DRL brightness
Hi, Is anyone have any eperience how to increase the brightness of DRL? do I need to change bulb? I've tinted headlights smoke grey so DRL brightness slightly got compromised. Thanks
Any pictures of your tinted headlights bud?
No bulbs required its a mod carried out with either VCDS or OBD11, I've increased mine too 100%.
25 minutes ago, R-Estate said:
Is it not the case that you can only increase the brightness of the U's while the headlights are on. I increased mine from 28% to 50% which is bright enough for me. In DRL mode they're 100% as default.
Awww so thats mean Its already 100% as a day running light, cannot be increased further? I am not worried about with headlights on.
4 minutes ago, R-Estate said:
Unfortunately not, unless the 7.5 set up is different to the 7. Stupid question but does it still have the double U's?
If so then you should find (if you have access to VCDS) that the outer U is set to 100 and the inner U to 127. These are the maximum values.
Yes my car have double U's and I don't have access to VCDS or OBD at the moment, I bought my car few months ago still learning about golf R. Thanks for your help anyway. I'd  probably think about changing to lighter tint.
