SpursMadDave Posted August 23, 2018 Report Share Posted August 23, 2018 They’re relatively cheap compared to PS4 too aren’t they? Can I put Goodyear on the back and PS4 on the front, or would I need to change all four?Will be fine, always better to change all 4 but not a huge issue especially on an R Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Martin2 Posted August 23, 2018 Report Share Posted August 23, 2018 I’ve got Bridgestones on my car (20” wheels) and there is hardly any tyre noise but there is very little unwanted noise at all. They don’t appear to be wearing all that well compared to the Goodyear’s I had on my old car and they are cheaper for this one (£220-£230 vs (£260-280) so I’ll give them a go next. Will be P4Ss on the Golf when the time comes to change. Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted August 23, 2018 Report Share Posted August 23, 2018 Tyre filters have always advised one wants the grip where the power is, and it’s predominantly to the front on the R. Worms are out But when braking, the backend goes light so that’s where you want the grip! (Shots fired! Over to you!)Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted August 23, 2018 Report Share Posted August 23, 2018 BIG can of worms, the R is FWD or AWD it is NEVER RWD so why put fresh rubber on the rear? If you have better rubber on the rear then the car will understeer way before it oversteers so completely pointless surely? If you have the fresh rubber on the front then less oversteer and if the back was to slip the AWD would correct it wouldn't it?Just getting the popcorn ready for the replies:popcorn:Sent from my SM-G935F using TapatalkFresh rubber on the rear - better traction out of corners - or anywhere tbh! My Cupra 280 was terrible for axle tramp. Never get that with my R.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
AgentFruit Posted August 23, 2018 Report Share Posted August 23, 2018 3 minutes ago, camelsac2002 said: But when braking, the backend goes light so that’s where you want the grip! (Shots fired! Over to you!) Sent from my iPad using Tapatalk No no no! You don’t want the grip where there’s no power, you want it where there IS power. If you’re braking, there’s no power going to the back wheels, light or not! Grip is needed at the front when you stop braking and power out of the bend. No shots being fired (I’ve had too much gin for that), just years of looking at tyre wear 😉 camelsac2002 1 Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted August 23, 2018 Report Share Posted August 23, 2018 No no no! You don’t want the grip where there’s no power, you want it where there IS power. If you’re braking, there’s no power going to the back wheels, light or not! Grip is needed at the front when you stop braking and power out of the bend. No shots being fired (I’ve had too much gin for that), just years of looking at tyre wear Read my post above yours mate. After years of front drive, I know where I like my new rubber! I’d rather have understeer than lift off oversteer - far easier to gather up! Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
AgentFruit Posted August 23, 2018 Report Share Posted August 23, 2018 1 hour ago, camelsac2002 said: Read my post above yours mate. After years of front drive, I know where I like my new rubber! I’d rather have understeer than lift off oversteer - far easier to gather up! Sent from my iPad using Tapatalk Mate-ess to you I loathe understeer, it’s designed for the masses. Give me oversteer any day. baz657 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 24, 2018 Report Share Posted August 24, 2018 Fresh rubber on the rear - better traction out of corners - or anywhere tbh! My Cupra 280 was terrible for axle tramp. Never get that with my R.Sent from my iPad using TapatalkAlways put new tyres on rears of all my RWD cars for that reason, used to have a Leon FR and got bad axle tramp on that too... on a normal FWD car I can understand the logic but not on the R as the Haldex and electric LSD would sort out any kind of oversteer pretty quickly wouldn't it? To be clear I'm not talking about moving near bald tyres onto the rear just part worn so the difference in grip front to rear would be very small anywaySent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted August 24, 2018 Report Share Posted August 24, 2018 14 hours ago, camelsac2002 said: After years of front drive, I know where I like my new rubber! I’d rather have understeer than lift off oversteer - far easier to gather up! I have to ask the question: Has anyone on here actually got any significant lift-off oversteer from a Mk 7 or 7.5 Golf R when driving on real roads (not just playing in the snow) ? I have tried to get my R to oversteer on a wet skidpan and the car simply didn't want to do it. I suspect the ESP, ABS & haldex are all programmed to avoid it. I can easily get understeer though (just go too fast on a slippery wet surface). Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 24, 2018 Report Share Posted August 24, 2018 I have to ask the question: Has anyone on here actually got any significant lift-off oversteer from a Mk 7 or 7.5 Golf R when driving on real roads (not just playing in the snow) ? I have tried to get my R to oversteer on a wet skidpan and the car simply didn't want to do it. I suspect the ESP, ABS & haldex are all programmed to avoid it. I can easily get understeer though (just go too fast on a slippery wet surface).My point exactly, I really do get the argument of putting new rubber on the rear, on a RWD absolutely, on a FWD yes I now see the benefits, even on a 4WD as it is possible to get slip, but on an AWD like an R? Everything is geared up electronically and mechanically to reduce oversteer, so the chances of the rear stepping out because you have slightly better grip on the front is minimal in sure.So really either option is absolutely fine, nobody is right or wrong either way imo just personal preference Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mainframe Posted August 24, 2018 Report Share Posted August 24, 2018 Personally I change all 4 tyres together every time - having roatated them over their life. Saves these discussions - plus also the heinous crime of mixing brandsF/R on the car. Aquaplaning in a high speed turn is the one scenario I can envisage where some front end slip is far easier to recover from from, than is the rapid oversteer, followed by over corrected tank slapper from bald rears (for the non- Ayrtons out there). I count myself in that group btw. adibordoy, Gavras and Booth11 3 Quote Link to comment Share on other sites More sharing options...
AgentFruit Posted August 24, 2018 Report Share Posted August 24, 2018 1 minute ago, Mainframe said: Personally I change all 4 tyres together every time - having roatated them over their life. Saves these discussions - plus also the heinous crime of mixing brandsF/R on the car. Aquaplaning in a high speed turn is the one scenario I can envisage where some front end slip is far easier to recover from from, than is the rapid oversteer, followed by over corrected tank slapper from bald rears (for the non- Ayrtons out there). I count myself in that group btw. Blimey you must be minted to be able to afford to change all four if one of a new set bites the dust. I don’t think anyone’s disputing rotating. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted August 24, 2018 Report Share Posted August 24, 2018 7 minutes ago, Mainframe said: Aquaplaning in a high speed turn is the one scenario I can envisage where some front end slip is far easier to recover from from, than is the rapid oversteer, followed by over corrected tank slapper from bald rears (for the non- Ayrtons out there). I count myself in that group btw. Anyone running bald tyres (whether front or rear) deserves whatever bad things happen to them. I just hope they don't injure any other innocent road users when they can't stop or steer (bald front tyres) or lose control of the rear end of their car (bald back tyres). SpursMadDave and Mainframe 1 1 Quote Link to comment Share on other sites More sharing options...
Mainframe Posted August 24, 2018 Report Share Posted August 24, 2018 1 minute ago, gregozedobe said: Anyone running bald tyres (whether front or rear) deserves whatever bad things happen to them (but I hope they don't injure any other innocent road users when they lose control). Illegal tyres are a deffo no no. But even legal tyres at edge of tread depth indicators, can have markedly reduced ability to displace standing water. Gavras 1 Quote Link to comment Share on other sites More sharing options...
Mainframe Posted August 24, 2018 Report Share Posted August 24, 2018 6 minutes ago, AgentFruit said: Blimey you must be minted to be able to afford to change all four if one of a new set bites the dust. I don’t think anyone’s disputing rotating. Change All four for wear. Chance to switch brands as per OP. Change in pairs for punctures- but stay in brand. ...would be logical deduction. Quote Link to comment Share on other sites More sharing options...
