Bazd13 Posted October 23, 2014 Report Share Posted October 23, 2014 Think I have had most of the popular issues 1. Juddering drivers wiper - bought bosch ones myself 2. Rear spoiler trim coming away - superglued it 3. Brake disks moving when reversing - parts in and being done under warranty next week. 4. Sound actuator - was doing it at mid revs but eventually went away and not had it for couple months. Other than all this, I love the thing. Quote Link to comment Share on other sites More sharing options...
add1ct3dd Posted October 23, 2014 Report Share Posted October 23, 2014 Juddering wipers is just from the dirt on the windscreen & wipers from transport - clean it properly and there's no issue :] Cheaper fix! Quote Link to comment Share on other sites More sharing options...
sumo69 Posted October 23, 2014 Report Share Posted October 23, 2014 Mine requires a whole new door card and associated trim for 1 of my rear doors - some of the panels keep popping out and they cannot seem to fix it. I cannot understand how some of these faults are not being resolved before the car leaves the factory - the QC isn't very impressive! David Quote Link to comment Share on other sites More sharing options...
PixelPeep Posted October 25, 2014 Report Share Posted October 25, 2014 Anyone have an electronic whine coming from behind the head unit after you turn the ignition off? Usually lasts a good 3-5 minutes after key out? Fan? Quote Link to comment Share on other sites More sharing options...
Cobinho Posted October 25, 2014 Report Share Posted October 25, 2014 Just had rear spoiler trim stuck back by vw.they told Me they will cover cost of adhesive strip but i have to meet cost of trim.i told them not a chance and eventually got it.i got new wipers on the front as was Smearing.still have a bang/click when braking in reverse i think its movement in rear pads.drivers side door pillar has a little swith that pips out everytime door closed. Quote Link to comment Share on other sites More sharing options...
goRt Posted October 25, 2014 Report Share Posted October 25, 2014 Anyone have an electronic whine coming from behind the head unit after you turn the ignition off? Usually lasts a good 3-5 minutes after key out? Fan? You mean the unit's cooling fan? Quote Link to comment Share on other sites More sharing options...
B13NGL Posted November 3, 2014 Report Share Posted November 3, 2014 After all the excitement of a new car dies down and you begin to really think about all the niggles, what, if any issues have you long term owners found? I've read about turbo, exhaust issues which are apparently now rectified. Sound actuator vibration. Rear spoiler coming away from the rear windscreen. Any more, And if so have they been rectified and how did your VW dealer fix? Thanks guys! Quote Link to comment Share on other sites More sharing options...
harryhackenbacker Posted November 3, 2014 Report Share Posted November 3, 2014 As you say feedback I think has solved these problems, I had the dealer Insulate my sound actuator and it's great rear spoiler I fixed myself till service with no nails double sided . My turbo is still spinning, and that's about it Quote Link to comment Share on other sites More sharing options...
54Kab Posted November 6, 2014 Report Share Posted November 6, 2014 I'm 6 months in, roughly 7,500 miles. - Rear spoiler, specifically the bottom of the thin arms are a bit loose - Revs fluctuating (?) -seems to move from 1k to 1.5k revs on its own when you first stop - anyone else got this? - in the last week I've noticed a slight rattle when closing the doors - sounds like a heat shield or exhaust bracket underneath, roughly in the centre ..apart from that, it's all good, a real weapon Quote Link to comment Share on other sites More sharing options...
neilje Posted November 7, 2014 Report Share Posted November 7, 2014 My dealer is going to fix my rear spoiler trim by using windscreen adhesive when it goes in for its first service in about 1000 miles. Plus side is it won't ever come off, but on a negative note, if the rear glass ever needs replacing the whole lot will have to come off. Quote Link to comment Share on other sites More sharing options...
VW7R Posted November 7, 2014 Report Share Posted November 7, 2014 The 7R is a non-premium £34k hot hatch. It is not a £49k premium BMW Saloon. I don't expect it to be as well made as a BMW, as fault-free or have the same high levels of service from dealerships. Best to be realistic. Quote Link to comment Share on other sites More sharing options...
MoldCAD Posted November 8, 2014 Report Share Posted November 8, 2014 Forums are a wonderful place if you want to read about all of the possible problems as people naturally share bad experiences rather than good. Who has seen a thread starting... 'My golf R is perfect with no problems whatsoever'. But honestly, my Golf R is perfect with no problems whatsoever! Quote Link to comment Share on other sites More sharing options...
MarkH Posted November 13, 2014 Report Share Posted November 13, 2014 R booked in VW dealer to replace sound actuator (vibrator), replace black rear spoiler bits that are hanging off and rectify rubbing brakes when reversing. has anyone had any of these items rectified, if so, how did it go? UPDATE: VW dealer has replaced the black rear spoiler bits and tightened and insulated the sound actuator. Vibration has gone, but it does not sound as loud (this could be my imagination). But.....it still sounds great. Quote Link to comment Share on other sites More sharing options...
MarkH Posted November 21, 2014 Report Share Posted November 21, 2014 R booked in VW dealer to replace sound actuator (vibrator), replace black rear spoiler bits that are hanging off and rectify rubbing brakes when reversing. has anyone had any of these items rectified, if so, how did it go? UPDATE: VW dealer has replaced the black rear spoiler bits and tightened and insulated the sound actuator. Vibration has gone, but it does not sound as loud (this could be my imagination). But.....it still sounds great. I have driven the R for a week now after the dealer has sorted the sound actuator. They have sorted it alright, you can only just hear it now. I know that some people say that the car sounds better without it but although it is sad, I am missing the generated sound. I have booked it back in so that the dealer can check with VCDS if the volume has been turned down. If not then some of the insulation is coming off......there is no hope for me. Quote Link to comment Share on other sites More sharing options...
Trickz Posted January 6, 2015 Report Share Posted January 6, 2015 well my wipers finally don't judder or smear with either the oe ones or bosch wipers after I had to have a new screen fitted(cracked screen)it's a non vw stamped pilkington one supplied by autoglass. Quote Link to comment Share on other sites More sharing options...
