SBN Posted August 18, 2018 Report Share Posted August 18, 2018 6 hours ago, Andy1a2b said: My previous car was an AMG C63 which had a nearly new set of these on and was very well behaved in cold and damp conditions , always felt secure and never had any scary moments. I’m not sure in them yet. Not sure how to describe them. Feel grippy but a bit ‘floaty’ Quote Link to comment Share on other sites More sharing options...
Stobsie Posted August 18, 2018 Report Share Posted August 18, 2018 On 06/08/2018 at 11:55, SBN said: Currently on prets, had conti 5’s followed by hancook Ventus. Couldn’t notice much difference between the two. About to get some 18’s so will prob go for rainsport 3’s because they are £63 each plus £10 shop voucher back per tyre. Otherwise would have gone for PS4 for about £90 a corner. Cracking tyre IMHO I'm sure you won't be disappointed. Quote Link to comment Share on other sites More sharing options...
Stobsie Posted August 18, 2018 Report Share Posted August 18, 2018 1 hour ago, SBN said: I’m not sure in them yet. Not sure how to describe them. Feel grippy but a bit ‘floaty’ What pressures you running them at? They have a soft sidewall construction & I found running them a couple of psi higher than recommended made an improvement. FBF 1 Quote Link to comment Share on other sites More sharing options...
Andy1a2b Posted August 18, 2018 Report Share Posted August 18, 2018 Anyone running Michelin CrossClimate-plus ? look a decent option and still quiet at 69 dB https://www.blackcircles.com/catalogue/michelin/crossclimate-plus/225/40/R18/Y/92/f?tyre=35790925#featuresOuter Quote Link to comment Share on other sites More sharing options...
SBN Posted August 18, 2018 Report Share Posted August 18, 2018 7 hours ago, Stobsie said: What pressures you running them at? They have a soft sidewall construction & I found running them a couple of psi higher than recommended made an improvement. Tried 36. Then 38 at minute. Better but still not confidence inspiring. Quote Link to comment Share on other sites More sharing options...
Growmac Posted August 20, 2018 Report Share Posted August 20, 2018 On 18/08/2018 at 06:51, Andy1a2b said: Anyone running Michelin CrossClimate-plus ? look a decent option and still quiet at 69 dB https://www.blackcircles.com/catalogue/michelin/crossclimate-plus/225/40/R18/Y/92/f?tyre=35790925#featuresOuter Yes. Have done for 15k now on the R and 30-40k on my last car (Accord). Very happy with them over the summer, and they were great over the winter in cold, wet and snow. My local place advised against them if you were planning on summer 155 mph Autobahn trips, but otherwise they are their absolute all-rounder pick. Microbe and Mainframe 2 Quote Link to comment Share on other sites More sharing options...
Andy1a2b Posted August 20, 2018 Report Share Posted August 20, 2018 37 minutes ago, Growmac said: Yes. Have done for 15k now on the R and 30-40k on my last car (Accord). Very happy with them over the summer, and they were great over the winter in cold, wet and snow. My local place advised against them if you were planning on summer 155 mph Autobahn trips, but otherwise they are their absolute all-rounder pick. Hi. Thanks for the response , I’m looking to put some winter/cross climate tyres on my 18inch wheels fie autumn winter, will have a set of 19s for summer. I definitely won’t be blasting down any autobahn. They aren’t stupid money either. How do you find the noise levels? They have a good noise rating of 69dB which is considerably less than a lot of summer tyres. I’ve had Continentals as OEM on several cars and find them quite noisy. Quote Link to comment Share on other sites More sharing options...
Martin2 Posted August 20, 2018 Report Share Posted August 20, 2018 Good comparison between the Pilot Sport 4 and 4S (and Cup2) and shows that the standard versions is still a good tyre. Tyre test goodbadboy, parkrunneR and SBN 2 1 Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted August 21, 2018 Author Report Share Posted August 21, 2018 13 hours ago, Martin2 said: Good comparison between the Pilot Sport 4 and 4S (and Cup2) and shows that the standard versions is still a good tyre. Tyre test Thanks Martin..Great find Martin2 1 Quote Link to comment Share on other sites More sharing options...
ellixtt Posted August 21, 2018 Report Share Posted August 21, 2018 I have Pilot Sport 4 on mine and can’t fault them whatsoever but I can only compare with the stock potenza as I’ve never experienced any other. A guy on YouTube I watch with an M2 was saying he prefers the PS4 vs the PSS. Quote Link to comment Share on other sites More sharing options...
Growmac Posted August 21, 2018 Report Share Posted August 21, 2018 21 hours ago, Andy1a2b said: How do you find the noise levels? They have a good noise rating of 69dB which is considerably less than a lot of summer tyres. Very very variable depending on road surface, but generally pretty good. They are definitely quieter than the Bridgestones the car came on. Andy1a2b 1 Quote Link to comment Share on other sites More sharing options...
andy_r Posted August 21, 2018 Report Share Posted August 21, 2018 Very interesting video comparing the PS4, PS4S and Cup 2s: I was all set to get PS4Ss to replace my OE tyres but given that I won't be on track any time soon I might go with the PS4s as the difference is so marginal. Quote Link to comment Share on other sites More sharing options...
Paradox1 Posted August 21, 2018 Report Share Posted August 21, 2018 im in need of 2 new tyres I have avon zz5 at the moment and im tempted to try semi slick Federal 595 RSR Anybody have experience with these? Quote Link to comment Share on other sites More sharing options...
golf7.5r Posted August 21, 2018 Report Share Posted August 21, 2018 31 minutes ago, Paradox1 said: im in need of 2 new tyres I have avon zz5 at the moment and im tempted to try semi slick Federal 595 RSR Anybody have experience with these? For road use? Just look at the wet stopping times between the 4S and the Cup2 tyres. That's the difference between a near miss and a total write off (or worse). Paradox1 and Mainframe 2 Quote Link to comment Share on other sites More sharing options...
Mainframe Posted August 21, 2018 Report Share Posted August 21, 2018 1 hour ago, golf7.5r said: For road use? Just look at the wet stopping times between the 4S and the Cup2 tyres. That's the difference between a near miss and a total write off (or worse). Yeah, but it never rains in UK and it is always hot...🙈 Quote Link to comment Share on other sites More sharing options...
