Guy Incognito
1 hour ago, PhilC22 said:
This is very helpful.
Explains why my "in transit" car has just changed from 3 weeks (to get to local dealer) to 10 days on the tracker..
Dont know whether the optional email/text notification goes through 5a-c, as i didnt bother selecting it.
It does (both text and email) but can skip some stages.  For mine I got text and email notifications for 5a and 5b but it skipped 5c and went straight to 6.  Also skipped from stage 3 straight to stage 5a which is not unusual.
Hiya, what's the price of a nigh on full tank of petrol please .. both normal and super unleaded? (UK based)
When my fuel light comes on on my last
fill up it costs me £65.99 for 258 miles, that's 23.1 mpg, mainly around the door driving. There's around 30 miles left in the tank when the fuel light comes on.
Does anyone know if you can set the default screen on the central computer in the 'car' menu?
I know you can switch between nav, car etc.
what I am finding is when I select 'car' it appears random which screen appears. Sometimes it is 'convenience consumers' sometimes it's 'vehicle status' sometimes it is 'driving data'. To be honest 95% of the time I just want 'driving data' as it's the most useful screen. I don't really want the others. So can you set it to default on 'driving data'?
I've got an early 2015 Golf R so there are only three options on the 'car' screen for me. I know on the updates that were done (mid 2016 I think) they added the 'think blue' trainer and another screen which had the 3 sports dials with stuff like Gforce. I haven't got those two. Don't suppose there is any way to get a s/w update to get those added?
2 minutes ago, tweaked9107 said:
Can you switch off the start stop system permanently? I got used to turning it off at the same time as starting the car with my old BMW but would rather not have to do that this time around.
I believe it is possible but only through VCDS coding, not a 'punter' option  though I'm sure one of our VCDS bods will be along in a min to confirm
If you want it off permanently, then you'll need to use either vcds or obdeleven to do it.  Coding for both is on the forum, in the respective sub boards.
I used to switch mine off every journey but in the end got obdeleven and disabled it for good.  Good riddance. 😁
I used to switch mine off every journey but in the end got obdeleven and disabled it for good.  Good riddance. 1f601.png
Thanks for the replies. I'll see how annoying it is when I get the car and maybe code it out as you say.
Its annoying but I think it might be 'forced'' on as default as something to do with emissions testing' I suppose they could have had the switch but had it off as default but perhaps the emissions are tests at default settings? Just a guess.
its less intrusive in a manual car but pretty annoying in a DSG.
I usually try try to leave it on but then you can guarantee in stop start traffic it will keep cutting out just as the car In front moves off.
probably the worst thing is every time you switch the engine off it defaults back to on.
Rather than completely disable it with obdeleven can you just set default to off? That would be best.
Disabling it with vcds/obd11 doesn't quite work like that, it's not a case of smiply deselecting it, you have to change the S/S limit voltage to something it will never reach to stop it kicking in, or another way is to alter coolant temp to an unacheiveable amount. See below.  I think if setting it to be off by default was possible it would have been sussed by now.
Ah. I see. Thanks for the explanatory link. I obviously thought the coding was more sophisticated.
I got an Autowatch Ghost immobiliser fitted to my car, as part of this you have the option to disable or enable the start stop. Mines off by default every time I start the car.
