Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 7 minutes ago, Benjamino69uk said: To get wipers into service mode I've found that: if you turn the ignition on but don't start the car, then turn if off again, press the wiper arm down within 9 seconds of switching the ignition off the wipers go into service mode. Both ways still tend to be temperamental for me at times, but have found engine off/on more hit than miss method. Benjamino69uk 1 Quote Link to comment Share on other sites More sharing options...
tweaked9107 Posted June 11, 2017 Report Share Posted June 11, 2017 I've never really thought about this but in a DSG if you want to rev the engine to have a listen would you do it in park or neutral. I naturally assume neutral but would it make any difference? Quote Link to comment Share on other sites More sharing options...
Jonnyfez Posted June 11, 2017 Report Share Posted June 11, 2017 1 hour ago, tweaked9107 said: I've never really thought about this but in a DSG if you want to rev the engine to have a listen would you do it in park or neutral. I naturally assume neutral but would it make any difference? I don't think it makes a difference. If you do it in P the revs are limited I think. The other day I videoed a launch and some revs and the exhaust sounded much gruntier in launch mode. So if you just sit in Park you can hear the engine/exhaust but if you put the car in launch mode it sounds better....you don't have to launch it, just put it in launch mode. Eg. Traction off, Race Mode, DSG in Sport. Left foot hard on brake....rev it hard. You'll be able to rev higher than you can in P. I tried this the other day. As I say I didn't launch the car, just listened and felt the power. I assume this does not actually constitute a 'launch'. Sounds great! Then i I went somewhere else and did a launch....haha. Quote Link to comment Share on other sites More sharing options...
Sunny66 Posted June 11, 2017 Report Share Posted June 11, 2017 I have a question in regards to launch control. When i try launch control im getting a lot of wheel spin from the front wheels, i understand some wheel spin is expected but not as much as im experiencing. I have seen another golf r launch and it had almost no wheel spin. I turn the traction off completly, Race Mode via the button, DSG goes into sport due to being in race mode. Left foot hard on the brake, rev to 4000rpm limit and wheels spin! I have also checked the tyre pressures and tread, all are ok. Any ideas on what im doing wrong? or whats wrong with the car? Quote Link to comment Share on other sites More sharing options...
mickR Posted June 11, 2017 Report Share Posted June 11, 2017 I take it you haven't read in owners handbook the recommended RPM for launch? Quote Link to comment Share on other sites More sharing options...
75Type2 Posted June 12, 2017 Report Share Posted June 12, 2017 I have a question in regards to launch control. When i try launch control im getting a lot of wheel spin from the front wheels, i understand some wheel spin is expected but not as much as im experiencing. I have seen another golf r launch and it had almost no wheel spin. I turn the traction off completly, Race Mode via the button, DSG goes into sport due to being in race mode. Left foot hard on the brake, rev to 4000rpm limit and wheels spin! I have also checked the tyre pressures and tread, all are ok. Any ideas on what im doing wrong? or whats wrong with the car?Sounds like your haldex needs some investigation work, as you shouldn't really get any wheel spin. Quote Link to comment Share on other sites More sharing options...
mickR Posted June 12, 2017 Report Share Posted June 12, 2017 The haldex maybe okay, VW state following - With your right foot, depress the accelerator until the engines speed reaches approximately 3,200 rpm. Quote Link to comment Share on other sites More sharing options...
Sunny66 Posted June 12, 2017 Report Share Posted June 12, 2017 14 hours ago, mickR said: The haldex maybe okay, VW state following - With your right foot, depress the accelerator until the engines speed reaches approximately 3,200 rpm. I have just tried launching at 3200rpm, although it does go it doesnt seem quick and it doesnt make that cool launch sound 😔 How do people launch at 4000rpm, make the cool sound and get no wheel spin? lol Quote Link to comment Share on other sites More sharing options...
tweaked9107 Posted June 13, 2017 Report Share Posted June 13, 2017 I thought the procedure was just mash the brake, slam the accelerator to the floor and then let go of the brake. I thought the car set the revs for you? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
TeaJay Posted June 13, 2017 Report Share Posted June 13, 2017 2 hours ago, tweaked9107 said: I thought the procedure was just mash the brake, slam the accelerator to the floor and then let go of the brake. I thought the car set the revs for you? Sent from my iPhone using Tapatalk That was exactly my thinking as well; you don't need to do anything with the revs, car manages it for you .. you just jump on the accelerator? Quote Link to comment Share on other sites More sharing options...
ScoobyNoMore Posted June 13, 2017 Report Share Posted June 13, 2017 I have some 215/50/17 winter tyres I used on my Subaru. These seem to be the exact size match for the 235/35/19 summer tyres but don't seem to be the recommended 17" size. Has anyone used this size? Also I take it there is no problem with fitting 17" wheels over the brakes on the R? Thanks Robert Quote Link to comment Share on other sites More sharing options...
Sunny66 Posted June 13, 2017 Report Share Posted June 13, 2017 12 hours ago, tweaked9107 said: I thought the procedure was just mash the brake, slam the accelerator to the floor and then let go of the brake. I thought the car set the revs for you? Sent from my iPhone using Tapatalk 10 hours ago, TeaJay said: That was exactly my thinking as well; you don't need to do anything with the revs, car manages it for you .. you just jump on the accelerator? I was under the same impression, I just get a lot of wheel spin from the front wheels when i try and launch. It looks like im going to have to go back to VW. Although i do have a funny feeling that they are going to try and fob me off by saying they need to change the haldex oil which will be at my cost. The thing is, i dont mind paying to service the haldex but im fairly positive it still wont launch without wheel spin, which then they will say i need to launch at 3200rpm and not mash the accelerator, which to me doesnt feel like 4.9second! 😔 well we will just have to wait and see what the good of folks at the stealers say! Quote Link to comment Share on other sites More sharing options...
Jonnyfez Posted June 13, 2017 Report Share Posted June 13, 2017 3 hours ago, Sunny66 said: I was under the same impression, I just get a lot of wheel spin from the front wheels when i try and launch. It looks like im going to have to go back to VW. Although i do have a funny feeling that they are going to try and fob me off by saying they need to change the haldex oil which will be at my cost. The thing is, i dont mind paying to service the haldex but im fairly positive it still wont launch without wheel spin, which then they will say i need to launch at 3200rpm and not mash the accelerator, which to me doesnt feel like 4.9second! well we will just have to wait and see what the good of folks at the stealers say! I have only done three launches but each time I've floored the accelerator and had no wheel spin. the only other thing I can think of is maybe your tyres? Are they new? Are they worn? I believe that the tread level remaining on all tyres and particularly those on the same axle should be as close as possible and ideally with a couple of mm. The car adjusts the power going to the front/back and if the tyres have different tread levels it can confuse the car. That's what I have been told anyway. In two months of driving and 2 thousand miles I have never noticed any wheel spin at all including doing launches and accelerating from standstill in the wet. So it sounds like something is not right with yours. I've seen quite a few launch videos where the drivers just floor it with no regard to the 3200rpm thing and I've not noticed any when spin on them either. i hope you sort it. It's not a critical thing but the car should be able to avoid wheel spin. good luck. Quote Link to comment Share on other sites More sharing options...
rbel5553 Posted June 14, 2017 Report Share Posted June 14, 2017 Vinegar?..Quick Question. I have been using the AC in the recent warm weather and the cabin has developed a scent of vinegar/acetic acid. Any thoughts? Errr.... no! Nobody eats chips in my car and no I haven't had the car "chipped" lol!Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 14, 2017 Report Share Posted June 14, 2017 58 minutes ago, rbel5553 said: Vinegar?..Quick Question. I have been using the AC in the recent warm weather and the cabin has developed a scent of vinegar/acetic acid. Any thoughts? Errr.... no! Nobody eats chips in my car and no I haven't had the car "chipped" lol! Sent from my iPad using Tapatalk At any point have you used vinegar to clean the windscreen? Or a glass cleaner containing acetic acid? I would expect the heat would exacerbate any smell. I once used white vinegar to clean windscreen of my old car and it stank for ages. Quote Link to comment Share on other sites More sharing options...
