tortoise99 Posted August 6, 2017 Report Share Posted August 6, 2017 Hi, My R had its first service last week (@ ~11,000 miles). In the film the VW garage did, the technician pointed out that the front tyres are wearing slightly more on the inside - in his opinion it was because they were under inflated. I was surprised to hear that as I check the pressures fairly regularly and make sure the psi is as per the sticker inside the car. I am still on the original set of bridgestones by the way. was the technician talking rubbish? Or should I put a bit more air in my tyres? I am fairly sure the tracking is ok. Quote Link to comment Share on other sites More sharing options...
mickR Posted August 6, 2017 Report Share Posted August 6, 2017 Do you check pressures when tyres are cold?Is your pressure gauge certified accurate?Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
NinkyNonk Posted August 6, 2017 Report Share Posted August 6, 2017 Both inner and outer edges wearing would point to under inflation, just the inner edge would point to alignment. Most cars of a sporty nature with low profile tyres will wear the inner edge first. My old modified Focus ST would take a couple of mm extra off the inside edge over the life of a tyre, and the alignment figures were always spot on. I have 2 pressure gauges that I use and they both read very similar, although VW seem to inflate the tyres to 40psi, not 38psi as per the pillar sticker. Guessing they don't use a pressure gauge, and probably use one of those naff air line inflators you see at garages and managed to get a few extra psi in when they went around. Surprised they didn't try and swindle you for a full alignment. From what I've gathered over the last few months with mine, do not believe anything the dealer ever says to you and you'll be fine. tortoise99 and andy86r 2 Quote Link to comment Share on other sites More sharing options...
TuftyR Posted August 7, 2017 Report Share Posted August 7, 2017 My sticker says 36 psi! I am on Cadiz too. Quote Link to comment Share on other sites More sharing options...
Limey Posted August 7, 2017 Report Share Posted August 7, 2017 My Cadiz sticker is 36 also, but I run them at 34. There is only me in the car 99.9% of the time and the wear is perfect and it helps with the ride quality. Dave Lee63 1 Quote Link to comment Share on other sites More sharing options...
Lee63 Posted August 7, 2017 Report Share Posted August 7, 2017 Same here, mine is on 18" cadiz and states 36 psi for low load but i have mine at 34 psi all round. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
tortoise99 Posted August 7, 2017 Author Report Share Posted August 7, 2017 15 hours ago, mickR said: Do you check pressures when tyres are cold? Is your pressure gauge certified accurate? Sent from my iPhone using Tapatalk Pro I go to my local petrol station and use its 50p a go air machine. It's fairly new so assume it's accurate (rightly or wrongly) - the tyres won't be stone cold. Quote Link to comment Share on other sites More sharing options...
tortoise99 Posted August 7, 2017 Author Report Share Posted August 7, 2017 Thanks guys - might try 34psi on the front. Quote Link to comment Share on other sites More sharing options...
NinkyNonk Posted August 7, 2017 Report Share Posted August 7, 2017 Sorry mine's an estate, guess they're different! Quote Link to comment Share on other sites More sharing options...
bigp2 Posted August 7, 2017 Report Share Posted August 7, 2017 Mine came with 40psi and I set them all to 36psi (18" Cadiz). Quote Link to comment Share on other sites More sharing options...
xPETEZx Posted August 8, 2017 Report Share Posted August 8, 2017 Do your cars all have the values in PSI on the door? Or are you converting? Mine only has Bar. Mine on 18" Cadiz has 2.8 Bar all round, which a quick google says is 40.6 PSI. Lee63 1 Quote Link to comment Share on other sites More sharing options...
thanksabunch Posted August 8, 2017 Report Share Posted August 8, 2017 Interesting you all say your R is wearing the inside edge of your tyres as mine has slightly worn the outside edge a little more on all 4 tyres! Alignment has been checked on hunter machine and all is good apparently! Also seems to drive and handle fine too People have told me the opposite about wear on sporty cars and that minor outer wear is indeed more normal due to hard cornering and fast roundabouts etc which makes more sense id say not much difference across the tyre if im honest, digital gauge read 5mm on inner edge and 4.3 on outer so about 0.7 difference across the tyre width Quote Link to comment Share on other sites More sharing options...
Lee63 Posted August 9, 2017 Report Share Posted August 9, 2017 Do your cars all have the values in PSI on the door? Or are you converting? Mine only has Bar. Mine on 18" Cadiz has 2.8 Bar all round, which a quick google says is 40.6 PSI. This is my sticker inside the door mate, the psi is the last number Sorry its on a side, better than upside down though ha haSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
