Booth11 Posted February 1, 2017 Report Share Posted February 1, 2017 1. Can someone please instruct me how to the left hand mirror dips on reverse? I've got it selected on the menu however it's not doing it. I've tried everything. Doesn't seem to want to dip 2. When locking (keyless) I've noticed pressing twice seems to lock again. Is this actually double locking or setting anything? Also is there a way of making the alarm beep when locking? 1. Have got the mirror knob turned to L position. It needs to be at L. 2. Double pressing (keyless or keyed) does not double lock and is less secure than single press. It is single press that deadlocks the car. A single press of the lock button activates the deadock (vehicle locked from both inside and out, so most secure), double pressing the lock button deactivates the deadlock, meaning it's only locked from the outside and not the inside as well. In the past with Golfs, many have mistakenly thought that double press lock was deadlocking the vehicle, not so. wolverine and SoggyBottomBoy 2 Quote Link to comment Share on other sites More sharing options...
cotnob Posted February 1, 2017 Report Share Posted February 1, 2017 I have a MY2017 car and all I had to do was move the mirror selector to the L position, no need to set it up. If anything it dips the mirror to far for me. On a different topic - is it possible to adjust the throw of the headlights when on dipped beams, they feel slightly too low, clobbered a pothole on the motorway at legal speed as I didn't see it until the last moment. Quote Link to comment Share on other sites More sharing options...
Lustral Posted February 1, 2017 Report Share Posted February 1, 2017 I have a MY2017 car and all I had to do was move the mirror selector to the L position, no need to set it up. If anything it dips the mirror to far for me. . You can adjust this while in Reverse and the mirror on L , just adjust it then to suit your needs. That reminds me that i need to dip mine more. Quote Link to comment Share on other sites More sharing options...
Taz23-R Posted February 1, 2017 Report Share Posted February 1, 2017 1. Have got the mirror knob turned to L position. It needs to be at L. 2. Double pressing (keyless or keyed) does not double lock and is less secure than single press. It is single press that deadlocks the car. A single press of the lock button activates the deadock (vehicle locked from both inside and out, so most secure), double pressing the lock button deactivates the deadlock, meaning it's only locked from the outside and not the inside as well. In the past with Golfs, many have mistakenly thought that double press lock was deadlocking the vehicle, not so. Doesn't 2 presses also disable the internal alarm, if for when you leave a dog or passenger in the car but you still want to lock the car without the alarm going off. Sent from my iPhone using Tapatalk SoggyBottomBoy 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 1, 2017 Report Share Posted February 1, 2017 Doesn't 2 presses also disable the internal alarm, if for when you leave a dog or passenger in the car but you still want to lock the car without the alarm going off. Sent from my iPhone using Tapatalk Not sure if double press on the key fob alone does disable the internal alarm. There's also the dedicated button for disabling the internal alarm/anti tow monitoring system, to stop it triggering if you were leaving a pet or passenger in the car for any length of time. And I think you need to switch that off too. It's located part way down the the driver's side B pillar iirc. There's a whole process for switching that off just pressing that button doesn't disable it. Think if you open your door with ignition off and press the button it lights up. Then you have to close the doors and then lock the vehicle to turn it off. To check it's on, open your driver's door and if it doesn't light up then it's ON and if it lights up, it's OFF. With the door shut it goes out regardless so you need to check it with the door open. If it is OFF just press once to switch it on. So think it's a bit more than just a double press on the key fob. Could be wrong though. Quote Link to comment Share on other sites More sharing options...
SoggyBottomBoy Posted February 1, 2017 Report Share Posted February 1, 2017 1. Have got the mirror knob turned to L position. It needs to be at L. 2. Double pressing (keyless or keyed) does not double lock and is less secure than single press. It is single press that deadlocks the car. A single press of the lock button activates the deadock (vehicle locked from both inside and out, so most secure), double pressing the lock button deactivates the deadlock, meaning it's only locked from the outside and not the inside as well. In the past with Golfs, many have mistakenly thought that double press lock was deadlocking the vehicle, not so. Point #2.....didnt know this. Thanks!! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SoggyBottomBoy Posted February 1, 2017 Report Share Posted February 1, 2017 Not sure if double press on the key fob alone does disable the internal alarm. There's also the dedicated button for disabling the internal alarm/anti tow monitoring system, to stop it triggering if you were leaving a pet or passenger in the car for any length of time. And I think you need to switch that off too. It's located part way down the the driver's side B pillar. There's a whole process for switching that off just pressing that button doesn't disable it. Think if you open your door with ignition off and press the button it lights up. Then you have to close the doors and then lock the vehicle to turn it off. To check it's on, open your driver's door and if it doesn't light up then it's ON and if it lights up, it's OFF. With the door shut it goes out regardless so you need to check it with the door open. If it is OFF just press once to switch it on. So think it's a bit more than just a double press on the key fob. Could be wrong though. I was never able to find this mythical button. Anyone got a photo? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
cotnob Posted February 1, 2017 Report Share Posted February 1, 2017 Has Jay Kay covered this yet? L8tes, 75Type2 and SoggyBottomBoy 3 Quote Link to comment Share on other sites More sharing options...
SoggyBottomBoy Posted February 1, 2017 Report Share Posted February 1, 2017 Has Jay Kay covered this yet? hahahaha.....ah stop!! Maybe I'll have to eat humble pie. Quote Link to comment Share on other sites More sharing options...
_Golfgirl_ Posted February 2, 2017 Report Share Posted February 2, 2017 I was never able to find this mythical button. Anyone got a photo? Sent from my iPhone using Tapatalk It's on the b-pillar behind the seatbelt... Sent from my iPhone using Tapatalk SoggyBottomBoy 1 Quote Link to comment Share on other sites More sharing options...
SoggyBottomBoy Posted February 2, 2017 Report Share Posted February 2, 2017 It's on the b-pillar behind the seatbelt... Sent from my iPhone using Tapatalk ahhhhh.....I was looking on the inside of the B-Pillar at the door jamb. Duh. Thanks GolfGirl Quote Link to comment Share on other sites More sharing options...
LordR Posted February 4, 2017 Report Share Posted February 4, 2017 Has anyone been able to take off the front number plate holder? trying to make my mind up if it would look better without or not but it seems a pain to be able to take it off. Quote Link to comment Share on other sites More sharing options...
Sundown Posted February 6, 2017 Report Share Posted February 6, 2017 Hi Guys, does anyone know what makes the exhaust valves open? I'm in a manual, and I'd quite like to keep the soundaktor for when friends are in the car, but for the day to day the fake noise is annoying. Is there a way to have 4 pipes open and soundaktor off without pulling the speaker cables out? So far I've been running in individual almost all the time, with everything set to sport apart from engine sound in eco. Only the inboard pipes are getting sooty though. Quote Link to comment Share on other sites More sharing options...
SoggyBottomBoy Posted February 6, 2017 Report Share Posted February 6, 2017 Hi Guys, does anyone know what makes the exhaust valves open? I'm in a manual, and I'd quite like to keep the soundaktor for when friends are in the car, but for the day to day the fake noise is annoying. Is there a way to have 4 pipes open and soundaktor off without pulling the speaker cables out? So far I've been running in individual almost all the time, with everything set to sport apart from engine sound in eco. Only the inboard pipes are getting sooty though. Hi Sundown. The four valves are open when in Race mode. What year is your car? The later model cars can turn off the soundaktor via the 'individual' mode on the driver mode selection. You configure the 'individual' mode to have all sport settings, but set 'internal sound' to ECO. So it sounds like this is what you are doing......your 4 valves should be remaining open. Quote Link to comment Share on other sites More sharing options...
Sundown Posted February 6, 2017 Report Share Posted February 6, 2017 Hi Soggy, this is what I'm looking at, the car was picked up a month ago. The engine sound options are eco, normal and sport, but this turns on the soundaktor too. Thanks for the speedy reply Quote Link to comment Share on other sites More sharing options...
