Guy Incognito
Is there an option to turn off the headlight washers that seem to come up everytime i use my screenwash ... getting a bit annoying. I have had a look , but i dont see any options on the infotainment system, or does this need to be coded out via a VCDS cable ?
Yes it requires vcds coding. Without using vcds you can't disable them. The headlight washers activate on every first press of the wiper stalk after ignition on and then every 5th swipe I think it is. They are a pita and make a mess all over the bonnet, wings. With vcds, not sure if you can completely disable it but can increase the number of swipes it takes before they activate.
A few quick questions:
- Is shifting the gearbox into S (Sports) mode the same as putting the mode into Race on DCC ? ie. if I'm in eco mode and I shift the gearstick into S-mode is this the same as DCC in race mode?  Or does the DCC add extra things like stiffened suspension etc.
- Are the main beam lights fairly dark?  Mine don't seem that powerful.  Can they be changed ?
- Best cleaner for the exhausts?  Brasso?
- How do I switch on video-in-motion ?  Can it be done using OBD11 or VCDS ?
- As above, does Pro-nav only playback .mp4 vids?  For some reason videos that are encoded with AAC, H.264 don't work
The only one I can answer...
I use Autosol for cleaning exhausts.
http://www.halfords.com/motoring/car-cleaning/shampoo-polish-wax/autosol-metal-polish-75ml
Lots of good polishes for tailpipes but IME not much beats Mothers Mag and Aluminium Polish https://www.amazon.co.uk/d/0ed/Mothers-05100-Mag-Aluminium-Polish-5oz/B00068GEJM
Also good is Britemax twins - cleaner/polish and sealant   https://www.amazon.co.uk/s/?ie=UTF8&keywords=britemax+twins&tag=googhydr-21&index=automotive&hvadid=39471473894&hvpos=1t1&hvnetw=g&hvrand=3302598226648463475&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006602&hvtargid=kwd-60468733414&ref=pd_sl_tklse9h5i_e
Key is to keep on top of them then you won't need anything too abrasive to get them back to their best.  There are many other suggestions, including some less orthodox ones, everyone has their favourites, lol.  Lots of threads on it in the Detailing section.  Here's a few:
http://www.vwroc.com/forums/topic/16562-cleaning-exhaust-tips
http://www.vwroc.com/forums/topic/15650-how-to-remove-carbon-on-tailpipes
http://www.vwroc.com/forums/topic/14149-what-do-people-use-on-the-exhaust-tips
http://www.vwroc.com/forums/topic/13673-cleaning-the-tips
No the two things are different.  Shifting the gearbox into S is the same as the gearbox setting in Race Mode. Changing DCC to Sport does not put the gearbox into S. DCC (Dynamic Chassis Control) is the ability to alter the suspension (firmer to softer), and the responsiveness and feedback of the steering (heavier to lighter) depending on whether you select Sport, Normal or Comfort.  DCC is an optional extra so not all cars have it but obviously they still have the ability to have the gearbox in D or S (DSG).
VCDS Instructions:
12. Headlight washer frequency
To extend the interval cycles that the headlight washers will activate to:-
a ) prevent the front of your clean car being sprayed, and
b ) to reduce the amount of screen wash usage.
1. Go to [09] Central Electronics
2. STG access permissions -> Function 16
3. Enter access code 31347
4. Go to adaptation channels (Function 10)
5. Select channel 1 - Select "Number of operations front windsceen wiper washer per SRA activation" (in German - Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen)
6. Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate).
7. Select channel 3, and adjust the activate time for folding the switch to enable headlight washers in the first place
I couldn't figure this out but this is another way to do it lifted from GolfMK7 forum:
2. The better way (as suggested by Finglonga) is to get hold of a forum colleague that has a VCDS, or OBD11 cable and ask him/her to change the settings on the BCM - telling it that the pump is not installed. This is done by placing a tick in Byte 13, Bit 3 of the control module at address hex09 (the VCDS/OBD11 cable owner will understand what this means)
You can also pull the fuse or the plug but I've got no idea where to start with that route.
On the topic of modes in a DSG car... is it possible in a DSG to have the four exhausts open but prevent the auto box revving to the heavens?
Yes! Can be done with a VCDS tweak. I will warn you that it does get droney around town at the lower rev range.
Video Instructions below. Excuse the awful music!!
Cheers. I use my manual in this "mode" all the time. Never notice a drone.
I have an OBD11 but no android device yet. Need to look up the procedures over the Xmas period.
With the stock setup depending on the RPM, throttle pedal position and speed the flaps will still open and close even in Sport Manual mode. - People say it doesn't happen but I have video evidence to prove otherwise! That's why when you open the flaps there's so much more noise all the time as the flaps aren't operating at all.
As for drone, I think it depends person to person as some say it isn't too bad and others are quite susceptible to it.
An easy way to stop it is to just pull the stalk as quickly as possible and then let go. Then pull the stalk normally to clean the screen for as long as necessary. The first quick pull tricks the car into thinking it's sprayed and as a result doesn't spray the subsequent one.
