stonefish Posted November 22, 2020 Report Share Posted November 22, 2020 This video is interesting and suggests the problem is down to poor installation causing damage to the plastic and oil contamination of the seals. (4) How VW 2.0t TSI Water Pumps Fail - YouTube Russellj and Booth11 1 1 Quote Link to comment Share on other sites More sharing options...
rbel5553 Posted December 2, 2020 Report Share Posted December 2, 2020 This video is interesting and suggests the problem is down to poor installation causing damage to the plastic and oil contamination of the seals. I love that guy. He really knows his stuff. It’s just difficult to find the time to “drop the car off “ as he is in the USA and I’m in Ireland. Sent from my iPhone using Tapatalk Ignition1 1 Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted December 2, 2020 Report Share Posted December 2, 2020 6 hours ago, rbel5553 said: I love that guy. He really knows his stuff. It’s just difficult to find the time to “drop the car off “ as he is in the USA and I’m in Ireland. Sent from my iPhone using Tapatalk What if we do a group buy-in and pay for him to fly over and fix all our Rs in a car park somewhere. rbel5553 1 Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted December 2, 2020 Report Share Posted December 2, 2020 On 07/11/2020 at 11:10, Booth11 said: PP gets the revised termo housing along with battery cover, lower engine cover, full under tray and bonnet insulation that doesn’t shrink. And I’m sure I’ve missed half a dozen other things. 😂 Is this for real? The lack of lower engine cover, under tray and shrinking bonnet insulation on the MK8? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 2, 2020 Report Share Posted December 2, 2020 1 hour ago, Ignition1 said: Is this for real? The lack of lower engine cover, under tray and shrinking bonnet insulation on the MK8? No I’m afraid it was sarcasm. Needs to be read in context with the preceding and following posts. Ignition1 1 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted December 2, 2020 Report Share Posted December 2, 2020 My sister has just had her coolant housing and pump replaced on her mk7 GTI for £636 by an independent. VW wanted £1040. Her electronic motor driven thermostat was stuck closed which was causing it to overheat. (Motor no longer working). VCDS reported low coolant flow, it reported not to be driven over 4K rpm on the dash and obviously temp gauge went all the way around to the red. What was really weird is VCDS never flagged an electrical issue with the motor just poor coolant flow. So I would assume there is a flow meter sensor somewhere. Oh 5yr old and 46k. camelsac2002 1 Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted December 3, 2020 Report Share Posted December 3, 2020 15 hours ago, Booth11 said: No I’m afraid it was sarcasm. Needs to be read in context with the preceding and following posts. I did some research after - at least on the bonnet insulation shrinking, and saw a post on here about it on the MK7 that VW blamed on a mod the owner had done Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 3, 2020 Report Share Posted December 3, 2020 Just now, Ignition1 said: I did some research after - at least on the bonnet insulation shrinking, and saw a post on here about it on the MK7 that VW blamed on a mod the owner had done Well, we all know that’s complete bullsh1t. My car is not modded (aside from pedal box and some cosmetic stuff) and my bonnet insulation is now the size of a postage stamp - ok exaggeration, but it’s shrunk like most of them, modded or not. I should have got it replaced under warranty but never got round to it. I expect they would have blamed its shrinking on me detailing my car. 😁 Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted December 3, 2020 Report Share Posted December 3, 2020 14 hours ago, TechieAli said: My sister has just had her coolant housing and pump replaced on her mk7 GTI for £636 by an independent. VW wanted £1040. Her electronic motor driven thermostat was stuck closed which was causing it to overheat. (Motor no longer working). VCDS reported low coolant flow, it reported not to be driven over 4K rpm on the dash and obviously temp gauge went all the way around to the red. What was really weird is VCDS never flagged an electrical issue with the motor just poor coolant flow. So I would assume there is a flow meter sensor somewhere. Oh 5yr old and 46k. £1,040. Based on my last "Specific Components" VW warranty I just purchased, that much pays for nearly four years of warranty from VW - which will cover the coolant issue + a whole lot of other things. Given how common the coolant / thermostat issue is - warranty is worth buying just for that! Could be worth looking into for your sister? Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted December 3, 2020 Report Share Posted December 3, 2020 3 minutes ago, Booth11 said: Well, we all know that’s complete bullsh1t. My car is not modded (aside from pedal box and some cosmetic stuff) and my bonnet insulation is now the size of a postage stamp - ok exaggeration, but it’s shrunk like most of them, modded or not. I should have got it replaced under warranty but never got round to it. I expect they would have blamed its shrinking on me detailing my car. 😁 I haven't thought to check mine!! I better take a look soon. Maybe they'll blame mine on leaving my car in the sun too long. Or using the wrong car wash+wax liquid on it. Only VW authorised car wash liquids may be used on ze car. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 3, 2020 Report Share Posted December 3, 2020 15 minutes ago, Ignition1 said: I haven't thought to check mine!! I better take a look soon. Maybe they'll blame mine on leaving my car in the sun too long. Or using the wrong car wash+wax liquid on it. Only VW authorised car wash liquids may be used on ze car. 😂 VW reasons for refusing stuff is almost on the same level as Network Rails for not running trains. Mine shrank early on so I really should have had it replaced during the original warranty. It’s just the top (or bit nearest the windscreen) where it’s shrunk so the tabs no longer slot into the holding slots. The rest is all anchored down with the pins. Like so It can be the next owners problem! Quote Link to comment Share on other sites More sharing options...
Dr Mike Oxgreen Posted December 3, 2020 Report Share Posted December 3, 2020 ^^^^^ I have exactly the same problem. I just slip the tags back into the slots every time I check the fluid levels, all the time thinking that if I wanted that kind of build quality I'd have bought a Vauxhall... Quote Link to comment Share on other sites More sharing options...
TechieAli Posted December 3, 2020 Report Share Posted December 3, 2020 Even if my sister had taken and extended warranty (2 on top of the original 3) it would have still been outside of that. It is her first issue though otherwise it’s been faultless. Cars just aren’t what they used to be. They just make them cheaper and cheaper and just charge more. camelsac2002 1 Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted December 6, 2020 Author Report Share Posted December 6, 2020 Even if my sister had taken and extended warranty (2 on top of the original 3) it would have still been outside of that. It is her first issue though otherwise it’s been faultless. Cars just aren’t what they used to be. They just make them cheaper and cheaper and just charge more.Bit like new houses! I wouldn’t touch a new house with a ten foot barge pole - especially when I see how they’re built!Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Barry Singleton Posted March 28, 2023 Report Share Posted March 28, 2023 Have same issue on a 2016 Mk7 GTI with 70k miles. Martins Garage would not fit new thermostat without an assessment charge of 1hr @ £150. Total estimate is an additional 3hrs labour plus cost of parts: £366 for thermostat housing and £82 for water pump. Total cost will be approx. £1200. Decided to keep topping up as leak is very minor at the moment. From below a small 'hanging' drip can be seen below the thermostat housing. If it gets worse I will consider using a coolant sealant. Another thought is....Why do garages insist on changing the housing when it is the seal that leaks ? Quote Link to comment Share on other sites More sharing options...
