second or so, gives the turbo a chance to spin up If you are finding you have to pump the throttle to get the revs to rise (brake firmly applied, sequence honoured), you may need to get it checked out by a dealer/garage. I sometimes approach the lights (car fully warmed), tap the ESC button, pull back DSG stick for sport, come to a stop and hold brake firmly, then stamp on the throttle when lights change, let go of brake at 4k revs and hurtle off, key factors are, warmed car, ESC in sport, DSG in sport, stopped with brake firmly applied, revs at 4k. RoundSquare, ninja_geezer and SoggyBottomBoy 3 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted February 6, 2017 Report Share Posted February 6, 2017 Yeah race mode and S. Its the first time I've tried it so wasn't sure what to expect. I vaguely recall another thread where this was also highlighted. I had only been out the house for less than 10 minutes so possibly not warmed up correctly? Could be. I remember being in a similar position and wanting to show a friend how loud it was when revving on launch but it just wouldn't go. I always put that down to it not being warm enough. You do really have to stamp on both the brake and the accelerator though so perhaps press harder? ninja_geezer 1 Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted February 7, 2017 Report Share Posted February 7, 2017 Could be. I remember being in a similar position and wanting to show a friend how loud it was when revving on launch but it just wouldn't go. I always put that down to it not being warm enough. You do really have to stamp on both the brake and the accelerator though so perhaps press harder? Yes i remember a year ago when my cousin got his R he was struggling to launch it but every time it worked for me ,it was just the fact he was not stamping the brake and the throttle. Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted February 7, 2017 Report Share Posted February 7, 2017 Launch control: Having reached 1000 miles I thought I'd give it a go Traction off Foot on the brake Then when I try and press the accelerator its as if its unwilling to rev. It goes up then stops, then if I let my foot off the accelerator a tiny bit, the revs go up a wee bit more. Probably 1k every time I do this. So it takes 4 attempts on the accelerator before the revs are at 4k. Anyone else experience this? Wow you actually waited until a thousand miles !! I thought I had done well getting to 400 . I know someone who had 10 miles and did a few Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
