Guy Incognito
An easy way to stop it is to just pull the stalk as quickly as possible and then let go. Then pull the stalk normally to clean the screen for as long as necessary. The first quick pull tricks the car into thinking it's sprayed and as a result doesn't spray the subsequent one.
Thanks. Worth a try.  :afro:   I've got used to cleaning the screen at strategic points when it can be done without the headlight washers, before setting off and sometimes switching to sidelights (only when safe to do so).
What is almost as bad is the person in front using their screen washers only for it to miss their windscreen and cover your car instead.
Err....sorry bud; they do.
Mine`s a 2015 plate, and mine also has the glasses cubby, along with my Pano roof ! :afro:
There's some confusion about this. I have a 2017 R Variant / Estate / Wagon with pano roof ("moon roof", for those in the know). I can guarantee there is NO cubby hole / sunglass box there. Believe me, I've tried! I also remember that in the configurator there was a warning about this when I added the pano roof option: choosing this will imply losing the cubby hole, etc.
This applies only to the Estate version I suppose?
Appears it may only apply to the Estate then, bud...
Sad as I am, when I saw this thread, I actually nipped into my garage and checked mine, and it definitely has the cubby, which my glasses are in right now (as well as the Pano roof, not that there`s much call for it lately LOL! )
You're not sad: I double-checked the car too... Wait..? Maybe we're both sad!
Hi all
I hope this is the right forum to ask
Could anybody please tell me what is that port in the middle of the red circle ?
I found some powdery white stuff in it, is that normal ?
Thank you
I have that port but its spotlessly clean. Seems like it's just a blanked off/unused port for the intake manifold.
Anyone else with keyless have the same situation?
When I park my car in the garage and it sits there for 7 plus days. The keyless sensors on the door handles don't work, you have to use the fob.
I'm kinda thinking that it's either the ecu detecting low voltage from the battery and it's conserving the remaining amps / volts.
Second thought is it's a security feature and shuts the system down after a period of none use.
I guess I need to read the manual as it's potentially more intelligent than the user!
Read the manual.
It's a security feature that deactivates the sensors after a unspecified time. Reactivated with use of fob.
