Nile Posted June 9, 2018 Report Share Posted June 9, 2018 Good morning! Has anyone used the current generation of Chipex to correct stone chips on Lapiz blue or Silver? Any good or bad experience to share please ? Thank you Quote Link to comment Share on other sites More sharing options...
stu-evans Posted June 9, 2018 Report Share Posted June 9, 2018 Good morning! Has anyone used the current generation of Chipex to correct stone chips on Lapiz blue or Silver? Any good or bad experience to share please ? Thank youInterested in the answers you get to this for lapiz too..... Quote Link to comment Share on other sites More sharing options...
Nile Posted June 9, 2018 Author Report Share Posted June 9, 2018 39 minutes ago, stu-evans said: Interested in the answers you get to this for lapiz too..... Reviews are good for it... a bit scared to use it on a front panel like a bonnet in case it goes pear shaped 🤔 stu-evans 1 Quote Link to comment Share on other sites More sharing options...
PhilC22 Posted June 9, 2018 Report Share Posted June 9, 2018 4 hours ago, Nile said: Good morning! Has anyone used the current generation of Chipex to correct stone chips on Lapiz blue or Silver? Any good or bad experience to share please ? Thank you When you say "current generation" have they recently changed the formulation? I bought a part-used lapiz kit from a forum member on here last year, so I guess he probably bought it in 2015 or 2016? No date on the box or labeling. Anyway, I have used it on a couple of small stone chips and it worked very well. Undetectable fix. Just don't overdo the supplied alcohol-based 'blender' solution. More impressively, I also used it to cover a thin scratch on the driver's side rear door, which was about 2 inches long. No idea how it happened. Probably some nupty in a car park. It wasn't a deep scratch, but you could catch your nail in it, so no way it was going to just 'polish out' (I did try using G3 scratch remover). Decided to use the Chipex paint (as I had it) rather than pay some smart repairer, and it worked well. If I told you exactly where it was, you could probably still see a very faint line, but an excellent result imo. The little "cotton buds" that come with the kit are much easier to use than the mini-brushes often supplied with touch-up kits. I applied polish on top when it was completely dry of course. The paint colour match itself (for the Lapiz a least) is spot-on. HTH. stu-evans 1 Quote Link to comment Share on other sites More sharing options...
Nile Posted June 9, 2018 Author Report Share Posted June 9, 2018 1 hour ago, PhilC22 said: When you say "current generation" have they recently changed the formulation? I bought a part-used lapiz kit from a forum member on here last year, so I guess he probably bought it in 2015 or 2016? No date on the box or labeling. Anyway, I have used it on a couple of small stone chips and it worked very well. Undetectable fix. Just don't overdo the supplied alcohol-based 'blender' solution. More impressively, I also used it to cover a thin scratch on the driver's side rear door, which was about 2 inches long. No idea how it happened. Probably some nupty in a car park. It wasn't a deep scratch, but you could catch your nail in it, so no way it was going to just 'polish out' (I did try using G3 scratch remover). Decided to use the Chipex paint (as I had it) rather than pay some smart repairer, and it worked well. If I told you exactly where it was, you could probably still see a very faint line, but an excellent result imo. The little "cotton buds" that come with the kit are much easier to use than the mini-brushes often supplied with touch-up kits. I applied polish on top when it was completely dry of course. The paint colour match itself (for the Lapiz a least) is spot-on. HTH. Ah! That's reassuring! I will give it a go then. Thank you Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted June 9, 2018 Report Share Posted June 9, 2018 i used chipex before on my arden blue vxr vectra very good kit and does work very well this was a few year ago now tho i do have a small stone chip on the TR at present and am thinking about getting a chipex kit again Nile 1 Quote Link to comment Share on other sites More sharing options...
SimR Posted June 10, 2018 Report Share Posted June 10, 2018 Has anyone used this on scratches, I have a small scratch to the base coat on my drivers door. Also some loading marks on the rear bumper. might give it a try before a visit to the Bodyshop. Quote Link to comment Share on other sites More sharing options...
tuono Posted June 13, 2018 Report Share Posted June 13, 2018 good post just ordered some👍 Quote Link to comment Share on other sites More sharing options...
Patrick Posted June 13, 2018 Report Share Posted June 13, 2018 Interested in this. Can anyone post some before and after shots? Quote Link to comment Share on other sites More sharing options...
SIMK7.5 Posted June 14, 2018 Report Share Posted June 14, 2018 Not used Chipex on any of the colours mentioned above but have used it on significant other's black Renault Clio after she had an 'altercation' with some railings. It's really easy to apply and covers up almost any type of paint damage, top tip is don't worry about applying it with the cotton bud type applicators that come with the kit. Tip the paint onto your (gloved) finger tip and smear it on, then you use a blending solution to smooth it all out, then apply polish/cutting compound once dry. It'll work well on scratches too, just use the finger tip method and 'rub' the paint into the scratch. If I ever need some for the R then I'll have no hesitation buying more (they do Oryx White). Nile 1 Quote Link to comment Share on other sites More sharing options...
Nile Posted July 22, 2018 Author Report Share Posted July 22, 2018 Brought the kit for Lapiz blue. sadly, it was a complete disappointment. The color match was not right, a bit darker, more like Atlantic blue. my recommendation is not to get the Chipex for Lapiz. Quote Link to comment Share on other sites More sharing options...
TweedsideR Posted July 22, 2018 Report Share Posted July 22, 2018 1 hour ago, Nile said: Brought the kit for Lapiz blue. sadly, it was a complete disappointment. The color match was not right, a bit darker, more like Atlantic blue. my recommendation is not to get the Chipex for Lapiz. That's interesting. I thought the same after I used Chipex on some very small chips on my Lapiz car. I put it down to something I did wrong but you seem to have had the same result, slightly darker, and certainly visible if you look carefully. However, it is a bit better-looking than the original chips! Quote Link to comment Share on other sites More sharing options...
Nile Posted July 22, 2018 Author Report Share Posted July 22, 2018 1 hour ago, TweedsideR said: That's interesting. I thought the same after I used Chipex on some very small chips on my Lapiz car. I put it down to something I did wrong but you seem to have had the same result, slightly darker, and certainly visible if you look carefully. However, it is a bit better-looking than the original chips! True! i will wait and possibly respray after collecting a few more. Quote Link to comment Share on other sites More sharing options...
slider09 Posted August 6, 2018 Report Share Posted August 6, 2018 Brought the kit for Lapiz blue. sadly, it was a complete disappointment. The color match was not right, a bit darker, more like Atlantic blue. my recommendation is not to get the Chipex for Lapiz.I had the exact same issue with Lapiz blue. Sent them an email and they sent a new paint bottle - haven’t tried it yet. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Nile Posted August 6, 2018 Author Report Share Posted August 6, 2018 6 minutes ago, slider09 said: I had the exact same issue with Lapiz blue. Sent them an email and they sent a new paint bottle - haven’t tried it yet. Sent from my iPhone using Tapatalk Possibly, I should do the same. please keep us posted regarding the new one. Quote Link to comment Share on other sites More sharing options...
