issues / bugs
zeebow
I have found that if you create or choose a driver profile selection with the engine at sport mode, it only remains active until you turn off the car completely.
After that you'll need to re-select the desired profile again if you want the engine back on sports mode.
Despite the fact that you can not see this into the settings you can hear clearly the difference if you take your foot off the accelerator.
In sport mode, the exhaust makes a nice gurgling.. otherwise it sounds flat.
Have you got a manual or DSG. Mine is DSG and seems to remember it correctly.
Two things for me.
1. The sound thingy at fully throttle is bottoming out. Like it can't handle the volume.
2. This morning on my way in to London the revs didn't stay stable in a traffic jam. They went down to thousand'ish to then raise to fifteenhundred'ish to then drop and rise again. Very odd.
I think ill book it in to get it checked over.
Thx for your feedback dejongj..
I think it's the flapper mod that I have conducted which creates this issues.
Best I can do to check this is attaching the valves back in.
Now you get an error from VCDS ..which is perfectly normal..told that both motors that operate the valves do not work
99% sure that this engine sports mapping reset back to normal by the issues.
Had hoped that several manual riders went respond on it.
I am surprised that there are not many who have done the flapper mod.
  • 1 month later...
  • Replies 225
Well on Friday I noticed that the passengers door isn't sitting flush it was ok on handover a week earlier I've been away for weekend so im gonna phone dealer and get them to have a look its 3 door btw.
There was a similar issue on the mk6 3dr cars. Just needed the bolts tightening
Found some drops of rain inside the passenger door. Window and door had not been opened and no obvious signs of water ingress. Will do a hose test.
Smeary/ juddery wiper
Delay in power delivery when accelerating hard (DSG)
Sound actuator rattle.
Putting all that aside - what a car this is. :afro:
I noticed water gets in through the seals on my rear doors. Along the top the rubber seal has a small kink where the opening rear window meets the fixed window at the top of the door. Water hasnt actually got onto seats etc.il keep an eye on this as it shouldnt pass the seals full stop.
Two things for me.
I have flapper mod and mine doesn't do this - I can't see how disconnecting exhaust flaps can have an effect on much else apart from the flaps.
The ROD error mentioned early on is the flapper mod - makes no difference to anything else.
When you say 'power delivery' are you referring to the time it takes to change gear. I have had a couple of occasions when starting off hard in 'sport' where the rev limiter cuts in before the DSG box changes gear. It's as if it doesn't realise. Acceleration stops briefly while it realises it needs to change up. It is more noticeable from 1st to 2nd, although I have had it 2nd to 3rd.
Bloody annoying when you're showing someone 'how quick it is'.
Anyone else noticed it?
Two things for me.
yep .. indeed already encountered.
'm just glad I'm not the only one, but I am still wondering what it could be..
maybe it's the kind of media radio type..ppfff.. I dont now
register this case at VW dealership
