LordR Posted January 19, 2017 Report Share Posted January 19, 2017 Were you expecting something different? White LED's are the standard footwell lights. Some of us prefer to swap the units over for coloured LED's, such as blue, red etc, to add a bit of colour to the cabin. Like in here. http://www.vwroc.com/forums/topic/13007-mk7-r-how-to-replace-white-footwell-leds-with-blue-leds/ The brightness of footwells can be adjusted in car settings menu: CAR - SETUP - LIGHT - INTERIOR LIGHTING - FOOTWELL LIGHTING - choose desired % of brightness. Well yes if I'm honest haha the boot and glove box seem to be on normal 'yellow' bulbs so i just thought the previous owner changed the well ones. Better for me anyway as i don't have to change them. i think I've got some 501 led's hanging around for the ones mentioned which are yellow. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 19, 2017 Report Share Posted January 19, 2017 Well yes if I'm honest haha the boot and glove box seem to be on normal 'yellow' bulbs so i just thought the previous owner changed the well ones. Better for me anyway as i don't have to change them. i think I've got some 501 led's hanging around for the ones mentioned which are yellow. Lol. Yes, VW cheaped out on the glovebox and boot lights and just used LED's in the lights that showed. The glovebox is your standard 501 led but the boot is a 42mm festoon, like these. http://www.ebay.co.uk/itm/4-SMD-Festoon-Canbus-44mm-42mm-SV8-5-C10W-264-LED-Canbus-interior-Car-Bulb-White-/331825001478?hash=item4d424fb406 Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
rbel5553 Posted January 20, 2017 Report Share Posted January 20, 2017 Yes it makes a hell of a diffenerence, lower shift points, lazier behaviour and the inner exhaust valves are closed, same if you go into manual mode from D or S. I leave mine in Normal or Individual most of the time and just pull the gearstick back to go into S. Uh? Your last comment Rich: Does the gearbox go back to normal (lower) shift points when you push the knob to the left for manual while in S that has been activated at the knob (pull back) rather than within Mode ? I'm sure I had not noticed that. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
rbel5553 Posted January 20, 2017 Report Share Posted January 20, 2017 Oh! Another thing. I hired a new Fiesta today to drive for five hours. I rolled out through the door onto the pavement. Ergonomic mind bender for me and a chiropractors dream I'd say. I only have one complaint in the Golf R and that is I think it should have a little more support under the thigh knee area. I am 5' 11". Otherwise I just love the extending centre arm and the arm on the drivers door for my elbows and the steering wheel is held at about 9 and 3 when cruising. It's a great place to be. Unlike my Fiesta experience. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Boj27 Posted January 20, 2017 Report Share Posted January 20, 2017 travel mode in the light menu in discover nav - stupid question. for the uk, should it be set to left side or right side? i cant work out whether its asking if i drive on the right, or whether the topposing traffic is on the right! Anyone? Quote Link to comment Share on other sites More sharing options...
Lustral Posted January 20, 2017 Report Share Posted January 20, 2017 Anyone? Left side for UK roads Rich_D 1 Quote Link to comment Share on other sites More sharing options...
Rich_D Posted January 23, 2017 Report Share Posted January 23, 2017 Uh? Your last comment Rich: Does the gearbox go back to normal (lower) shift points when you push the knob to the left for manual while in S that has been activated at the knob (pull back) rather than within Mode ? I'm sure I had not noticed that. No, that is only for automatic mode, if you go from D into manual the exhaust valves will remain closed, if you go from S into manual, the exhaust valves are open and it will also pop & burble on overrun, I always like to go from S to manual. In manual mode you control the shift points, it will only change gear under 3 condtions; 1) you are at the rev limiter so the car needs to upshit, the revs are too low, so the car needs to downshift, 3) you've mashed the throttle pedal and hit the kickdown switch. rbel5553, Scirocco32 and SoggyBottomBoy 3 Quote Link to comment Share on other sites More sharing options...
Rich_D Posted January 23, 2017 Report Share Posted January 23, 2017 Does everyone have led's in the foot wells in the front? Yes, they are standard, you can alter the brightness in the menu, mine are at 20% now IIRC Quote Link to comment Share on other sites More sharing options...
__tophe Posted January 28, 2017 Report Share Posted January 28, 2017 Hi all. Has anyone removed the 'carbon effect' trim on their doors? (That run along the blue led lighting / door handle) ... I think it's time for an upgrade Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
LordR Posted January 28, 2017 Report Share Posted January 28, 2017 Has anyone managed to take off the front headrest? want to remove for a good clean. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 28, 2017 Report Share Posted January 28, 2017 Has anyone managed to take off the front headrest? want to remove for a good clean. Some instructions on how to remove headrests in here. http://www.vwroc.com/forums/topic/15754-removing-head-restraints-on-front-seats-mk7-g7r/?p=260553 SoggyBottomBoy 1 Quote Link to comment Share on other sites More sharing options...
Soche Posted January 29, 2017 Report Share Posted January 29, 2017 QQ - how much memory comes on the navpro ssd? How much space for music? Was under the impression there was 64gb but when I went to import my 30gb music collection from a USB it says there is only 11gb available space. I realise the navigation software is installed but surely it doesn't take up 50gb? I only had a small fiddle in the rain and there is no music stored on it currently. Any help greatly appreciated, I couldn't find an answer from searching on this topic Quote Link to comment Share on other sites More sharing options...
roberth Posted January 29, 2017 Report Share Posted January 29, 2017 QQ - how much memory comes on the navpro ssd? How much space for music? Was under the impression there was 64gb but when I went to import my 30gb music collection from a USB it says there is only 11gb available space. I realise the navigation software is installed but surely it doesn't take up 50gb? I only had a small fiddle in the rain and there is no music stored on it currently. Any help greatly appreciated, I couldn't find an answer from searching on this topic 10GB, look here http://www.volkswagen.co.uk/technology/navigation-and-entertainment-systems/discover-nav-pro Soche 1 Quote Link to comment Share on other sites More sharing options...
LordR Posted January 31, 2017 Report Share Posted January 31, 2017 Can anyone help on how i can remove the gloss black grill vents off the front bumper? Quote Link to comment Share on other sites More sharing options...
wolverine Posted February 1, 2017 Report Share Posted February 1, 2017 1. Can someone please instruct me how to the left hand mirror dips on reverse? I've got it selected on the menu however it's not doing it. I've tried everything. Doesn't seem to want to dip 2. When locking (keyless) I've noticed pressing twice seems to lock again. Is this actually double locking or setting anything? Also is there a way of making the alarm beep when locking? Quote Link to comment Share on other sites More sharing options...
