Wagon R Posted February 23, 2021 Report Share Posted February 23, 2021 1 hour ago, Swerve said: A couple of quick questions can someone tell me what a GPF is please read about it all over the forum and I know it’s to do with the exhaust but what does it do? Is better with one or without and how can I tell if my car has one I have a 66 plate estate. Second question do the estates have a flapper valve exhaust system when I looked on line the system looks so different to the hatchback model? sorry if these are silly questions I just have not a clue lol cheers Very basically, the Gasoline Particulate Filter (...AKA Petrol PF) reduces the soot particles and harmful gasses emitted from the engine by catching them in a chamber in the exhaust system, similar to a Diesel PF. I’m not sure whether they need the same regen (burning off) as a Diesel or not though ...sure someone else can fill in the gaps, as that could/should make all the difference in your purchase. Estates don’t have the valved exhaust! Sound is increased slightly when the engine is up to temperature and you select Race mode. HTH. Swerve 1 Quote Link to comment Share on other sites More sharing options...
NRW Posted February 24, 2021 Report Share Posted February 24, 2021 The GPF/PPF/ and even Otto Particulate filters are fitted to All R Golfs registered after March 2019. There may be some earlier, but rare. The engine was detuned to 300Ps. Down from 310 Ps for the earlier Facelift R models, with the Full digital dash and 7sp DSG/ 6sp Manual. Generally tuning / exhaust options are not so widely or readily available. Think if you have a 66 plate Mk7 R Wagon with Analogue dash (proper dials) then just about impossible (!) that you will have GPF exhaust system fitted. Generally the earlier 300Ps and 310 ps cars are easier to tune for higher outputs and performance than the GPF equipped versions. HTH @Swerve Swerve and Wagon R 1 1 Quote Link to comment Share on other sites More sharing options...
Raiden Posted February 25, 2021 Report Share Posted February 25, 2021 Silly question but my 2015 R. Would the DSG box have a wet or dry clutch?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 25, 2021 Report Share Posted February 25, 2021 1 hour ago, Raiden said: Silly question but my 2015 R. Would the DSG box have a wet or dry clutch? Being a Mk7 R it will have DQ250 DSG with a wet clutch. Raiden 1 Quote Link to comment Share on other sites More sharing options...
NRW Posted February 27, 2021 Report Share Posted February 27, 2021 Servicing Question Please. My R (much loved) will reach its Second birthday on 28.3.21. I have a Service Plan in Place for the first 3 services with Pulman Vw Durham - supplying dealer, who I find very good. Awkward question; My First service was cancelled due to Lockdown last year. So it did not go ahead in March, and was not done until 24.8.20 at 4380 miles. The current mileage due to restrictions is only 5281, so by the end of this month not likely to be more than 5500 miles. Less than 1200 miles since last serviced. Do I get it done at the end of March or leave it until August and then get the Third service & MOT done on or around the 28. March 2022. The neatness of the Service History is at stake here 😂. Does it matter? Has OCD got the upper hand with me? Views and opinions welcome please. GoldenGun 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 27, 2021 Report Share Posted February 27, 2021 20 minutes ago, NRW said: Servicing Question Please. My R (much loved) will reach its Second birthday on 28.3.21. I have a Service Plan in Place for the first 3 services with Pulman Vw Durham - supplying dealer, who I find very good. Awkward question; My First service was cancelled due to Lockdown last year. So it did not go ahead in March, and was not done until 24.8.20 at 4380 miles. The current mileage due to restrictions is only 5281, so by the end of this month not likely to be more than 5500 miles. Less than 1200 miles since last serviced. Do I get it done at the end of March or leave it until August and then get the Third service & MOT done on or around the 28. March 2022. The neatness of the Service History is at stake here 😂. Does it matter? Has OCD got the upper hand with me? Views and opinions welcome please. If it were me, I’d revert back to the original service schedule of end March and just swallow the fact that it’s barely moved since the last one. 😁 NRW 1 Quote Link to comment Share on other sites More sharing options...
GoldenGun Posted February 27, 2021 Report Share Posted February 27, 2021 I respect the OCD! 😬 NRW 1 Quote Link to comment Share on other sites More sharing options...
NRW Posted February 27, 2021 Report Share Posted February 27, 2021 2 hours ago, Booth11 said: If it were me, I’d revert back to the original service schedule of end March and just swallow the fact that it’s barely moved since the last one. 😁 Yes, thank you. I was leaning that way 😀. I’ll get it booked in. Quote Link to comment Share on other sites More sharing options...
SRW Posted March 5, 2021 Report Share Posted March 5, 2021 Rear calipers, are the wind in pistons handed, do I need a wind in tool with both handed threads? Thanks Quote Link to comment Share on other sites More sharing options...
marshy Posted March 5, 2021 Report Share Posted March 5, 2021 Rear pistons just push in and don’t turn.But before you do that you need either vcds or obdeleven etc to put the brakes in to lining change mode which in turn puts the motors back to allow you to push the pistons backSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SRW Posted March 5, 2021 Report Share Posted March 5, 2021 4 minutes ago, marshy said: Rear pistons just push in and don’t turn. But before you do that you need either vcds or obdeleven etc to put the brakes in to lining change mode which in turn puts the motors back to allow you to push the pistons back Sent from my iPhone using Tapatalk Thanks. I have obd 11, just waiting on axle stands now. Quote Link to comment Share on other sites More sharing options...
GaryP Posted March 12, 2021 Report Share Posted March 12, 2021 What is the recommended approach when buying a private sale used car that still has finance on it? Seems a reasonable and common thing to happen, but assume care has to be taken to ensure a safe transaction. Thanks. Quote Link to comment Share on other sites More sharing options...
Wagon R Posted March 18, 2021 Report Share Posted March 18, 2021 I’m hoping someone can answer two questions on the same part. Has anyone that fitted a full engine undertray had any issues with overheating since fitting, and does it prevent water splashing up into the engine bay? Mine is filthy with muddy splash from the amount of rain we’ve had this winter and I’m looking to fit one to prevent a repeat before I go wasting time and money buying something that doesn’t help to that end. Thanks. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted March 19, 2021 Report Share Posted March 19, 2021 5 hours ago, Wagon R said: I’m hoping someone can answer two questions on the same part. Has anyone that fitted a full engine undertray had any issues with overheating since fitting, and does it prevent water splashing up into the engine bay? Mine is filthy with muddy splash from the amount of rain we’ve had this winter and I’m looking to fit one to prevent a repeat before I go wasting time and money buying something that doesn’t help to that end. Thanks. If you have a DSG make sure you get an undertray with the vent for the DSG (some undertrays don't have the vent). Wagon R 1 Quote Link to comment Share on other sites More sharing options...
Wagon R Posted March 19, 2021 Report Share Posted March 19, 2021 11 hours ago, gregozedobe said: If you have a DSG make sure you get an undertray with the vent for the DSG (some undertrays don't have the vent). Thanks @gregozedobe That’s good to know - I wasn’t aware there were 2 different kinds ...and yes, mine is DSG. 👍 gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
