ACJMY2K Posted February 1, 2019 Report Share Posted February 1, 2019 This came up this morning, read the codes via carista but Google isn't much help... Any ideas what it might be? Sent from my SM-G955F using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted February 1, 2019 Report Share Posted February 1, 2019 If it's stop/start related almost certainly battery related especially this time if year with heaters on max and heated seats on along with lights etc...Sent from my SM-G950F using Tapatalk ACJMY2K and gregozedobe 1 1 Quote Link to comment Share on other sites More sharing options...
Hugh Posted February 1, 2019 Report Share Posted February 1, 2019 Have you observed any noticiable fault with the system in use? Quote Link to comment Share on other sites More sharing options...
ACJMY2K Posted February 1, 2019 Author Report Share Posted February 1, 2019 If it's stop/start related almost certainly battery related especially this time if year with heaters on max and heated seats on along with lights etc...Sent from my SM-G950F using TapatalkYeah I half thought this might be the issue.. cheersSent from my SM-G955F using Tapatalk Quote Link to comment Share on other sites More sharing options...
ACJMY2K Posted February 1, 2019 Author Report Share Posted February 1, 2019 Have you observed any noticiable fault with the system in use?Well everything else is fine, no issues driving or starting up. Just the stop/start doesn't kick in while idlingSent from my SM-G955F using Tapatalk Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 1, 2019 Report Share Posted February 1, 2019 14 hours ago, ACJMY2K said: Well everything else is fine, no issues driving or starting up. Just the stop/start doesn't kick in while idling Maybe see what happens if you take the car for a 20+ minutes highway drive to topup the battery ? If you decide to use a battery charger remember to use the -ve terminal on the firewall, not direct to the battery (otherwise you will confuse the BMS Battery Management System). Edit: NB Use the negative terminal on the firewall (I got confused) ACJMY2K and SpursMadDave 2 Quote Link to comment Share on other sites More sharing options...
E-V-A-N-S Posted February 1, 2019 Report Share Posted February 1, 2019 I’ve had this come up on mine a couple of times in the last few months. It’ll come up then 10 minutes later the stop start works so I just assumed the battery was a bit low and after I’ve driven a few miles its charged it above required voltage for stop start to work. ACJMY2K 1 Quote Link to comment Share on other sites More sharing options...
PHILC Posted February 1, 2019 Report Share Posted February 1, 2019 11 minutes ago, ACJMY2K said: Well everything else is fine, no issues driving or starting up. Just the stop/start doesn't kick in while idling Sent from my SM-G955F using Tapatalk Result! Quote Link to comment Share on other sites More sharing options...
Rich_D Posted February 1, 2019 Report Share Posted February 1, 2019 Carista seems to pull up allsorts of weird spurious codes for some reason, clear them, drive the car and re-scan. ACJMY2K 1 Quote Link to comment Share on other sites More sharing options...
ACJMY2K Posted February 1, 2019 Author Report Share Posted February 1, 2019 Result! it's annoying at all times apart from the morning crawl to work... I resent using my Tesco momentum to sit still!Sent from my SM-G955F using Tapatalk Quote Link to comment Share on other sites More sharing options...
75Type2 Posted February 2, 2019 Report Share Posted February 2, 2019 Modern engines use alternators with 3 charge states and in simple terms:Zero chargeTrickle chargeFull chargeMajority of the time, the alternator is in trickle charge mode. Engine braking or loading the electric system will initiate full charge mode. Hard acceleration will put the system into zero charge. You can blame the emissions efficiency chasing for this. Sent from my iPhone using Tapatalk Booth11, ACJMY2K and gregozedobe 2 1 Quote Link to comment Share on other sites More sharing options...
steeve Posted February 2, 2019 Report Share Posted February 2, 2019 Sounds as though it could be a battery issue. Quote Link to comment Share on other sites More sharing options...
