R-Estate Posted June 8, 2017 Report Share Posted June 8, 2017 Pretty certain that's what I have done Once you have done that, do you need to set the mirror switch to L and leave it there for it to work? Do you need to take it out of R to do the second part? Does the engine need to be on or would ignition suffice?It needs to be in L for it to work but obviously only triggers when in reverse. Engine should be running. Think I readjusted my mirror once back in neutral. Quote Link to comment Share on other sites More sharing options...
mickR Posted June 8, 2017 Report Share Posted June 8, 2017 Ha good point RebeccaSent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
R-Estate Posted June 8, 2017 Report Share Posted June 8, 2017 It needs to be in L for it to work but obviously only triggers when in reverse. Engine should be running. Think I readjusted my mirror once back in neutral.Missed the updates above but hopefully you'll get it working now Quote Link to comment Share on other sites More sharing options...
Taz23-R Posted June 8, 2017 Report Share Posted June 8, 2017 Cheers guys. My next R newb question I can't for the life of me get the reversing, left wing mirror to change or change back. I've used some instructions I found on here but it seems to do odd things ... like it will change when I go into reverse but then not change back? Does anyone have any exact instructions on how to set it up or know where it is in the huge owners guide to follow please? Thanks and sorry for all the questions When it in L on the wing mirror switch and you go into reverse the mirror will dip, once you pull away and do over 10mph the mirror goes back to its normal position. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Richard2 Posted June 8, 2017 Report Share Posted June 8, 2017 Hi, New owner. Been tinkering with the active info display. Would like it to show the enlarged navigation map but also have a digital speedometer reading in one of the dials. Is this possible? I have been going round in circles with the buttons and even tried to understand the manual but as a bloke I come over all funny reading that. Any thoughts from those who have the active display thingy. I know it has a tiny digital speedometer at the base of the Rev counter but was really hoping for a bigger one in the centre of a dial. Grew up in the eighties so the digital dash in my Astra GTE still holds fond memories. Quote Link to comment Share on other sites More sharing options...
tweaked9107 Posted June 8, 2017 Report Share Posted June 8, 2017 2 hours ago, Richard2 said: Hi, New owner. Been tinkering with the active info display. Would like it to show the enlarged navigation map but also have a digital speedometer reading in one of the dials. Is this possible? I have been going round in circles with the buttons and even tried to understand the manual but as a bloke I come over all funny reading that. Any thoughts from those who have the active display thingy. I know it has a tiny digital speedometer at the base of the Rev counter but was really hoping for a bigger one in the centre of a dial. Grew up in the eighties so the digital dash in my Astra GTE still holds fond memories. You mean like this?: If so scroll to view and then scroll down until you get the gear in the left one and speed in the right. Then when that's done scroll across to navigation. Hit okay and you are done. maccas99 1 Quote Link to comment Share on other sites More sharing options...
Richard2 Posted June 8, 2017 Report Share Posted June 8, 2017 You are a star. Thanks Rich Quote Link to comment Share on other sites More sharing options...
Harry8052 Posted June 10, 2017 Report Share Posted June 10, 2017 Hey folks, does anyone know if you can get the track info etc in the active info display when using apple car play? I was using dezzer here but it's the same when using iTunes through car play. Cheers! Quote Link to comment Share on other sites More sharing options...
Taz23-R Posted June 10, 2017 Report Share Posted June 10, 2017 Hey folks, does anyone know if you can get the track info etc in the active info display when using apple car play? I was using dezzer here but it's the same when using iTunes through car play. Cheers! Yer mine does the same just comes up car play. It's frustrating. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
rbel5553 Posted June 10, 2017 Report Share Posted June 10, 2017 Cheers guys. My next R newb question I can't for the life of me get the reversing, left wing mirror to change or change back. I've used some instructions I found on here but it seems to do odd things ... like it will change when I go into reverse but then not change back? Does anyone have any exact instructions on how to set it up or know where it is in the huge owners guide to follow please? Thanks and sorry for all the questions OK. At least you got it to tilt downward on reverse engagement. If you reverse out of a parking space and dawdle around the car park slowly toward the exit I notice that the rear camera and LHS mirror can be slow to revert to normal. That appears to be a foible. The exact instructions are in the manual. I always have to refer back to it for this if I "lose" that functionality AND for the "service position" of the wipers when washing the car. .......ah......don't ask me about the service position and what it is because I'm going out now.....Read the manual!( I know Beccs is going to say you should wash it more often and you won't forget.....my bad. )Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 12 minutes ago, rbel5553 said: ( I know Beccs is going to say you should wash it more often and you won't forget.....my bad. ) Sent from my iPad using Tapatalk Not at all, it's etto. ☺️ I find getting the wipers into service position can be hit and miss, doesn't always work first time for me despite the exact same procedure every time - ignition on (fully with foot on brake) then off, press wiper stalk down once - it often takes two/three goes to get them to move to vertical position, then other times it's ok first go. 😕 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 10, 2017 Report Share Posted June 10, 2017 Not at all, it's etto. I find getting the wipers into service position can be hit and miss, doesn't always work first time for me despite the exact same procedure every time - ignition on (fully with foot on brake) then off, press wiper stalk down once - it often takes two/three goes to get them to move to vertical position, then other times it's ok first go. I don't press brake. Ignition on then offPress down wiper stalk. Sent from my iPhone using Tapatalk Benjamino69uk 1 Quote Link to comment Share on other sites More sharing options...
Richard2 Posted June 10, 2017 Report Share Posted June 10, 2017 Back to ask the experts another question. Sorry I am all take take take... The drivers seat in the handbook shows two levers under the front of the seat. One on the left to move the seat forwards and backwards and also one on the right to alter the tilt of the seat base. My estate does not have the one on the right, what am I missing here. Glad this forum is not like Pistonheads I never dare post anything on there it seems to be populated by some very aggressive people. I have the the active display all set up how I want it now thanks to Stefan so thanks again. Rich Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 5 minutes ago, Richard2 said: Back to ask the experts another question. Sorry I am all take take take... The drivers seat in the handbook shows two levers under the front of the seat. One on the left to move the seat forwards and backwards and also one on the right to alter the tilt of the seat base. My estate does not have the one on the right, what am I missing here. Glad this forum is not like Pistonheads I never dare post anything on there it seems to be populated by some very aggressive people. I have the the active display all set up how I want it now thanks to Stefan so thanks again. Rich Sadly, the R doesn't have the option to tilt the seat base, so it's minus that lever. 🙁 Quote Link to comment Share on other sites More sharing options...
Benjamino69uk Posted June 10, 2017 Report Share Posted June 10, 2017 1 hour ago, Booth11 said: Not at all, it's etto. I find getting the wipers into service position can be hit and miss, doesn't always work first time for me despite the exact same procedure every time - ignition on (fully with foot on brake) then off, press wiper stalk down once - it often takes two/three goes to get them to move to vertical position, then other times it's ok first go. To get wipers into service mode I've found that: if you turn the ignition on but don't start the car, then turn if off again, press the wiper arm down within 9 seconds of switching the ignition off the wipers go into service mode. slider09 1 Quote Link to comment Share on other sites More sharing options...
