AddyT Posted May 24, 2021 Report Share Posted May 24, 2021 Thank you very much to both of you for the advice! The new set is ideally in early July so not far away. I didn’t know you could now get the 4S for 18’s so I will check those out definitely 👍 I’ve only had the car since February so it must have been the last owner who had a puncture. Based on your thoughts I think I’d better leave it be and sit tight for a new full set. Thank you very much for your help and I really appreciate it! 😊 Wagon R 1 Quote Link to comment Share on other sites More sharing options...
v7fmp Posted May 25, 2021 Report Share Posted May 25, 2021 brake bleeding... i am fitting my Racing Line BBK with braided lines front and rear soon. Are there any guides, tricks or things to watch out for when bleeding the brakes? I have done it on previous cars before, but they have been lets say... less technologically advanced compared to my Mk 7.5 R. thanks! Quote Link to comment Share on other sites More sharing options...
Swerve Posted May 26, 2021 Report Share Posted May 26, 2021 Hi all, nearly 4 months ownership and loving my estate but I have a question about the headlights, it’s a mk7 estate I always have them set on auto I have noticed while driving and the day driving lights are on that it seems that the edges seem brighter is this correct ? Quote Link to comment Share on other sites More sharing options...
Martin2 Posted May 26, 2021 Report Share Posted May 26, 2021 On 24/05/2021 at 18:19, AddyT said: A quick question if OK! Just had my R serviced and as I suspected following the health check, the fronts are getting closer to that 3mm mark - 3.5mm as it stands. I have noticed a drop off in wet weather grip recently, particularly with one road near my village which wasn’t great. I will get some PS4’s and buy a set all round - running 18” Cadiz. My question is at the rear its 4.5mm and 6mm. Would people swap these round for now as thats quite a bit left or get rid anyway? Thank you in advance! 😊 It depends on how many miles you do. If it isn't several thousand a month, then I'd wait a month and replace all 4 with the PS4 / PS4S or F1 SS. I think the 4S are £170 vs £100 for the 4 and about the same for the F1 SS, so I'd probably get the Goodyears as they've had good reviews in group tests and on this forum. Quote Link to comment Share on other sites More sharing options...
Raiden Posted July 10, 2021 Report Share Posted July 10, 2021 I’ve had this pop up a couple times now. Any reason why?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Emjayholla Posted July 15, 2021 Report Share Posted July 15, 2021 Possible A/C condensation drain issue? Picture is from the passenger side of the car (2019 Golf R). Have been noticing large puddles of water lately, anytime I move the car, even if I haven’t ran the A/C for a day or so. Is the A/C supposed to drain directly onto this piece of metal under the car and pool up? Photo of Wet Part Under Front Passenger Side Quote Link to comment Share on other sites More sharing options...
Wagon R Posted July 15, 2021 Report Share Posted July 15, 2021 On 10/07/2021 at 15:16, Raiden said: I’ve had this pop up a couple times now. Any reason why? Sent from my iPhone using Tapatalk Do you have an SD card in the unit that may have developed errors? Maybe a CarPlay/AndroidAuto dongle that may need a firmware update plugged in?? Quote Link to comment Share on other sites More sharing options...
Wagon R Posted July 15, 2021 Report Share Posted July 15, 2021 4 hours ago, Emjayholla said: Possible A/C condensation drain issue? Picture is from the passenger side of the car (2019 Golf R). Have been noticing large puddles of water lately, anytime I move the car, even if I haven’t ran the A/C for a day or so. Is the A/C supposed to drain directly onto this piece of metal under the car and pool up? Photo of Wet Part Under Front Passenger Side I believe the A/C drain tube pokes through the lower grill on the driver’s side …at least it does on my 2017! Are you losing any coolant? Try dabbing it with a tissue to see if it smells or has any colour! Don’t lick it though, it could be animal pee. 😁 Quote Link to comment Share on other sites More sharing options...
Raiden Posted July 15, 2021 Report Share Posted July 15, 2021 Do you have an SD card in the unit that may have developed errors? Maybe a CarPlay/AndroidAuto dongle that may need a firmware update plugged in??I have go one in there will some music on it. I’ll scan it the weekend and maybe re upload the tunes Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Raiden Posted August 2, 2021 Report Share Posted August 2, 2021 This new E10 fuel coming to the pumps soon. I assume the MK7 will run ok with it?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
slider09 Posted August 2, 2021 Report Share Posted August 2, 2021 This new E10 fuel coming to the pumps soon. I assume the MK7 will run ok with it?Sent from my iPhone using TapatalkOnly affects the 95 ron fuel, which you should be using anyway.Sent from my iPhone using Tapatalk Raiden 1 Quote Link to comment Share on other sites More sharing options...
marshy Posted August 2, 2021 Report Share Posted August 2, 2021 All the Tesco 95 pumps round here have been E10 for over a month.Good old momentum is still E5 thoughSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
AddyT Posted August 2, 2021 Report Share Posted August 2, 2021 Hi All, Apologies if this has already been covered. Aside from retrofitting Dynaudio which I think is expensive(?), what are the recommendations for upgrading the speakers? Am open to replacing the spare wheel for a sub like the Dynaudio setup but not essential. Just also interested if people have chosen to upgrade the other speakers in the car, and if so, what to? 😊 Quote Link to comment Share on other sites More sharing options...
mustard Posted August 9, 2021 Report Share Posted August 9, 2021 So each gallon/litre produces less pollutants, yet it gives fewer miles, so you end up using more to go the same distance and then presumably producing the same amount of pollutants, or am I missing something? Wagon R and Shug 2 Quote Link to comment Share on other sites More sharing options...
Ryphon Posted August 12, 2021 Report Share Posted August 12, 2021 I've got my driver's seat as low as possible as my preferred seating position. However it seems every time I get back in the car, it has adjusted itself slightly up. Anyone experience this? 2020 Mk7.5 R. Quote Link to comment Share on other sites More sharing options...
