andy203 Posted December 19, 2017 Report Share Posted December 19, 2017 Have been on a long run today, when I got out noticed this clean well almost clean rectangular area. Has anyone else had the same appear? No it has not been wiped, and it appears in exactly the same place on the nearside as well. Quote Link to comment Share on other sites More sharing options...
Lew Posted December 19, 2017 Report Share Posted December 19, 2017 Weird 🤔 Quote Link to comment Share on other sites More sharing options...
stu-evans Posted December 19, 2017 Report Share Posted December 19, 2017 Radar sensor location for lane assist? Assume there's some heat build up that stops the moisture trap? Quote Link to comment Share on other sites More sharing options...
andy203 Posted December 19, 2017 Author Report Share Posted December 19, 2017 2 minutes ago, stu-evans said: Radar sensor location for lane assist? Assume there's some heat build up that stops the moisture trap? But I have not got Lane Assist, and here is a picture after doing a further 100 miles, you can still see original line/size, the clean patch has reduced in size. Not the best will take a picture tomorrow in daylight before she gets a clean. Quote Link to comment Share on other sites More sharing options...
stu-evans Posted December 19, 2017 Report Share Posted December 19, 2017 But I have not got Lane Assist, and here is a picture after doing a further 100 miles, you can still see original line/size, the clean patch has reduced in size. Not the best will take a picture tomorrow in daylight before she gets a clean.Well that's my theory scuppered then!! Quote Link to comment Share on other sites More sharing options...
phil4 Posted December 19, 2017 Report Share Posted December 19, 2017 My guess would be some sort of coating/adhesive that's been on there, made the area hydrophobic, hence less dirt. Odd though! Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 19, 2017 Report Share Posted December 19, 2017 ^^ That would be my guess - that there’s been a sticker or something on that bit, in the way that windscreen sucker marks come back seemingly forever until you finally clean them into oblivion. Shug 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted December 19, 2017 Report Share Posted December 19, 2017 Pocket in the bumper for blind spot radar looks like heat from the exhaust is seeping into it and drying the area on the surface ? Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted December 19, 2017 Report Share Posted December 19, 2017 Very odd... doesn’t happen on My 7.5R hatch but is yours an estate? Reminds Me of the cattle mutalation a few years ago 😳 Quote Link to comment Share on other sites More sharing options...
montecarlo Posted December 19, 2017 Report Share Posted December 19, 2017 The vent flaps in the body are exactly at this location behind the bumper. Here is a theory: It must have been quite cold outside and quite warm inside the car, so the air escaping out of the vents must have thawed out the icy, dirty spray from the tires. 😁 Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
DUB R4XX Posted December 19, 2017 Report Share Posted December 19, 2017 Here’s a pic of the vents mentioned above Booth11, Jon R306, Rob2k68 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 19, 2017 Report Share Posted December 19, 2017 15 minutes ago, DUB R4XX said: Here’s a pic of the vents mentioned above That looks like the culprit, with the edging round it which looks exactly like the OPs. Maybe the vent is horizontal/landscape orientation on the facelift / estate? Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
andy203 Posted December 19, 2017 Author Report Share Posted December 19, 2017 34 minutes ago, montecarlo said: The vent flaps in the body are exactly at this location behind the bumper. Here is a theory: It must have been quite cold outside and quite warm inside the car, so the air escaping out of the vents must have thawed out the icy, dirty spray from the tires. Will have to wait for warmer weather to see if the area continues to appear. This morning the air temp was 2.5+ roads were wet, on return trip this afternoon it was 6+ roads still wet, and the size of clear area reduced. Your theory may still be correct. Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
andy203 Posted December 19, 2017 Author Report Share Posted December 19, 2017 2 minutes ago, Booth11 said: That looks like the culprit, with the edging round it which looks exactly like the OPs. Maybe the vent is horizontal/landscape orientation on the facelift / estate? Yes mine is a 7.5 estate and looking at pictures of the vents if they are turned and there size would fit.... Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Ptl388 Posted December 19, 2017 Report Share Posted December 19, 2017 Yep i had the same thing after a run to scotland. Quote Link to comment Share on other sites More sharing options...
