Guy Incognito
Thanks guys.
16 hours ago, gregozedobe said:
Try swapping wheels front to back (and back to front) to see if it moves to the rear.  If it doesn't it might be a warped disk (or pad deposits on a disk).
Next quick question, How can I do this with two jacks?! 😂
mccol is spot on with his advice ^
Even if you only had one jack you can still do it by using your spare as a temporary holder.  It just takes a bit more time and effort: take a back wheel off, put your spare on the back, take the front wheel off, put the wheel that was on the back on the front, take the spare off the back and replace it with the wheel that was on the front; repeat the exercise on the other side of the car.
16 hours ago, ilikecars said:
Would VW alloys on a VW need spigot rings? I mean, would standard Golf R Spielbergs need them, given they are on an R?
There are plenty of fakes out there that look like originals, and it’s only when you remove them you know for sure they’re VW’s own.
  • 3 weeks later...
1 minute ago, Swerve said:
I’ve been looking at getting a pedal box it’s states 3 different hp engines, I know mine is not a 310 but how do I know if mine is 296 or 300 ? I’ve got a 66 plate estate registered January 2017
cheers
Is it a DTUK box?  It’ll be exactly the same box regardless, just put 300 in.
  • 3 weeks later...
A quick question if OK!
Just had my R serviced and as I suspected following the health check, the fronts are getting closer to that 3mm mark - 3.5mm as it stands. I have noticed a drop off in wet weather grip recently, particularly with one road near my village which wasn’t great. I will get some PS4’s and buy a set all round - running 18” Cadiz. My question is at the rear its 4.5mm and 6mm. Would people swap these round for now as thats quite a bit left or get rid anyway?
Thank you in advance! 😊
It depends on how soon you’re going to get the new set?
In reality, it’s always better to have more tread depth at the rear than the front because understeer is usually more predictable/easier controllable, and therefore safer, than oversteer. As it is, the fronts will let go first …which is how you want it.
I’d be more interested to know how you ended up with 4.5 and 6mm at the rear - had a puncture along the way?
I’m of same mind as Wagon R (Strawbs) in that you’re better to have the most tread in the rear so I’d not rotate them.  If you’re going to replace the fronts now and you can stretch to a full set given one of your rears is at 4.5mm then I’d go new PS4s all round or even PS4S possibly (now available for 18s).  Like Wagon R I’m intrigued as to the difference in your rears but sounds like one might have been replaced at some point?
