Booth11 Posted March 14, 2024 Report Share Posted March 14, 2024 21 minutes ago, G.aero said: i'm just looking to buy a mk7-7.5 R again , is that keyless option worth it ? with the start button 😘 It’s a Marmite thing - some love it, some hate it and actively disable it. On some models this is easily done, on others you might need to code it off (depends on the year of the car). You’ll often read a lot of fear mongering about keyless theft and whilst it can happen of course, the fact is (using this forum as an example) the vast majority of theft of keys is a result of house break-ins. I’m in the ‘love it’ camp. G.aero, MJC1216 and gregozedobe 2 1 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted March 17, 2024 Report Share Posted March 17, 2024 On 14/03/2024 at 23:48, G.aero said: i'm just looking to buy a mk7-7.5 R again , is that keyless option worth it ? with the start button 😘 Not for me. I use the remote to lock the car and switch off keyless entry (as a probably not needed extra security measure). I didn't have a choice as it came std in my country, but I wouldn't pay extra for it. G.aero 1 Quote Link to comment Share on other sites More sharing options...
G.aero Posted March 20, 2024 Report Share Posted March 20, 2024 On 17/03/2024 at 08:24, gregozedobe said: Not for me. I use the remote to lock the car and switch off keyless entry (as a probably not needed extra security measure). I didn't have a choice as it came std in my country, but I wouldn't pay extra for it. to be fair , the only thing i like is the start engine button , prefer it than the classic key start 😏 Quote Link to comment Share on other sites More sharing options...
rRRRM Posted March 21, 2024 Report Share Posted March 21, 2024 why would you want another Golf R from a maker who has had known issues for several years, with several new models, none of which fixed those issues?? The main issue I am referring to is the coolant pump/thermostat leak which is expensive to fix (and will recur anyway). Quote Link to comment Share on other sites More sharing options...
G.aero Posted March 22, 2024 Report Share Posted March 22, 2024 19 hours ago, rRRRM said: why would you want another Golf R from a maker who has had known issues for several years, with several new models, none of which fixed those issues?? The main issue I am referring to is the coolant pump/thermostat leak which is expensive to fix (and will recur anyway). They are a few manufacters out there with coolant pump issues as a common fault , to be fair is not that difficult and expensive to do it , i will plan to do it alone . apart from that , this TSI ea888 is quite reliable . when i had the MK7 R Manual owned for more than 40k miles , didnt have any issues . the same for my mk 7.5 R Dsg , owned for 1 year no issues again . but for my old mini cooper s R56 N18 , it was the first job i did as it failed quite fast . Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted March 23, 2024 Report Share Posted March 23, 2024 On 22/03/2024 at 16:44, G.aero said: They are a few manufacters out there with coolant pump issues as a common fault , to be fair is not that difficult and expensive to do it , i will plan to do it alone . apart from that , this TSI ea888 is quite reliable . when i had the MK7 R Manual owned for more than 40k miles , didnt have any issues . the same for my mk 7.5 R Dsg , owned for 1 year no issues again . but for my old mini cooper s R56 N18 , it was the first job i did as it failed quite fast . Given how long this very common leaking thermostat housing problem has been going on my take is that VW don't really want to fix it, mainly because of all the extra money VW and their dealers are getting from fixing them all the time. If all VW's markets (not just the US) had class actions and it was costing VW their profits then they might actually make a revision that worked properly. Quote Link to comment Share on other sites More sharing options...
rRRRM Posted March 30, 2024 Report Share Posted March 30, 2024 You know how the matting fabric on the underside of the bonnet shrinks and falls down (and BTW VW refused to replace mine under w'tee) , weeeelll a similar-looking fabric in my rear wheel arches is doing the same. Unfortunately, I only noticed it yesterday and my w'tee has expired. I don't think it will fall down but it has shrunk. Anyway, this has left a gap at the edge where the fabric should meet the bodywork, and high-pressure rainwater and mud would be injected behind the fabric. I reckon it might remain there and possibly cause problems like rust. I've become unable to mess about to see what gives behind the fabric. What do you think? Quote Link to comment Share on other sites More sharing options...
Crick Posted May 16, 2024 Report Share Posted May 16, 2024 Pipe / holes / bags / cover evening all Should this pipe (possibly a breather) be connected to anything or just swinging in the wind ? Front of the engine near the fan. Either side of the engine bay, should these holes have blanking plugs ? Does the smaller one have a cable clip usually ? Also either ide of the engine bay I have what looks like rolled up plastic bag/sheet stuffed up cavity. Not the best picture but you can see it through the hole ... Anyone else have this ? Was my car a drugs mule in a previous life 😆 and finally, the rear seat latch cover. Mine isn't flat but wont push down/home. The seat still latches and releases fine but the red indicator doesn't pop up. Does it need some more 'persuasion' or can the mechanism be released and tension taken off perhaps ?? Thanks for any advice Crick Quote Link to comment Share on other sites More sharing options...
Phoenix Posted June 20, 2024 Report Share Posted June 20, 2024 I’m sure there are lots of options, but can anyone suggest a decent set of I believe what they call Dsg paddles.Standard ones are a bit of a faff when you’re cornering and trying to shift Cheers guys.Assume there an easy swap over for the mechanically challenged Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 20, 2024 Report Share Posted June 20, 2024 1 hour ago, Phoenix said: I’m sure there are lots of options, but can anyone suggest a decent set of I believe what they call Dsg paddles. Standard ones are a bit of a faff when you’re cornering and trying to shift Cheers guys. Assume there an easy swap over for the mechanically challenged Sent from my iPhone using Tapatalk It’s an old thread but has lots of ideas for paddles through its pages ranging in price from cheapo to expensive. I had two different sets of replacement paddles on my mk7 - S2T ones and nczworks illuminated ones but I think they don’t ship the latter anymore, only provide the digital file for 3D printing. Both were brilliant. Might give you some ideas. holy_piranha and Phoenix 2 Quote Link to comment Share on other sites More sharing options...
Midlife Driver Posted August 15, 2024 Report Share Posted August 15, 2024 I just today came across a US website that ships internationallyDsg-paddles.comThey have some nice looking things in the mid range budget band. Most paddles I see are either super cheap (and therefore make me suspicious) or are 170+.This website has paddles starting from about 40 and website looks decent. I might take a punt on a set myself.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Crick Posted October 22, 2024 Report Share Posted October 22, 2024 Is folding in the mirrors using the control on the door limited by speed ? Twice I’ve been down the same lane around 35-45mph and tried to fold the mirrors in and they don’t move. Stationary they work fine, locking the car they fold in too. thanks Crick Quote Link to comment Share on other sites More sharing options...
1nfinite Posted August 23, 2025 Report Share Posted August 23, 2025 I am having difficulty getting this crankshaft sensor connector off, is in a very awkward place for big hands to reach. I tried lifting the grey clip up, dont want to force it. Quote Link to comment Share on other sites More sharing options...
Mark55bn Posted August 29, 2025 Report Share Posted August 29, 2025 Hi guys, quick question about the speedo/ revcounter in my 7.5 R. The numbers are brighter around the needles but quite dim elsewhere on the dials. Is this normal or is there a setting where you can make it all the same brightness? Quote Link to comment Share on other sites More sharing options...
1nfinite Posted May 5 Report Share Posted May 5 Anyone know how to reset the 02 Lambada sensor 1 on the turbo? Or does it do it automatically. I recently installed & cant find anything in obd11 for a reset. Quote Link to comment Share on other sites More sharing options...
