WLAN
VWR2018
Anyone else having ridiculous issues with the length of time it takes to get the connection?
40 minutes yesterday including 3 disconnections and a reboot before it showed on the display 20 mins after despite the phone showing as it being connected from the start.
7.5R with the non-pro
I go through a process that works pretty well, and usually only takes a minute or two.... something like this:
  • iPhone onto personal hotspot screen.
  • Can into settings, then wifi, then click the phone's wifi.
  • Wait for the phone to indicate that something is connected.
  • Wait about 30 seconds, then go to the CAR-Net, repeatedly until it loads the menu items... by with the Wifi signal should show at the top.
  • Then go into traffic.  Check that it's downloaded hundreds of items, and isn't using TMC.  Go back into Car-Net updates, then traffic if not.
If all those work it's in pretty good shape, so then I usually plug the phone in, which then fires up Carplay/AppConnect.
I occasionally get disconnected... and indeed often go to areas with no phone signal, hence no wifi data.. but it works reasonably reliably considering.
Tonights run was over an hour and it still didn’t show the wlan
Settings show it was connected automatically
phone shows it was connected
yet zero car-net regardless of the number of times you tapped it.
going back on Monday as it’s developed rattles today as well
Well a 4hr run back.
Took almost half that before it even showed wlan on the display and there wasn't any connection at all.
Finally had connection 20mins from home and then promptly disappeared before I could actually select any of the options after the "please read"crap that pops up every time.
  • 11 months later...
Hello
Excuse me for replying to an old thread But..
I have a 2018 (2019) model year Golf 1.5 150 R Line DSG
I have the same issue with wlan. I try to connect to the hotspot on my phone
It simply wont connect at all to either my phone Huawei p20 Pro or a Galaxy s7
Which model WLAN USB stick with dedicated sim card slot should i choose. and how do i wire it to work in the boot.
Iam grateful for any advice.
James
4 hours ago, AndyCook said:
Hi James, try a search of then forums, there is already a post about it and I added photos to it too. Last year
Can you link me to the cable that you used. I looked to private message you but i cannot find out how to
James
