Guy Incognito
Quick question!
My 7.5 has memory seats which I've been able to set, however it will only "remember" just one step above the lowest height, and each time I hop in the car I have to adjust it. I've tried saving it again but nothing. It's not a big deal, but does anyone have any idea?
Mk7.5 - Have any of you found a good solution for lining the small pocket to the right of the steering wheel (other than not using it!)?
The wife keeps her chapstick and gum in there and they rattle about and it drives me nuts!
Maybe try some of that non-slip waffle type material (most hardware places should sell it)  ?  Even if it doesn't stop them moving around completely it should dampen down the noise they make.
Owners have used adhesive flock lining for this problem.  There’s loads on eBay and Amazon at varying prices, e.g,
Ebay
Amazon
I need to replace an aftermarket brushed stainless steel bumper protector plate on a Mk7 estate.  Some muppet damaged mine and kinked up the edge of the steel plate (long story, don't ask...).
Does anyone know if there is any appreciable difference in the lip profile of the rear bumper between pre- and post-facelift Mk7 estate?
Only asking because the best looking replacement that I can find says it's for post-facelift Mk7.  I can't see any obvious difference in the lip of the newer bumpers but would be grateful if anyone has any better info!  Thanks!
  • 3 months later...
  • 3 weeks later...
Hi, I’ve tried searching for this with no success, so apologies if it’s been covered before. I prefer to have the main central display showing the Sport Display option. So three dials with the central dial larger than the two either side. What drives me mad is I have to select it every time I start the car otherwise it defaults to the screen showing mpg, ave mpg, journey time etc.
Is there anyway to have the Sport Display as the default screen on startup ?
The 3 gauges central display on my Mk7.5 R stays the same (persists) after I switch the engine off and then back on later.  Is your car a Mk7 ?  Maybe they are different somehow.
On 14/02/2024 at 22:36, gmtsteve said:
It’s a my17, so technically a mk7.5. Maybe you have some settings differences to me that makes the difference. I’d love to know what they may be.
Mine is an MY18 (built June 2017).  I never change the centre display, and I don't use the nav, phone or infotainment system, do you ?
  • 3 weeks later...
